! - Possible Fix for Klarus XT12GT - !
So, I’ve been hard on my XT12GT flickering from the beginning, but I recently discovered that if you remove the pocket clip, you will find that the tailcap can be screwed on tighter and can make a better connection. This totally fixed my flickering issue AND made the light about 100 lumens brighter. I managed to screw down the cap tighter and still get the clip back on, and all is OK now.
Try this if you’ve been having trouble with your XT12GT. Mine was put on too high, which made this undetectable connection issue. Try it.
So maybe the clip arms need a little filing to make them thinner?
