I have built Zener modified Qlite drivers and Wight’s PZL driver with a Zener mod for the 6V emitter, but the 7135 chip is not designed to run with an 8.4V power supply so there is potentially a problem with that if using the light for longer periods and/or in the lower modes where the regulation chip is holding back more of the current.
I prefer to use the MOSFET driver and if need be tone it down with PWM. The little 14500’s can be surprising, a pair of em can do 6A or more in most cases and of course you can just avoid Turbo to make it easier on the cells.
LED4Power’s LD-2 is a better approach, I think. I have a few of those left, might try that some day. Nice mod Khas, bet it’s a really sweet performer in a “sleeper” of a light!
Hi Paul, I hate to say this but I think you work so hard you just might be crazy, but your a good man and always treat me very good thank you, this must be better than my Long Emails to you… Gary
Hope you like my pictures, I know your product is always high quality but this AA light is over the top, meaning the best light you have made for easy modifying yet, just a perfect light, Thanks…!
Thanks Dale this does explain why some issues have come up in some of my 14500 builds, now I get it, and now looking at that LD-3 or even the 2 as you mentioned, sounds much better really.
I am currently using RMM’s WindyFire cells and they are really nice, HJK gave them a nod and so does Richard obviously and your comment about amps explains everything, thank you,
Every build I do I always think I have it right but I’m still light years away from your knowledge so before I flip the switch for the first time I still hold it out at arms length and then fire it, never know,
I’ve really blown some stuff up, that learning curve can get steep at times.
Did you buy the UV E3 also? Or, the U1 I think it is with the pill in it?
I think you might be thinking or seeing what I’m seeing and it’s not for Norland but just a nice looking shell to me anyhow and I’ve still not looked inside yet but have to today it’s killing me,
I’m buying that other $20 UV also, seems it’s the only way now to get the shell but I see potentials.
But I am overly curious what your up to frankly and I’m doubtful it is for curing anything and it’s not curing my curiosity … ha ha
There is the Dale take on things, so if curiosity killed the cat I am dead but it’s a must know situation for sure, might save me from myself … ha ha
I got the U1, it’s a midrange Nichia UV that’s between 2 I already have. Tiny by my larger ones standards but it makes a nice amount of light and things really fire up under it. I got it for general purpose checking, like, how clean is your bathroom REALLY? I have one I built that I took with us to MS a couple of weeks ago and scoped out the hotel room. It actually passed quite well but then it was a newly remodeled room. Visually, our laundry room looks quite decent. The UV light says otherwise! There are detergent splashes down the counter and on the wall, a shocking mess! Dare I show mom?
This one is a tiny emitter and the driver doesn’t even have chips on the spring side, so it’s probably only doing about 700mA. I have a NVSC333A (think that’s right) that’s pulling 3.8A! It’s wickedly powerful for a single UV emitter. Cures Norland very fast.
The U1 has a matte black ano that is really well done and the text is all aligned, like they assembled each light for the text part, not pulling bits of single pieces out of a box. Nice work.
Yeah, I hear ya, you can bet I was a bit on the antsy side when I fired up my DBC-05 Triple XHP-50.2 the first time… didn’t know if it was gonna pull 20A or 30… have learned to test fire with a piece of steel across the tube to the cell first, beat’s screwing the tail cap on and hitting the switch. (also learned to test for continuity before even putting cells in, to make sure the positive spring isn’t in circuit with the ground)
Ha Ha Ha, Oh wow, I am right with you and the UV inspections and I’m single but still there’s no excuse and that UV has disturbed me more than once that’s for sure, the Convoy I got is pretty good and it shows just how bad I am at house cleaning but also handy when looking for things in the carpet, I’ve lost stuff and grab to UV and found what I lost in seconds, then the cats, oh, never mind I love them anyhow, it the just knowing it’s there but not visible, and don’t take these UV’s I’ve discovered to lady friends homes to show them what I thought would be funny, it wasn’t at all, they will get very very mad at you, they to are some really lousy house keepers for ladies so I don’t feel to bad, but the dust is what gets me, it shows just how dusty things get,
I just tore apart that E3 UV and it’s got a pill and a decent reflector but is still longer than a Utorch UT01 with a 16mm board and driver pilled, so I like the looks but the output is fairly useless so will do something eventually with it, my curiosity is cured, for now, Thanks Dale
By the way so darn funny to hear you say how antsy it can get on some builds, I did a crazy mod on the Maxtoch 2X and used the remote switch to fire that one, it’s always so nice when nothing happens, better safe than overly sorry… ha .!
I think I’m cut and pasting that bit about test for continuity into my couple years now, The Book of Dale, The Enlightening, and all things sketchy or dangerous that you can do with flashlights during your weekends currently for sale at 7/11 for only $19.95, by one now and I’ll give you the second one with a free dangerous flashlight. :smiling_imp:
My E2 L arrived today. A very nicely done light too. No, I am not going to change one thing on this one…. it stays stock as it came. I have some host I’ll play with however.
A very well done light Jaxman…… :+1:
Fit & finish is usual Jaxman quality, just about perfect.
As Dale said earlier, I to really like this rich Blue-Gray color. It is definately a great alternative the same old boring black.
Heck, it has all already been said. Thanks for another great light Jaxman!!
Hi, I didn’t buy the host but I bought a ready made and immediately tore it down and looked it over and personally I don’t see where that would be an issue,
You could probably find more answers at this other thread here, The other thread by Jaxman
The owner of this company has so many threads going I can’t remember which thread I was at last least of all where I commented about something, getting sort of confusing but I think that link is for folks who have built a host and what their results and opinions of the E2L are, or suggestions, I think, this is all over the place sort of… I don’t really think you’d have an issue frankly… Good Luck…
Dropped a couple of the new AA lights in the shopping cart at Jaxman, added the small C8 design and some cells. The site wants to ship separately, I’ve asked if he can package it all together and ship FedEx so I get it quicker. Waiting on a reply. I don’t really need the cells, might just add an Z1 and run with it.
Yes, the heat build-up is different in the E2L: the outside gets hot quicker because there is not a chunk of copper in there that soaks the first heat. But the heat spreading over the shell is faster than in an S2+, that compensates it a bit.
One of my E2L’s has 219C’s (sm405 R9050) and a BLF X5/X6 driver and draws 10A on highest setting. It can be run at that for half a minute with no problem, it just gets so hot after that that you will switch it to a lower setting. And that 2000lm for half a minute is a nice addition to all the lower modes that can be used continuously.
So if used like that, the heat transfer is fine: even at 10 amps I see no problem for the leds in the period before the shell gets so hot that you will automatically switch to a lower mode. Your time at turbo may be a little bit shorter than with a S2+ with copper spacer, what you get back is a flashlight that is a bit shorter and more lightweight.
Gunga, which light from Convoy comes with this deep carry clip you’re asking about? I only have a few Convoy tube lights, not sure if I have that specific clip, but will check and see. Everyone’s sleeping at the moment but that should change soon and I’ll go dig stuff out and see if it fits.
Will be back shortly…
Hey Gunga? The Convoy S2+ tailcap interchanges with the E2L tailcap and both lights work fine. The groove that exists between the tail cap and start of knurling is the same width but the grooves in the E2L tail cap are slightly narrower. So if there is a clip that attaches to the tail cap, I doubt it would cross over due to the narrower margin.
I have a blue S2+ but have no clue where the clip for it is. Thought I had more Convoy tube lights but the only other one I can locate is chopped with a short tube and TIR lens, no clip.
