The Nichia sw40 tint range is very wide, can range from ~3750K - ~4250K.
The sw40 bin covers 16 different Cree bins.
Here are some beamshots of different sw40s
I have the 4000K from clemence and it’s kinda yellow, not bad overall though.
EDIT: the 4000K from illumn.com are really nice, my favorite sw40, but they are 219B V1.
Yeah really nice tint, Henry from HDS uses these in his HCRI 200. He had mentioned that everyone of the LEDs he tested had passed his CRI testing unlike the previous Nichia batch he had used. :+1:
I will be able to check out my recent Nichia purchase from Clemence only when I return to the USA in a month, but have to agree the sw40 Nichias from Illum.com are hard to beat if you like Rose (with a whisper of magenta). The company (IS) had a lot to do with Nichia 219A Leds becoming popular ‘way back when’.
The one light I reflowed them into has become my standard EDC and ‘go to light’.
While keeping bin variations and photographic reproduction processes in mind, we remember temperature and tint are less than synonymous.
Tints can vary greatly while maintaining the same temperature.
Kelvin temperatures are based on the colors of heated metal, often overly simplified by illustrating the color range between yellow (sun) and blue (sky).
Using a color wheel as reference, red/magenta, and green/cyan vectors influence the tint to varying degrees, while allowing the color temperature in Kelvin terms to remain the same.
This illustration may be of some use.
By super-saturating the colors in the OP’s photo, it can be seen the beam on the right contains more blue and green (cyan), while the beam on the left seems more biased towards red and magenta, with a preponderance of yellow.
The better balance of RGB components in the Reylight Led produces a whiter, more neutral light, albeit comparatively cooler than the more yellow Led from Kaidomain.
Flowing your own, or having somebody reflow for you is the best bet after getting your LEDs from a known reel, from reliable dealers like IS and RMM.
Some brick and mortar businesses can be convinced to high-grade their stock for particular preferences.
When I measure tint hue shifts, I find that whatever Nichia 219 they put in the Reylight Pinapple (they claim 219C, but often when companies say that it’s really a 219B) is 4000K with zero tint shift to either magenta or green. Most other lights I have with Nichia 219 have a magenta shift (which is quite nice if you like that), and one has a green shift (yuck!).
So, I think you’re right that your Nichia 219C isn’t a pure white.
Tints of 219B are centered under the BBL (black body locus) line. Tints of 219C are centered right on the BBL line (so the tints of half of the LEDs are above it). Above the line means yellow/green tint, below it means red. The BBL line means “perfect tint-free white” (regardless of color temperature). Of course a 3000K will still be more reddish than one with 6000K.
There are also different Macadams Ellipse tint bins of the 219C. There is 3-step, 5-step and 7-step. It basically defines how far away from the BBL line the tint of an LED can be. 3-step is the best. It basically means the worst tint in this Bin is much closer to the BBL than the worst tint in the 5- or 7-step macadams ellipse.
If you look closely at the LED you can easily see if it’s a 219B oder 219C. The package looks different.
All 4000K 219C Ra9050 3 steps are naturally closer to yellow zone, and slim chance for rosy tint. With 7 steps the probability is higher either sides (super yellow or slightly rosy).
Stick with 219B sw45k if you really hate yellow tint. Even the 219B sw40 still can be slightly yellow.
Wow, you’re right. I had checked the Reylight awhile ago, and couldn’t detect any PWM, but I didn’t have my regular camera setup at the time. I just checked with my dSLR at 1/4000s, and it does have PWM, even on its maximum mode. I wonder why they’d use PWM on max? I guess because it also uses a 14500, that max on NiMH is an intentional step-down.
Does it still have PWM when using a 14500?
It’s something I don’t notice with my eye, but, now that I know it’s there…. arrrgh… must not try to see with my eye! It has such a nice pure tint otherwise.
I have to admit the tint of the Reylight is amazing.
since the Reylight is advertised as a 219c high CRI 4000k i was hoping for the same tint in my S2+ with KD’s high CRI 219c 4000k, which it obviously isn’t…
Yes, the 219C 4000K from WWEFANS / Reylight are cooler and less yellow than the KD ones.
I have yet to try Clemence’s 4000K ones.
His 3500K ones are very pleasant though.
