it also depends on the INSIDE of the tube
my L6 and S70 have an anodized inside of the tube, so even if the magnet slides to the side there is no short (so I do not have any securing measures taken and use the fact that whey are loose in swapping the cells top/bottom at every charging, when removing the cells I plac the magnet from the bottom to the top and then in the charger so when inserting them I have onl ye swapping way to put them in.
Thought this thread is a worthy spot to put this article in
Quality reporting I know as details are a bit lacking - it’s unclear the brand of headphone or cells used…however it may serve as a reminder to people to be careful even with battery powered headphones
I actually have that same question about airplanes. I’m going to Florida April 9th and I have a rather large ANKER power bank which looks like it uses multiple 18650 batteries. I’m wondering/hoping I can take it on the airplane…
I’d use it just to charge my tablet and my other familys phones or whatever they have
all fire-related problems that happen on airplanes will show up in the news, and the sources discussed.
That’s because aircraft fires are taken quite seriously. LMGTFY
Problems elsewhere, well, if someone happens to put it on YouTube we’ll know about it, otherwise maybe not.
For example, a while back, there were a lot of reports of vehicle fires in China attributed to li-ion batteries.
Then China cracked down on handling them and the stories disappeared from the news.
Thanks. I have the ANKER Powercore+ 26800 charger. I’m not sure how many Wh that is. Amazon answers said it can be brought on an airplane but I just wanted to double check
Thanks, I will print that out tomorrow when the stepdad isn’t home. Florida is a surprise to him. He thinks it’s just 4 people going, so I’ll do it while he is at work
Also you should check with the airline(s) you’re flying on and if they have a “FAQ” page with their details online, then print it out too. The airline folks will find that easier to reference should they have any concerns, and airlines themselves may have additional requirements not spelled out in the FAA or TSA regulations.
While this has been mostly worked out at this point I expect the future to bring more specific details including specifications regarding acceptable boxes and carriers for cells, and maybe even the devices Li batteries are installed in themselves. Right now a baggie meets the specs for being in plastic, yet we all know that the this thin plastic could easily be damaged in a bit of turbulence. We LiIon enthusiasts know better than to rely on a baggie, but the ‘average Joe’ doesn’t, nor do most airline employees. Considering the stakes involved I think it’s a situation which could be handled far better than is currently being done.
_
If we preach and teach Li safety where we can, we can reduce the number of problems occurring which benefits us directly_
SawNaster thanks for the tips. I will do that also. As far as what my battery is in, I still have it in the box it came in with the charger and everything including a little travel pouch that the battery sits in snugly. It’s cardboard box but it holds everything nice and tight. I knew about them phone batteries exploding in the note phones. Almost bought one until I seem that craziness on the news.
My uncle actually works for the airport we are using so I will talk with him about it also to make sure I have all of the correct information needed just in case, to be safe
It does say some stuff on the battery. I’ll try and post a picture if possible. How do I do that? It’s asking for a url. I can’t take one with my tablet or just use one from off of my computer and put it on here? Help please
