Convoy L2/L6 modding thread
Jason, I might overbuild something but rarely ever think enough to be accused of over-thinking. :wink:
I was cutting out the reflector like that on Courui D01’s (The Fathead) several years ago. But yeah, whatever it takes. Like Kawiboy I like to machine the emitter shelf to take a 26 or 32mm mcpcb in the L6, moving the contact pads much further out and making things easier. Or using the cut off tabs from a large Omten switch to move the connection outside the mcpcb and thus allow the extra room for the reflector by not having that wire there. Kapton tape is your friend. :slight_smile:
Question about Richard’s 30mm FET driver. Anyone know what kind of amp draw I could expect with a couple of good 26650’s in an L-6?
I don’t have any machine shop stuff. I cut my reflector bottom using an upside down router with the bit 1/8” up and slowly worked it around. It worked. Lol! :slight_smile:
And that’s what you do, you use what you have even if it takes a bit of creativity. When you succeed, it feels fantastic! The sense of accomplishment from doing something on sheer ingenuity makes you get addicted to the modding, and before you know it, you’re spending income tax return monies on a small lathe instead of something more frivolous. :smiley:
Well, it seems that We do have a L2/L6 AR glass update, the new one is better, better looking and the total candelas upped with like 4-5k( L2 host).
IT also adds more reddish in the tint thus made the L2 beam profile even better for outdoor/hunting
Good!
Update 2017-04-06
The short tube is finally available in the Convoy store. This tube will fit both the L2 and L6 and is meant for single 26650 builds, 2 cell 26350 builds and will probably fit 26700 cells though I can’t guarantee that. It is slightly longer than the older single cell tube to better accommodate more cell variations.
Purchase link here:
L2/L6 short tube
I’ve added this info and link to the OP as well.
Damn i was hoping it would fit the tactical ring…
Ah well cant have it all hehe :smiley:
Yeah, it was supposed to actually but that slipped through the cracks on this first run. :weary: If/when he does another run it will have the threaded rings.
Aha i understand!
Lets quickly emty his stash of short tubes then, so that he can get that next run done :smiley:
Well said! Buy them up people! :+1:
Ordered one single-cell tube right away when you posted it Jdub , thanks …!
Now i wish i had 2x 26350 to power Dale’s beast …
Has anyone modded their L6 to make the side switch slide out the hole?
A assumed there were 2 slots cut in the shelf the switch sits on or else the switch had 2 flat sides so that you could slide the switch out when replacing the driver.
Nope. I had the unsolder the leads. There is room for improvement here.
Why? Most people just use the light. I just pull the switch out and file 2 slots in the hole with a small rat tail file or just de-solder the switch, no big deal!
I’m gonna be running indicator lights onto the switch so I might have 3 or 4 wires from it. I can’t remember where all the wires go! Lol. I’m also trying out a lot of different drivers in it lately.
I was thinking of using a jigsaw or maybe a Dremel with small diameter wheel. I think I’ll get me a small file as well and add slots to the hole. Takes longer, but less metal shavings everywhere.
Yep I understand! :+1:
You’d be surprised how little has to be filed out when you key hole the switch hole! :smiley:
It’s very thin so it’s pretty fast!
Well, I somehow must have messed up my L6 driver trying to do a resistor mod. It has some flickering and can’t decide whether it wants to run in high or turbo. I never did get the resistor in. So before I order a stock replacement driver, should I consider other drivers? Not sure these shaky 63 yr old hands are cut out for teeny tiny part soldering. Or maybe get one and have someone else do the mod for me.
I have still 3 unreserved 30mm Texas Avenger LDO drivers with latest Narsil
Temperature protection at whatever you want
Thanks for the link. Trying to understand all the options vs output, probably very interested.
Use a magnifying glass and make sure the solder didn’t get on nearby components.
There is not too many choices for other drivers. There’s the Convoy version of FX30, there is the direct drive one that MTN sells, there’s the Texas Ace direct drive one that Lexel is making and then the stock FX30 that Kaidomain is selling. It’s a bit of an odd one, with 3 levels, standby and the same output as the Convoy version.
So if you want to turn it on/off from the rear switch you’d need the Convoy one or the TA one with it programmed to turn on at the rear switch.
If you want the rear switch to serve as lockout only and on/off from the side switch, them the Kaidomain, MTN or TA versions will work.
Thanks for the run down, especially w respect to rear switch. Do you know what kind of amps / lumens the DD from Mtn or TA run? Run time impacts?
