CRX Brass Nine Kubatan
This light is powered by two Efest 10440 cells driving an XHP50 J4 1A emitter on a 10mm Sinkpad directly soldered into a large copper pill and heatsink.
The casing is made from 14mm OD x 1mm thick solid brass tube with copper & steel internals, bezel and switch detail.
It has a forward clicky tail switch with red tritium vial installed, an aluminium reflector and 12mm x 1.6mm multi layer AR coated glass.
Single mode direct drive
XHP50 J4 1A
ARC glass
Soldered MCPCB & pill
Forward clicky tail switch
Length - 140mm
Width - 14mm
Weight - 104gm
Max 1800lm OTF
Very nice
Very nice! Creative work that pays off, gotta love it!
How’s the beam on it? Should be floody enough with the small reflector to pretty much eliminate the dark center…
You’re really doing some awesome work these days Man! Keep it up! :wink:
Thanks mate
Thanks very much, yeah it’s fairly floody but the reflector is also quite deep for it’s size.
There is just a slight hint of the crosshair in the beam, It sure heats up fast :laughing:
Man, you are nuts! These builds are amazing and I love seeing each one appear.
So cool you achieve builds that are outrageous in components AND look like made by a jeweler.
Amazing
That QTC switch is really cool and great implementation. Looking forward to measurements.
Sir, I’m in awe of your inspired builds. Every time I see a new CRX build post I get excited. Keep up the fantastic work and thank you for sharing these elegant designs with us mere mortals!
Ok. I know what it is now. Not to shabby. I thought the Brass looked thin in the what did you mod today thread and it is. :+1:
Another nice one, CRX! I think a XHP-35 with 4x 10180 in a light like this would be nice, too! :wink:
There’s an idea… :wink:
