Close call - battery meltdown out of the clear blue
That shape at the left end of the cell often indicates a PCB which is the protection circuit.
It probably doesn’t have an actual protection circuit, but clearly something is there.
I’m glad this turned out with a good ending Zebretta. :+1: … :slight_smile:
And I am sure you know it by now….
………….but everything anyone needs to know about these batteries are contained in the picture you took.
The name & the mAh rating……… :wink:
CrapFires” are just that……… crap. And no 18650 battery has that mAh rating… that is crap too. :slight_smile:
About the only thing I know of with “Fire” in the name that can be trusted is “WindyFire” & I can only speak of their 14500 Red ones. Cause that is the only ones of those I have.
Glad you are ok.That is the most important thing. :+1:
I think we all know this and most would agree w/ this but I will repeat it!
The odds of that happening w/ a QUALITY battery[Samsung/Sanyo/LF/Sony/Panasonic] are a lot less.
I wouldn’t use a “Pick ur Fire” battery if you paid me or gave me ones for free!
The Only “fire” I used is Windyfire IMR 14500 That HKJ reviewed.Besides the aforementioned, I never used a Surefire but that would be the only other “Fire” that is a quality battery.
I still can not comprehend why someone would use these batteries just to save a few dollars when the performance is sub par and the risks of an accident increase. :person_facepalming:
The only fire batteries I trust is thorfire. The 5000mah 26650 tested out good. Good to about 10amps before major sag.
And from people on here unwrapping the 18650s they are a Samsung rewrap.
I’ve heard windyfire mentioned before but don’t have any experience with them
Its already in the ‘brand’ name FIRE
Be warned to keep away from that brands cells.
Battery safety 101
… I think I’m going to fully discharge all my Cytac (unknown cell) 2400 mAh and ditch them… Sticking with Panasonic, Samsung and Sanyo only…
In the end at least you were there to notice the smell and move it. It maybe have been a old grade c rewrap. It didn’t go into thermal runaway. Which newer name brand cells won’t do until about 450 degrees. Did it vent is there any residue by the top. I mean visually don’t touch if there’s residue I imagine is highly toxic
Edit,
Wanted to add if this was a protected cell it would have done the same thing because a protection circuit isn’t going to be able to stop a internally caused short. If its in a flashlight or charger its going between the circuits and the PCB can trip and cut the current. So don’t get a false security about protected cells. Just make sure the underlying cell is a name brand cell
I still have 4 X 18650 Cytac cells. HKJ reviewed them. Although the cell is Unknown he stated it acts just like a Panasonic and rated it a very good cell.
HKJ:These batteries uses a undisclosed cell, that works exactly like a Panasonic cell, i.e. it is very good.
I,Wolfdog1226 have no worries about them!
Interesting and cautionary.
I found this
I’d guess that most Li-ion cells sold are put in laptop computers or power tools, and I haven’t noticed stories of power tools burning houses down. Vape devices are almost certainly a bigger market than flashlights.
Very small I’d say, or we’d hear a lot more about it, (considering laptops and power tools) but if you are the one in ten thousand per year (or whatever) and it’s burned down your place, that’s not much comfort.
I’d guess that a part of this is that laptops and power tools use new cells and have protection circuitry, whereas *fire 10,000 mAh 18650 cells are clapped out, recovered rubbish. I think a part of that is that considering most users of flashlights, you can get away with palming off an originally 2,500 mAh, now 750 mAh cell, as OK, but that wouldn’t fly with vape devices, laptops or power tools.
The thing I find worrying was that it was just sitting there and decided to go off. You weren’t charging it or using it.
Actually this is a point of interest. HKJ tests performance of cells, but what do we know about how safe these cells are? For example, if we look at the 30Q’s datasheet: https://www.nkon.nl/sk/k/30q.pdf
On pages 14-16 test results are shown for short circuit test, high temperature (140 degrees C) test, and impact test. And what do we know about the differences between a branded cell and an unbranded cell if you drop them on concrete? Of course don’t drop them in the first place, but is the branded cell safer in that respect?
So you see, since I don’t know the answer to these questions, at this moment I prefer to play it safe and stick with branded cells when possible.
I agree to use the Top 5 manufacturers as I mentioned in my first post in this thread.
As far as these Cytacs go I have had them 3 years,…like I said I have no worries about them.It probably is a Panasonic cell or at least One that is of good quality like a Panny cell!
P.S. You did not include part of my post where I mentioned what HKJ said and you also left out his quote!!!
Here it is again!
Yoiks…
Gotta say, the way that battery’s bulging, this is begging for a yootoob video of someone with a .50BMG putting a big big hole right through it to see what happens.
The number of people who don’t know better VASTLY outnumbers those who do. That’s why so many are sold on ebay. I really didn’t know better until I came to these forums and started reading. It’s surprising there aren’t a lot more incidents. This really caught me by surprise. I hadn’t charged the battery, discharged it or anything recently…it was just sitting there and decided to go thermal all by itself. Scary is a good term.
I’m a believer now in taking extra precautions.
Yes correct, I should elaborate! Well the thing is that you have performance as in voltage sag, and the max amount of current you can run, and the max temperature it reaches. These parameters form the performance of the cell I think. And this is what HKJ tests.
I’m not too sure whether he means that a Panasonic cell is used in the Cytac, or whether the performance as described above is similar to a Panasonic. If the latter is the case, then I become weary regarding safety parameters as mentioned in my previous post. So basically, the question is what HKJ means with “that works exactly like a Panasonic cell”. Is my reply ok?
THIS.
I’ve never had it happen so I find this a bit disturbing too. It could happen while sleeping. And that FHL thing mentioned above…wow.
But….it’s not the first time I’ve ever smelled a burning odor and never found anything. Now I wonder if that could possibly have been a battery self terminating but didn’t go nuclear?
That’s why I keep so few cells around. Think I only got 4 LK 26650s, a pair of protected panny-Bs, 8 30Qs, and a bunch of pulls from otherwise good power packs. Keeping more around is just like keeping gallon jugs of gasoline “just in case”. Probably won’t go boom, but why up the odds by keeping more than you need?
If anything, I probably got way more of those power-packs than I need, too. Buncha “lipstick” ones, up to those 10AH donks the size of a fat wallet.
By the time I wear out any of those cells…
No your reply is not ok!!! Your Sarcasm was weak! lol! :wink:
It is CLEAR what he said. The cell is Undisclosed and works exactly like a Panasonic cell.
The whole point of my original post is that HKJ feels it is a very good cell and in addition it has served me well.
I would be a LOT more concerned about a Trustfire/Ultrafire ect. than a Cytac cell.
We can analyze things forever,if your not comfortable with it ,fine,toss them….I am comfortable with them so lets leave it at that!
No sarcasm intended from my side. Yes it is clear what he said. But it looks like you are not understanding my point then. There are more variables than what HKJ tests.
Wait…you mean I could go to sleep with my trusty 26650 flashlight beside the bed….and if it gassed out overnight….wake up (or not) on death row the next morning due to these HFA gasses? :open_mouth:
I have some 300 Li-ion cells. About 100 lights with cells in them, on stand-by and something like 70 cells in reserve, 50+ in a 12Ga. Shotshell case and more in a clear container beside the bed.
I’ve been up to about 170 flashlights before I sold some off back in the Winter. Mostly been hot-rodding the snot out of flashlights for about 4 years. Haven’t built an underground bunker battery storage facility just yet…
