Texas_Ace integrating PVC sphere with no math involved
57 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 2 days 12 hours ago
djozz wrote:
Texas_Ace wrote:
The styrofoam versions work great for low powered lights but once you get to ~1000 lumens or so they start to divagate due to so much light making it through the foam.
This is not true, loss of integration from light loss through the wall is with the average wall thickness of styrofoam balls (over here 2cm) negligable, and is completely independent of the light power of the measured source. The limit of my integrating spheres are solely determined by the range of the luxmeter that is used, which can be extended to wish by either a neutral density filter or the use of a satellite sphere. My most used sphere measures up to 15,000 lumen, if I need to measure higher, a small adaptation can extend that range.
Is the bad availability of suitable styrofoam balls the only reason for people to not build integrating spheres? (which despite the love of flashoholics for tube-systems are according to all literature of light measuring and measurements in practical use the way to go for good integrated light flux measuring). It is not that it is difficult, via my sigline people will find 4 IS build threads, of which one is simpler, cheaper, faster to build, and better integrating than any tube-system that is in use by CPF and BLF members.
I don’t know what your sphere consists of but I know that the JoshK sphere that I have will deviate by 5% or 10% (forgot which, been a year since I messed with it) per 1000 lumens due to losses.
So basically I have to adjust the multiplier by adding an additional 5-10% per 1000 lumens as the lumens go up in order to get an accurate result.
I tested this by testing three S2+‘s separately and then putting them all together and taking a reading and the readings did not match up like they should. I used a few other lights in the same way with the same results. I also compared it to my PVC sphere. The PCV did not deviate to a statistically significant extent where the foam ball did.
I ran these tests due to over time the readings I was getting on high output lights was just not adding up compared to the low output.
All of the data is posted in the joshK thread.
I was 100% in favor of the sphere when I started all of this, which is why I was so excited to get the josh sphere and give it a try. The move away from it was not easy and only happened because I got significantly better and more consistent results on the PVC sphere.
I have positively nothing to prove in this case, I would love a proper sphere but the cost to build one would be way too much to justify the result based on my experiences so far. It would also be a lot of work as it would need to be coated with something to keep the light from making it through the foam.
Which is a point, light makes it through the foam super easy, even moon can be seen just making it glow in a dark room. It is quite possible that denser foam would not have this issue.
djozz
djozz's picture
Last seen: 47 sec ago
Measuring light has little to do with light loss but all with keeping the loss constant, the fact that a small fraction (in the order of a few %) of the light goes through the wall of the styrofoam is of no concern for either integration or accuracy.
About Joshk’s spheres:
I stopped reading and posting in Joshk’s thread after he refused to take on any advice from me (two years of building spheres and numerous tests on the performance), and was being rude to Texlite who was giving very good input at the time. Then he went completely his own way with some clear misconceptions about measuring light and produced and sold a number of spheres without any proper test data on their performance.
He would not even know what kind of tests to perform, not even sure if he really understands what light integration is. Which is all perfectly alright but not if you are into integration sphere making and distributing.
Not having followed his thread any further I would not know why his spheres do not perform, it is certainly not the concept of the integrating sphere, which has been proven worldwide by every light lab.
djozz
djozz's picture
Just measured two flashlights (that I know have a good constant output) in my integrating sphere, first separately, then together next to each other in the entrance hole. I did not correct for entrance hole effects on the multiplier (but that effect is limited in my large sphere)
First light: 71 lumen
Second light: 115 lumen
Together: 185 lumen
Texas_Ace
Texas_Ace's picture
For the record I never doubted your sphere works or that the sphere design works better.
I doubt that cheap spheres using cheap styrofoam balls work better then a PVC setup like I have now.
The only thing with the josh sphere I could not isolate and test was the sphere itself, which is why I came to, and still hold, the conclusion that the foam sphere itself is the cause of the non-linear readings.
With a better and/or coated sphere I have no doubt it would be superior. The question is, at what cost?
I am very much a results minded guy. I am not overly worried about how the results are achieved, as long as they are the desired results.
djozz
djozz's picture
Thing is that we try to achieve some accuracy (don’t we all?), but we are actually pretty satisfied with a ballpark figure. So if our numbers are not consistent or match up, we just call it a day. And why not?
Btw, in integrating sphere making (and measuring light in general) I found that achieving a good performance has little to do with costs, it has to do with having your theory in order, thinking a lot about how to avoid possible errors, and testing, testing, testing.
Solving an error can be as cheap as taking a piece of sandpaper and carefully sand the inside of a sphere to a nice matt finish (just an example).
ImA4Wheelr
Last seen: 6 months 5 days ago
I'm guessing most folks would prefer a proper sphere. Whenever I have read a build thread on one, I would get a bit intimidated.  Not so much by the physical building, but by understanding what is going on in one.  I've always trusted djozz and others that take measuring light seriously, but it's difficult for me to picture in my mind how a sphere can measure both extremes in beam profiles accurately.  Couple that with having to purchase or construct a large rigid structure, the barrier to entry was just to high.
I did, though, already have adequately sized PVC parts on hand.  With those, I tried my hand at it years ago, but didn't like the fiddly, inconsistent results.  I pretty much wrote it off until this thread was created.  Someday, I would like a proper sphere that is big enough to measure my big lights.  It may have to do double duty as a table top stand or something to overcome the SAF though.
Texas_Ace
Texas_Ace's picture
I would agree, it took dozens if not hundreds of hours worth of testing to get my sphere where it is now. It is now consistent enough that I will at least post the numbers although I still have no idea exactly how accurate it is, I just know it is in the ballpark.
cclight
Last seen: 15 hours 3 min ago
I appreciate the heroic efforts to measure total light flux as reliably as possible. However
only total lumens and OTF lux are insufficient to characterize the beam.
I think it’d be better to measure “intensity” (in the photometric definition), as a function of angle instead of only along the flashlight axis. If we had a table of candela X angle we’d have a much more complete picture of the beam and could answer questions like how big/intense is the hotspot, how much spill or corona there is, etc. This is unusual because it’s too much for the general public but for this community it’d be very useful and it seems that measuring lux reliably is a lot easier than total emission.
In principle we need measurements in the whole plane but almost all flashlights have a beam with cylindrical symmetry so readings along a single line are enough. It can be along a circle or a perperdicular to axis.
If we know the distance to the flashlight we can also easily integrate and determine total lumens emitted in the measured angular range, and going far enough even total lumens. This way we wouldn’t even need an integrating sphere and if we have such measurements we can compare with the angular result.
These readings take some time, so it’s better to do them at low/mid levels to avoid output drop. Since the beam profile won’t change with intensity level, doing 1 or 2 readings at max is enough to scale the complete graph.
Flintrock
Last seen: 3 years 2 weeks ago
Didn't follow everything but I have to 100% agree with djozz that the performance of any sphere/box, whatever, has nothing to do with the brightness of light.  Any two photons on the same path act the same and have the same chances of getting through regardless of how many other photons there are around it.  If something is non-linear, it's the meter, not the box (or maybe light leaking in from other sources skewing the low-end results?).
Texas_Ace
Texas_Ace's picture
While that is all well and good, 2 seconds to take a lumen reading > doing math.
Put simply we are messing with flashlights, the actual light output simply doesn’t matter. It is purely for comparison purposes on the internet and bragging. All that matters is that it lights up what you want it to light up.
There is no need for anything more then a basic light box / sphere setup in the flashlight modding world.
In an engineering world, sure more accurate numbers can be important but even then I would rather spend that time and money on simply overbuilding the setup instead of trying to plan everything out perfectly on paper.
To each their own. As long as the end result is good, that is all I care about.
Texas_Ace
Texas_Ace's picture
Flintrock wrote:
Didn’t follow everything but I have to 100% agree with djozz that the performance of any sphere/box, whatever, has nothing to do with the brightness of light.  Any two photons on the same path act the same and have the same chances of getting through regardless of how many other photons there are around it.  If something is non-linear, it’s the meter, not the box (or maybe light leaking in from other sources skewing the low-end results?).
I thought this same thing, which is why it took me so long to track down the issue.
I still can’t fully explain it but I know for 100% sure it is not the meter or any other aspect of the sphere except for the sphere itself.
I tried 3 separate meters on the sphere, they all read the same with a deviation as lumens increased.
I tried the same 3 meters on my PVC setup, they all read the same with no statistically significant deviation regardless of lumen output.
light leaking in is also not an issue as the sphere is contained inside a box plus the light in the room is nothing compared to a 5000+ lumen blast from a flashlight. Plus that would cause the readings to go up, not down.
The readings do deviate, the sphere itself is the only thing left that it could be as I have tested everything else in the PVC sphere. I still do not understand why or how it is happening, only that it is.
Flintrock
About the only thing I can see as remotely possible is if the light is heating the surface and this affects its reflectivity.      I guess it goes in that category of mysteries along with many other things.
cclight
I agree that to see mod results made by the same person it’s enough but my post aims a more general situation. First, we’d have more info on the beam. Second, reliable measurements are important to compare different flashlights, measured by different people.
Texas_Ace
Texas_Ace's picture
Like I said, to each their own.
Such measurements would be meaningless to anyone that was not intimately familiar with flashlights and those that are do not need such info as they generally can get all they need to know from a beam shot and basic numbers such as lumens and kcd.
Such a setup would be more precise, I just don’t see the need for such precision.
gastonpatagonico
Last seen: 3 weeks 4 days ago
Hello TA, first I want to thank you for sharing your work, a while ago watching this post, I like the idea of building a spherical pvc like yours (excuse my English I use a translator), therefore I acquired a luxmeter there, I could Tell me what is the centering disc input diameter? I have available pvc pipe 4 “and what is the material that looks like foam? I have a friend who has milling machines, so I do not think it is difficult to center, well I do not bother you anymore, greetings !!
https://es.aliexpress.com/item/TASI-TA8133-200-000Lux-Digital-LCD-backlight-Pocket-Light-Meter-tachometer-luxmeter-Lux-FC-Measure-Tester/32625335050.html?spm=2114.10010408.1000016.1.l0Xr49&isOrigTitle=true
Texas_Ace
Texas_Ace's picture
I used a 3” PVC pipe myself but as far as the centering rings for the flashlights the outside lip it just slightly larger then the outside of the PVC pipe so that it has a snug fit. It is easier to measure your pipe to get the exact measurement, I don’t know if the pipe where you are has the same dimensions as in the US.
The foam is exactly that, styrofoam. It was sold oridgnally to stick the stems of fake flowers inside of a pot to keep them standing up.
Although honestly lots of things could work, a diffuser film like DC-Fix should work as well, possibly better. Or really anything that fits in the area and diffuses the light.
I doubt you would need a milling machine for this but it would work if you have it, although a lathe might work better since all of the parts are round.
My centering discs are 3D printed plastic if you have access to a 3D printer. Otherwise you could simply use cardboard and cut the hole manually.
gastonpatagonico
Hi, thanks for your prompt response, then have several disc centered according to the head diameter flashlight? My friend has both machines, lathe and milling machine, well at one time publish my copy of your device, greetings and thanks again!
nkresho
nkresho's picture
Last seen: 2 weeks 6 days ago
Bumping this thread back to life.
I copied the design almost completely. I even ordered the same meter.
Changes i made:
  • Sanded the inside of the pipes with 400 grit to a matte finish
  • Don’t have a 3d printer, so i cut some chinese food container lids and used 3m adhesive to stick aluminum foil to the inside
  • Instead of foam, i cut a disc of acrylic to fit inside the opening, then applied two layers of white contact paper. A third brought the numbers too low. Now, they’re a tad high. I think i’ll hit the backside of the acrylic with some 2000 grit to see how close i can get.
  • I’m calibrating with a few well-tested lights, and going for the expected outputs. An olight m2r warrior and a nitecore p12. I’m hoping to zero in on the expected lumen outputs and call it good.
Thank you, OP, for the detailed info and the motivation.
Texas_Ace
Texas_Ace's picture
Glad to hear someone is finding it useful.
Remember this is still a DIY sphere. I would not expect better then ~10% accuracy at the very best. Consistency is the most important thing with a standard calibrated device. Mine still reads the same (minus 3 lumens, which I expect is due to dust) 1.5 years later. So I am happy with the results.
Agro
Agro's picture
Last seen: 2 min 37 sec ago
What’s the difference between hs1010 and hs1010a?
Texas_Ace
Texas_Ace's picture
Not a clue., I just got 2x of the cheap ones on ebay. Think they are the A models.
nkresho
nkresho's picture
Here’s my sphere bleeding a bit of light with the q8.
Integrating sphere light bleed
Finally figured out how to post pics here. Evil
Lower lumen lights are spot on, but as they go higher, results are lower than expected.
This specific light has 4 freshly charged 30q. The bottom pcb was replaced by a copper plate with 20ga turnigy bypasses and heavy springs. No tailcap loop for amperage (sorry). Highest this light has made was 5970 lumens in my sphere.
Even worse, was my L6 with MTN driver and 70.2. That light pulled 20.67a with liitokala blacks and only showed 8020 lumens in the same sphere. That light made a similar glow in the PVC.
I ordered a bottle of barium sulfate and will test later with that painted inside the sphere to see if I can decrease the bleed. I read an article that compared a few different ratios of paint to BaSO4, and i’ll likely use 20% or more powder to paint if it doesn’t turn into paste. I was intrigued by this article and plan on painting it with ratio of paint: https://www.triticeaecap.org/wp-content/uploads/2011/12/Barium_Sulfate.pdf
I really don’t want to have to use any type of multiplier if I can help it.
I have a few lights coming that I will test in my sphere and compare to TA’s numbers in his. I’ll post results.
Texas_Ace
Texas_Ace's picture
Hmm, I just checked my sphere with the lights off and noticed that it does bleed some as well, I never noticed before since I always have my work lights on at the desk.
I actually have had some new ideas for this sphere design that should be even better but also a little more expensive.
Does anyone know of a cheap diffusing film/plastic? I am thinking about using a clearish diffuser could improve the consistency.
How are you calibrating the sphere? What kind of examples do you have in the low modes?
nkresho
nkresho's picture
I’ll test on some low modes and add to my growing spreadsheet.
Here’s so far: https://docs.google.com/spreadsheets/d/1IbqSD4ovvGC_1MDzzlFbKf8t38Q8j1wk...
JasonWW
JasonWW's picture
Last seen: 1 hour 8 min ago
I was thinking about this myself. We need something that can completely eliminate the beam shape going into the measuring device. You don’t want a skinny beam (thrower) to read any differently than a wide beam (flooder). We need something to neutralize the beam shape and do it better than tissue paper or foam discs.
I believe that’s the point of using a dome shaped ball like a true integrating sphere, but with pvc tubing, we lose that effect and need to compensate.
One other issue I want to work on is sealing a flashlight to the measuring device.
I have a question for those that are experienced. How important is it to have the light source, the actual emitter, on the same exact plane when measuring the lumens?
Obviously a deep reflector like on the GT will push the emitter farther away from the measuring device compared to say a MF01 which has many little emitters less than an inch from the lens. Does this difference in depth effect the readings?
If so, should we make a flashlight mount that has an adjustable depth to it so we can keep the emitters of all our flashlights on the same plane?
Texas_Ace
Texas_Ace's picture
Yeah, the best idea I have so far is using the diffusing panels from the florescent fixtures you can get at home depot, a few stacked together should remove all beam pattern from the beam. Although I know a better option has to exist.
The sealing of the light to teh sphere is very important, I use a bunch of 3D printed rings to seal to various lights myself. When they do not seal properly there is a noticable drop in lumens.
The emitter distance is not that important but the black of the light entering the tube can also have a very noticable effect by absorbing lumens. You want the very end of the light inside and that is it.
