You are invited to Gearbest Epic Lights Sales, and we improved” the subpage”:http://www.gearbest.com/m-promotion-active-282.html for coupon copy usage, have your click here, hope you will like these outdoor & survival gears.
The spring wakes us, Deals come frequently and regularly.
Light up Spring, Bright Make over Ideas: http://www.gearbest.com/promotion-world-of-light-special-1069.html
We here to introduce about 76 Deals in such Lights collection subpage:
indoor lights, Bulbs, Strips,Smart Lighting, outdoor lighting Gears,
Laser pointer, Stage lighting, Wall lights and Pendent lights.
Check and find some different than ever before.
Can you please have a look at my ticket T17033106379.
I bought a Brother 1602 (item 208237501) and the knife I received is defective from the factory.
The knife has no detente at all and therefore has nothing holding the blade in place when in the closed position.
This makes the knife unusable and actually dangerous.
I disassembled it to see what was wrong and the detente hole was drilled too wide so the detente ball sit at the bottom of the lock bar instead of being raised and doing its job of keeping the blade secure in the closed position.
I opened a ticket and provided the video and photo below and after a whole 2 weeks, your customer service determined that there is nothing wrong with the knife and are offering 50 GB points which is unacceptable!
Can you please look into this and get a replacement of a knife that is not defective sent to me asap?
Wow, that’s ridiculous! What a horrible customer service. I certainly won’t be purchasing from Gearbest until I hear they’re fixed your issue.
Best of luck
Sounds like standard procedure going on (same with Banggood). What seems to work is to stay calm, explain them that you cannot accept their offer. Explain the same thing over again: knife is (too) dangerous to use, and product is not as described or should be etc. It may take some back and forth messaging. I’ve read about these cases regularly, so hopefully you’ll be successful. Good luck.
Thanks guys for the support.
TBH, the only reason I still shop at GB is because of gearbest here on the forum.
I have had a couple of issues last here and the member here made it right both time. We’ll see this time.
But yeah, their regular CS is pretty lame.
@bdpf79, sorry to hear that, we got your ticket number and arranged your order to service center minutes ago, check your email or inbox minutes later, please.
Packing List:
● 1 x Arduino UNO 2012
● 3 x LED (transparent) red
● 3 x LED (transparent) yellow
● 3 x LED (transparent) blue
● 5 x 1k resistor
● 5 x 10k resistor
● 8 x 220r resistance
● 1 x big bread plate
● 1 x Three color plug-in
● 4 x Small key package small
● 1 x Active buzzer components
● 2 x Passive buzzer components
● 1 x Receiving head package receiving elements
● 1 x Fire element
● 1 x LM35 element
● 2 x Ball bearing components
● 3 x Photosensitive resistance element
● 1 x 74HC595
● 1 x Section 6V battery box
● 1 x USB line
● 1 x 8 x 8 dot matrix
● 1 x Digital tube
● 1 x One of four digital tube
● 1 x Article 30 / 1 the bread line
● 1 x Remote control
@gearbest
Thanks for looking into that.
Here’s the reply that I got from your CS
“As we empathize with your situation, after consulting with our supervisor, we can exceptionally offer you a partial refund 4 on your wallet (store credit) and exceptionally reward you with extra points (e.g. If your refund is USD 1=2 points, USD 3=3*2 points=>get 6 points etc).”
I am not interested in a partial refund and GB points!
What I want is a knife that is not defective, so please send a replacement.
No.
There is a detente hole on the lock bar that is drilled a bit smaller than the detente ball.
Then the detente ball gets press fitted into the hole with usually half of the detente ball or so sticking out.
The half sticking out then fits into the hole on the blade when the knife is in the closed position.
That’s what hold the blade inside the handle when the knife is closed and prevents the blade from opening any time.
In this case, hole too wide -> detente at the bottom of the lock bar -> nothing sticks out -> noting holds the blade when the knife is closed -> blade can just open at any time when in the pocket -> cut
Also, this is a flipper, so it’s supposed to flip.
Without detente, it can’t.
@bdpf79, please check your package box to see if there is another accessory left alone. And please do let me know the result via PM. We are positive to help you, always, when confirme to send you another replacement, we will double check it to make sure it is sound for you. Thank you for your sharing, and there’s a warm thing, before you post your video to the public, please give us a first chance to check problems about the item for you, P.S. we check Gearbest BLF official inbox every 2 hours.
As for giving you a chance before posting in public, I did that.
I opened my ticket on March 31st, explained my problem and made it very clear that the knife was defective and I would only accept a replacement or full refund if the knife was not available.
I was asked to submit proof, which I did with the video and photos on April 1st.
The problem is that your CS is useless, it took them 2 weeks to respond to my ticket (after I sent them 3 or 4 reminders btw), and then said there was noting wrong with the knife and offered 50 points when it is clear that the knife is defective. That’s when I came here to see if you could help.
You don’t want thing like this to be posted in public, it’s simple, improve your CS and offer the correct solution in a timely manner instead of being snicky and try to get away with things like this. As a company, it is not worth it.
Anyway, posting here seemed to help as they agreed to ship a replacement.
I will post an update once I receive it.
Hi, really sorry for your suffering on our site, when I got your ticket, I turned to CS directly for proper solution. Hope the problem has been solved, if not, please do let me know. Next time whenever you encounter with any difficulties, do not get help from service center within 24 hours, please PM me for instant help Dear, you know, I will check the inbox every 2 hours I can find CS in work for you quicky.
Hi, I heard about Sony US18650VTC5A, 25amp 2600mAh Battery. After making a market survey, we can decide whether we list it or not. The truth is not anytime soon, you know, it has lots of restrictions, we need much more time to test reports and other confirmation. Anyway, thank you for your kind advice, nice weekends, Dear.
