Meanwhile, I measured the led current (with the modified driver) , and got only 3.2A. In this case, the driver efficiency is somewhere 72%. But something wrong with this, because I tried out the reflector with an another led which was powered directly from a lab power supply, and around 4A got the same 53000cd. That's interesting, maybe the DMM self resistance, or the PWM output ditsurbed the measurment.
...and I did a new modification. Now, if I turn off the light and wait about 5sec and turn on, it will start in Hi mode in any case.
You can play the value of the resistor. I used a 30kohm, but if you put a higher resistance, for example 100kohm, the time will increase to about 10sec.
This is how mine behaved stock (might have been a few seconds longer than 5).
But I !@#%@#^!@#$%^ cooked my driver yesterday. Not exactly sure how, probably too much heat from soldering gun (small iron is broken and stupidly used 140W automotive one).
Hearing that it was inefficient makes me feel just a bit better about it.
I'm starting to realize why you guys joke about the xxxfire lottery. There is one small imperfection in my reflector, but otherwise, no build quality issues with mine.
I ordered the sst-50 driver on Dec. 8th. They shipped it Jan 8th.
Anyway, it won't fit the pill, or at least it will require a serious mod. I will do it if I can't find one that fits. I want at least 4A but not more than 4.5. The light will just be used for 'wow' and brief long distance searching, otherwise I would consider that a big waste of battery capacity.
I've ordered this for testing. http://kaidomain.com/product/details.S009442
aqualab driver db says a user reported 3.3A but doesn't sound like it was heatsinked. KD says 5A.
So far I have resisted stripping the ano but if I like what I end up with I will strip it. I've done some informal experimenting w/ bare and anodized aluminum and a torch. I think ano holds in a lot of heat. Flaw in my experiment...measuring by touch - it might not make much difference w/ air as the sink.
Truthfully though, I just don't like it much. Give me silver, black, a color, and in shiny or matte, but this is just kind of weird...
Sorry Chicago-X, I'd been watching price on every version of this torch for awhile:) The manafont one looks pretty good.
If this ends up an (exceptional) performer I might buy this one.
dx sku 13619 (59mm mentioned above) and 13569, 66mm
much more dome and much less edge on 66mm
it also has a shorter focal length than the other, and does make a good image of emitter, albeit w/ a substantial corona.
the focal length is so close to d1 emitter distance when placed on directly on reflector that I would have to rig some kind of holder (so as not to use reflector) to determine the exact best distance.
But, it is unfortunately significantly too wide. You would have to remove more of the dome than viffer did here https://budgetlightforum.com/t/-/5182#comment-98081
I get 2x the lux w/ just the reflector than w/ both (visually and on meter), and although the beam would look better, I can't see how not using the reflector would increase reading (w/ only lens).
But, I will eventually find a host for this lens - it should be very impressive.
avoid the 59mm sku 13619, this is my second sample and both make multiple scattered emitter images at focal length. maybe Ok for just tightening a beam, but not full throw.
don't force, tighten the pill too strong, because you could break the ceramic pad of the led, beside that, if you haven't lucky you could short circuit the driver
here is mine
you see the lower part of the emitter, nevertheless I don't want to replace, it works perfecly
Yeah, same characteristic as hs-802, but not so aggressive.
HS-802 reflector with xr-e isn't so good with unusable tight spot, but with xm-l much better. I like its beam profile, a very strong spill with a strong spot. Here are some comparison pics with difference shutter speed:
Received manafont driver (linked above) from Chicago X today - thanks!. Excellent packaging and quick shipping, hooray!
The base can be trimmed to fit the pill. The vertical board can be very minimally trimmed to an interference fit.
The coil (transformer?) is an obstacle. The pill must be bored ~1/8" and still the coil has to be pushed down and toward the center. I'm taking a break from that to keep from getting hasty.
Height might be an issue. It is so close that I can't say for sure until I'm done boring.
I'll probably have to plastidip the board/coil to ensure it doesn't short to the pill.
