Zelda
(Zelda)
April 14, 2017, 2:02pm
1
I’m use a Qlite 8 x 7135 105C Driver with a single 3.7v cell in a short convoy s2+ body.
When I try to switch it on, it happend nothing.
With the second click, it goes on an I can toggle through the modes.
Pic of the driver:
It started after two month of regular use.
Any idea how it can be fixed?
I would try to determine if it’s a switch problem or not. Does it light up if you take the tail cap off and use a wire to connect the end of the battery to the battery tube?
Wildcat
(Wildcat)
April 14, 2017, 7:33pm
3
It is normal for all Convoy drivers.
I read it to be that the first click from off doesn’t turn the light on, which is not normal at all.
Zelda
(Zelda)
April 14, 2017, 9:56pm
5
I changed the switch, now its working on the first click.
Thank you :+1:
