Got my JAXMAN E2L host in the mail yesterday. Very nice light! I like the integrated LED shelf like on the bigger convoy lights. Threads are top notch as well.
Do be careful to read the build notes Richard put on his website though. I had to drill out the center hole a bit (I used a #27 drill), and had to file down the noctigon board quite a bit in order to get it to drop in. Once all that was done though the light fits together great. I also bypassed the tail spring with some copper braid.
Unfortunately I forgot I needed thermal paste so will have to get some of that this afternoon before I can power it on.
Just got my 17mm Qlite Guppydrv firmware driver, and soldering braid yesterday. Thanks for the ultra fast service Richard, it got to me in 2 days. Got it installed and what a difference it makes over the standard 6*7135 convoy driver, its almost like a night and day difference in brightness.
just put together all the P60 parts i received last week. For some reason this one is super bright! XP-L HI v3 3c quad with bistro. Draws 18A at the tail with VTC6!
I have multiple XPL HI quads and the most I got is from a Convoy M2 with the same driver/LEDS…12A. This is one hell of a hot rod! But why is this one so much brighter?!?
Probably less resistance through the host, and possibly lower vF on that batch of LEDs.
Out of caution, however, I would want to make sure that the LEDs are getting proper heatsinking---does the amp draw rise significantly after turn on? That is a bigger variance than I would normally expect.
Thanks! It is really hard for me to find the time to make videos, etc., but I'm trying to get better about it and set some time apart each week to work on it. Unfortunately it is usually late at night when I'm pretty tired. Can you tell?
I was thinking about putting one of your light bars on my Drag Bike, you know for those Lights out, night time Grudge matches, but then adding another battery would add too much weight!
But I did buy a new truck ! I thought it was a great video Richard!
