Probably less resistance through the host, and possibly lower vF on that batch of LEDs.
Out of caution, however, I would want to make sure that the LEDs are getting proper heatsinking---does the amp draw rise significantly after turn on? That is a bigger variance than I would normally expect.
Thanks! It is really hard for me to find the time to make videos, etc., but I'm trying to get better about it and set some time apart each week to work on it. Unfortunately it is usually late at night when I'm pretty tired. Can you tell?
I was thinking about putting one of your light bars on my Drag Bike, you know for those Lights out, night time Grudge matches, but then adding another battery would add too much weight!
But I did buy a new truck ! I thought it was a great video Richard!
Ugh, I built a quad XP-L2. I was hoping that the multi-emitter setup would help blend the tints and make it bearable. Still pretty ugly IMHO. But Nichia? Not sure I’ve seen a Nichia that I didn’t like the tint of.
Probably when the XP-L stock gets depleted, but in every application except for triples I prefer the original XP-L over the XP-L2 (and would even prefer them there except they don't fit). The rough phosphor construction of the new generation Cree LEDs leaves a lot to be desired, which is why I'm glad that Nichia has stepped up to the plate with the 219C and 319AT.
For anything reflector based I would always recommend to use the original XP-L or XP-L HI instead of the XP-L2. Optically they just work better and have better tint edge-to-edge than the XP-L2.
In general I also prefer the original XPL mostly because of its much higher luminance and throw (when dedomed), but for this particular light I want to emphasize overall output with a wider beam. With quad emitters under the carclo TIR, the lower Vf of the XPL2 will be advantageous for my purpose.
