Yes sure, still have most of them…
PM’d you.
4 for me, please. PM follows.
I’m in need of a couple. I’ll send a pm
I used these MCPCB’s to test a nichia 229AT today. The results were surprisingly good. It beat out the 219C all the way up to 4.5A when the lack of a thermal pad and DTP caught up with it.
They have the lowest Vf I have seen to date as well!
ECHO sent these NWSW229AT LEDs to me to see what they could do and well, I love trying to new things so here are the results. I am not sure what bin / tint they are other then they are 70CRI. Tint appears to be in the 5k range. The package has this lot number: G85051-SM505M600L2R70 And this barcode: 912665462 It didn’t come up in any good search and I am don’t know how to read the nichia codes. If anyone knows what they means, let me know. EDIT: I looked up the datasheet and there appears t…
I take 2 as well to germany
PM me for pricing and paypal
Sent a message also for one board.
Hi djozz, i’ve PM’d you for two boards.
I had my Nichia 365nm LED in the Convoy run to long on the stock MCPCB it has lost brightness on parts of the emitter, 700mA are not good
Too bad I did not had this board from the beginning
Could I get 2 of these shipped to the UK?
About to order my first S2+ UV, and a reflow onto one of these seems advisable!
I’m behind in sending out stuff at the moment, and next week I’m away for work, so it will be next weekend before I will send the next boards.
for the Convoy Nichia LED I would strongly advise to make a resistor parallel to the LED which eats up 200mA
R=U/I=3.8V/0,2A=19 Ohms
P=U*1=3.8V*0.2A=0.76W
mine on this star is dying, lost about half its output
I used that light more than 20 minutes continously some times and its not good at 700mA
If you still have some to sell i will take 3 Boards.
Yes I do, 3 boards is fine, and thanks for the PM. I will reply this weekend because I’m not at home atm.
In general, I have so little boards leftover that at this point I stop the sale. Will update the OP and title.
These would be a nice addition to Clemenece’s new online shop I think.
Clemence has a version in the pipeline if I’m correct that should perform better than this board.
Hate to revive an old thread… but anyone know where i can find a few of these boards for the Nichia 119? I have a couple dozen 119’s that i have a project form, but no boards to put them on.
I think the clemence PCB’s will work with the 119. I would contact him.
Yes, the VirEnce VR16S1 board will fit the 119’s fine, but are a bit overkill at 4 dollar per board.
The boards from the OP were not cheap either and are unfortunately sold out, I had 200 of them made and sold most of them and have only a few leftover for own use. And it seems that you need many. I see no source for 119 boards on the internet atm
So sorry, that USD 4/pc is there for unlucky reasons. For anything below 10 watt it’s overkill. Any cheap non DTP board will do just fine. Try Digikey or Mouser.
- Clemence
