The Thorfire TG06S is an upgraded version of the TG06 which is the successor of the TG05. The TG06S is Thorfire's current "flagship" 1xAA/14500 light and also their newest product. The TG06S is a tube-style light which utilizes a Cree XP-G2 in a throwy polished reflector. Output is speced at a max of 500 lumens when powered with a lithium-ion 14500 or 150 lumens with common AAs (NiMH, alkaline, etc.)
I had the opportunity to evaluate the new Thorfire TG06S and was provided a copy for review by Thorfire. I was really looking forward to this because I am a big fan of EDCs which accept common AA and AAA batteries in addition to having a 14500 option (for AA lights).
- TG06S LED flashlight is the upgraded version of ThorFire TG06 flashlight. TG06S has 5 modes: High-Mid-Low-Moonlight, hidden Strobe. gives out MAX 500 Lumens
- Extremely Bright Mini Light: TG06S flashlight uses single XPG2 LED, gives out MAX 500 lumens when powered by premium 14500 battery(NOT Included).
- Multi-functional Light: High(500LM) - Middle(200LM) - Low(50LM) - Moonlight (1LM ) and Strobe , perfect for daily different applications
- Durable: aircraft graded aluminum alloy to ensure durable, sturdy, non-slipping performance
- Package Includes: 1x TG06S flashlight; 2x spare O rings; 1x manual and helpful customer services.
New Features on TG06S
1. More Modes: When use premium 14500 battery, the brightness can be High(500LM) -Middle(200LM) -Low(50LM)-Moonlight (1LM ), and Strobe(500LM); When powered by AA battery, the mini light gives out High(150LM) -Middle(80LM) -Low(20LM)-Moonlight (0.5LM ), and Strobe(150LM)
2. Easier Operation. Fully press the turn on/off, tap to change modes, double tap to activate Strobe mode for emergency.
We still keep the old features on TG06S as below:
1. The lightweight makes the newly designed ThorFire TG06S fits easily into your pocket, backpack, purse, or tool bag.
2. With one considerate metal clip, you can clip it to your shirt pocket.
3. It is great for multiple indoor and outdoor applications including searching, camping, hiking, or even use as an emergency light when suffering a power outage.
4. One cooler thing is that the O-ring behind the lens glows in the dark, which makes it easy to be found in the dark.
Warranty
ThorFire promise to offer 40 days money back and worry free customer services, if you encounter with any question, please contact us.
Item Weight: 1.6 ounces
Product Dimension: 4.3*2*1.6 inches
The tail thread is anodized to allow for mechanical lock-out.
Clip
The TG06S includes a pocket clip, which was preinstalled on the tail end for carry with the light facing down. The clip can also be installed on the head end for facing the light outwards (such as if you wanted to install the light on the bill of a baseball cap). The clip is secure and would be relatively hard to accidentally remove. Keeping the clip installed also adds a significant level of roll-protection.
Output is ordered H -> M -> L -> ML. (This is my preferred order for smaller EDC lights)
There is no mode memory so the light always activates on High.
Operation:
- To turn the light ON or OFF, the tail switch is depressed fully.
- To advance modes, the tail switch is depressed partially (light press).
- To activate strobe (hidden), the tail switch is depressed partially twice in rapid succession.
When using AAs, I recommend using rechargable NiMH batteries such as Eneloop because these rechargables will not leak the same way that alkalines do. If using alkalines, be sure to replace them frequently especially once they are drained. Alkalines are most likely to leak in hot environments (like in a car) or when drained. For long-term storage such as a light left in a car or emergency kit, you may also use lithium-primary AAs (ex: Energizer L91).
The positive contact is flat. The negative contact is a firm spring.
Moderately Throwy. The TG06S uses a domed XP-G2 combined with a polished reflector so the hot spot is relatively tight with a somewhat defined corona that transitions nicely with a reasonable amount of spill.
When using an Eneloop AA NiMH, this light exhibited a gradual ramp-down of roughly 10-12% from activation during the first 2 minutes which is not noticeable during use. After that, this light does not appear to step-down any further during the first 10 minutes.
There is no electronic lock-out.
SoCalTiger
Recent Reviews: Klarus G20L / Thorfire S70S / Thorfire VG10S / Thorfire S1 / Thorfire TK15 & TK15S / Thorfire TK4A / Thorfire TG06S / Wuben T101 / Wuben TP10 / Zanflare C4 Battery Charger / Zanflare F1 / Zanflare F2 / Sofirn C8A / Sofirn SF22 / Sofirn SP31 / Orcatorch WR10 / MiBoxer C4-12 Battery Charger
Nice complete review!
Got this one a week ago and like it, but the moonlight seems to be higher output than the old model.
Tint is better however.
Thanks!
Keith
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Thanks! I don’t have the old model to compare it to but I thought that the tint was great. Definitely a good EDC IMO. With a 14500 the High is great to impress muggles with given the size.
SoCalTiger
Thanks for the nice review. Now the TG06S is on big deals to all BLF friends. Use this coupon code (MQHZYUZC ), you could get one TG06S for ONLY $10.99.
Purchase Link: http://amzn.to/2p62Ipv
ThorFire is looking for dealers/retailers/distributors from Europe countries and other countries around the world. If you are interested, PM me!
Nice thorough review SoCalTiger! Looks like a good EDC.
I’d rather use my flashlight around the house than turn on the lights.
Well done!
@1theDeals
Great review! Thank you.
I was really interested in this light, but PWM is a no-go for me. Otherwise, everything else looks great. If it were constant current, I would buy several.
Thanks for the great review. I’ve been using one of the older TG06 models as EDC, for over a year. It came up missing a couple of weeks ago, and really miss it. With the offer from Thorfire, I will have the new model on Monday.
The older model I believe only used PWM on low, but I’m not that susceptible, so it works well for me.
Brian
I think the tail threads are anodized to prevent wear and provide smoothness, not for lock out, because you don’t need lock out with a reverse clicky switch, because it’s hardly possible to accidentally turn it on and there is no parasitic drain when off.
Interestingly enough, I lock mine out when it is in my pocket. I tend to fiddle with my hands when idle. I also keep chapstick in one of my pockets and frequently find the tube unscrewed, etc. I guess I could subconsciously screw the tail back on and them press the button but that hasn’t happened yet. haha
SoCalTiger
I said that because i have some lights with bare aluminum threads, and when you lubricate them (silicone grease), the aluminum seems to dissolve a little and you get that grey goo as a result, which doesn’t help making it go smoother..
Candle wax works better though, but is a little hard and crumbly.
So the anodized threads are definitely a plus on this (or any other) light.
That’s interesting. I know that silicone grease is a no-no because it can react with silicone O-rings but didn’t know that it could react with the aluminum as well. Are you sure that the grey goo isn’t the result of reacting with the O-rings?
SoCalTiger
Yeah i’m quite sure.
It’s even worse with thermal grease, like Fujik etc..
Never had any problems with O-rings though.
I used to have a small syringe with silicone grease, but now i have “Yezl” silicone grease (Fasttech), which is more solid, less runny.
Alright, I’ve made several improvements to my output measurements:
1) I realized that my current measurements were inaccurate due to using poor leads on my DMM. My updated numbers should be correct now.
2) I re-calibrated my output measurements so these numbers are now estimated lumens.
3) For “High”, I show both the peak output and output at 30 seconds.
4) I added % Output and % Amps columns.
Finally, just to make sure no one misses the coupon code:
SoCalTiger
Interesting.
Less output with protected 14500.
I think that means there is no current regulation on 14500, only PWM, but basically direct drive.
The XP-G2 can handle that though.
Currently $9.90 on Amazon (US) after coupon code.
http://amzn.to/2znBCyk
40% OFF Coupon Code: 8YGYJ38C
SoCalTiger
