The customizations in that hexfile are moonlight defaulted to off, and the reverse groups have been modified to ultra low, then turbo/FET, then battcheck.
Basically I will ask people that had replied here as there is interest for at least 25 drivers, to give me a final number how many they take and send the payment instruction
When I have confirmation of people with the final number of drivers they take,
Then I will start ordering parts, and also as last time more for people who join in later
So if you tell me as early as possible a number you take for sure its better than a number higher than you take in the end
Interested in a 22mm ldo bistro or possibly bistro hd to replace the LD-29 in my Convoy L5. Single tube with 2x 26350 or double tube with 2x 26650 lii cells powering a xhp50.2 would probably be a good combination for this light. I like the light itself but the driver… not so much.
I got some Be-Cu springs as well, dont need to be cut and bend, they simply fit
but as you solder the positive wire to the top of the spring there is no need for low resistance spring, you can use thin steel springs
The Be-Cu springs are not nearly as flexible as steel springs, first time compressed they get shorter
Correct, the pass-through in the TA drivers means that spring resistance is a non-issue. All that matters is that the spring holds the battery in place and keeps it from hitting the 7135’s.
The potential problem is the length of the springs in the op. I’d have to measure but the original spring on the L5’s driver looks like 6 or 7 mm uncompressed.
NarsilM got released, it is a bit different with temp. calibration in User settings
The only improvement I see in LVP for 2S lights, but it lost some setings to get the UI Settings easier
Ok we met the minimum number of driver to start ordering parts and boards
I will order from digikey this time later when the first Oshpark boards arrive, so the number of drivers is not limited by an early order from digikey parts
Priced for Bistro HD OTSM and NarsilM updated
Option for customized modespacing/modegroups added or you give mne a customized HEX file
