I agree with David that lack of comfort holding it is not enough reason to not want the Q4 as short as possible. Many lights are very short and I like them for their compactness and I still find them comfortable to hold. The SWM D40A and the Crelant V4A are 12cm, the shorter Manker MK41 is 10.5cm, but because of the short quad reflector and if we do not use a battery carrier, we can make the Q4 as short as 8cm. Mind that that is a full cm shorter than the newest DQG tiny 26650! When also squaring off the middle section of the battery tube, we have an ultra-compact 4xAA light that makes the most of the advantage that AA-size is shorter than 18650-size.
I said “really” see. Sure there are always fringe cases.
I agree, my wording was a bit strong. Although all of the facts about the batteries, are just that, facts. Not opinion.
The only opinion is that the shortest it should be is ~110m. That is indeed my opinion, although that is an opinion that would be backed up by most market research consultants as seen by the fact there are very few lights shorter then that.
I will bow out now, I only wanted to bring attention to the logical side of using larger cells over 14500’s. I have done that and there is no need to continue doing it. People can make up their own mind.
My opinion is that the time, effort and resources would be better spent on something besides this. This is one of those things you make when you run out of things to make IMHO.
The 4P AA 14500 Q4 is a really nice follow up with Thorfire IMHO
They do the Q8
We take the TK4A tube, tail and switch, scale down the head of the Q8, design driver and build on the trust there is now.
AA lights are very useful, in the car for example here I measured –12°C to 60°C, no way I want a li ion cell in that.
The 14500 is just added bonus for Mac brightness and so we can develop a driver that paves the way for some sweet Bistro / Narsil SK68 or whatever AA or 14500 light
Complex firmware on a AA would be my prime goal for the Q4 so to say.
That is why our normal 2,7-4,2V input are less interesting here, making it work on 0,9-1,6 AND 2,7-4,2V that is the challenge and a mighty big one I’d say.
4xAA is 4.8V nominal, versus 3.7V for li-ion. You can not burn that off with a lineair/direct driver. It will need a buck driver, and it needs to deliver at least 6A to the emitters if you want an output that is remotely impressive with a floody quad set-up (2400 lumen). Quite a challenge that is!
The TK4A looks like a good start but I don’t like the ears at the bottom, it adds unneccessary length, in my opinion of course.
The Miller is talking about a 4P. Not 4S
So only 1.2v… I can not believe in 4P AA.
No no not series, parallel
Consider the Q4 the ultimate muggle light and hopefully opening doora to sweet AA yet complex cool firmware running flashlight mods on SK68, Kronos X5, etc lights.
And indeed modded TK4A mini soda can lights needing only 1 AA instead of 4.
The 14500 is neat for those qanrinf max output but 1* AA with Narsil/Bistro is a goal.
You need about 3v (I hope you are not thinking about a xhp in this configuration) for one led and about 6amps for 4 LEDs to get the 2400lm out of it
ONE AA???
Poor small eneloop. :confounded: after 10 minutes dead :smiling_imp:
OK im in!
This thread will get 100 or 10000 posts… I have time
HKJ has tested Eneloop AA up to 10A current. If it takes 2.5X to convert AA to LED running voltage, you’d need 14A input to get 6A output. One cell probably couldn’t handle that, but two might, three sure would, and four would be gravy! The real challenge will be finding a boost driver capable of 1xAA input to ~3V 6A output. I don’t know that any have even been attempted, but that driver has actually been desired around here for a while.
This!
Here is one.
Hi! i posted already some measurements in the XHP35 tread.... (from V0.1 where i held the parts together with the hands...) since i do not have much shoptime i wanted to show my "work in progress" to gather some thoughts from you ;) today i used some scrap to build Frankenlight V0.2 which works, but is far from finished in mechanical terms... I used a XHP35 (12V) from Cutter on a noctigon. to power it i modded a SRK-clone: the old driver was stripped and converted to 4S [i…
fund news:
Change:
4 only for progress in projects that are meant to lead to a real flashlight for all to buy.
To:
4a primarily for progress in projects that are meant to lead to a real flashlight for all to buy.
4b the funds are growing so fast, a part also for support of driver developers for down the road these projects can be used in BLF specials
Reason, we do not know what will be used in BLF specials and even Narsil and Bistro started smaller.
Though all developers that are doing their work open source seem happy in doing so, financial rewards or a little donation are no motivations for them. The big projects can get so much attention it seems nice to give others a small token of BLF appreciation making them able to do a Oshpark order or use it for tools or something, knowing they are seen and speeding things up as among others the Kronos projects and Q8 have sped things up too.
A quote from the Q8 topic:
This (Q8 red.) achieves 4000 lumens. For eye perception we can assume its sqrt 4000 which is 60~.
For Q16 I think we should at least double that. This means it will have to be 120×120=15000~ lumens.
Do you think q8’s soon to be big brother q16 with 4 xhp50.2 emitters will achieve this?
NEW FUNDS SPENDING
A round of BLF tech developer support, as token of appreciation and hopefully speed tech development up even more.
$30.30 (received $30) Toykeeper for example: trunk : Code : Flashlight Firmware Repository
$30.30 (received $30) Tom E for example: Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light - #2 by The_Miller
$30.30 (received $30) DavidEF for example : Another little driver that won't be much use to most of you guys
$30.30 (received $30) Texas_Ace for example: Texas Avenger "TA" Driver series - Triple channel + Bistro or Narsil + Clicky or E-switch - The Ultimate open source driver!
$30.15 (received $30) Mike C for example: Mike C drivers: v8 series, ATtiny1634 based.
(More tech developers were contacted, not all reacted, not all accepted, so the token of BF appreciation was bigger for these 5.)
Thanks for the donation. I’ll use it to build a couple of drivers for a GAW when I’m finally satisfied with the design.
:+1: thank you for creating BLF tech.
You guys are the core why manufacturers take us serious as a group with real information and input and not just a forum of consumers.
It is the likes of you that are making it possible for people like me to dare ask manufacturers to look at an idea and thus making BLF specials possible, not to mention the coolness of what gets done with super firmware, lighted tailcaps and what not
So thank you again!
Pretty cool you wanna do a GAW! do people who donated to the funds and enter an extra chance?
Nice Mike. You receive a donation for work carried out that you will do more work and donate it away.
That’s not a bad idea at all. I’ll figure something out.
It’s actually The Miller’s idea. I tried to decline the donation but was talked out of it. Doing a GAW was the perfect solution
So Miller talked you into giving your donation away. I’ll have a few words with him for you and give him a good piece of my mind. He wont be doing that again.
Thanks for the donation, The Miller! :money_mouth_face:
Mike C, I didn’t think I deserved to be on the list of recipients, but you sure do. Your work around here is undervalued, IMHO. Nobody talks much about your contributions, but IIRC you’re actually the guy responsible for a lot of the coolest ideas, like 3+ channel drivers for better efficiency. It’s cool you’re going to “give back” your donation by building drivers and doing a giveaway. It reminds me of Old Lumens in a way. He had received lots of flashlights from manufacturers for reviewing over the years, and he never kept them, but always did a giveaway here.
Also, I want to take the time to say thanks to everybody that donated. I hope you all feel good about the decision The Miller made here. I’ll try to make sure whatever I do is a push forward for BLF somehow. I’ve learned so much in my time at BLF, that I can’t possibly pay back for the knowledge I’ve gained. I wouldn’t even be doing these kinds of mods, or designing my own boards, if it weren’t for the inspiration and encouragement of my fellow BLF’ers.
I’ve already got a GAW going right now (gonna end today). So, in an effort to “give back” my donation, I think I’ll try designing another crazy, cool, or niche driver board. My reasoning is that it’s the guys on the fringe, making the niche items, that push most crafts forward in life. So maybe I’ll find another nifty host and make a driver for it. Then, if the build goes to plan, I’ll do a GAW of the modded light. The donation money will help me buy the board from OSH Park and the components to populate it, and maybe the host to put it in. I don’t know when I’ll get all this accomplished. Perhaps it will be done in time for my 5000 post GAW! :partying_face:
