well, i have yet to confirm this
f e n i x l d 0 1 r 4
ENELOOPS:
tailcap readings.
tailcap readings with freshly charged Eneloops (1.54V)...vs...depleted Eneloops (1.20V)
Med: 0.207...0.657A
Lo: 0.022...0.041A
Hi-1: 0.655...1.750A
Hi-2: 0.448...0.551A
comment: as expected, amperage rises with falling cell voltage. this way the brightness is regulated constant.
actual runtime measurements.
Eneloop runtimes on Hi:
1.54V, cell#2, 2h0min, @0.83V ->1.1494V, N/A
1.55V, cell#8, 1h44min, @0.83V ->1.1691V, 798mAh
1.54V, cell#6, 1h37min, @0.88V ->1.1848V, 749mAh
1.54V, cell#7, 1h35min, @0.98V ->1.2008V, 745mAh
1.54V, cell#5, 1h35min, @1.01V ->1.2103V, 772mAh
1.54V, cell#6, 1h34min, @0.91V ->1.1934V, 761mAh
1.54V, cell#2, 1h33min, @0.96V ->1.1966V, 742mAh
1.55V, cell#7, 1h32min, @1.13V ->1.2268V, 728mAh
1.54V, cell#8, 1h31min, @1.15V ->1.2356V, 737mAh
Eneloop runtimes on Med:
1.54V, cell#8, 3h24min, @0.83V ->1.1577V, 811mAh
1.55V, cell#2, 3h15min, @0.88V ->1.1761V, 755mAh
1.54V, cell#8, 3h12min, @1.09V ->1.2000V, 740mAh
1.55V, cell#7, 3h8min, @1.11V ->1.2039V, 753mAh
Eneloop runtimes on Lo: TBA
1.55V, cell#2, 31h45min, @0.85V ->1.1617V, 772mAh
note:
down-step from Hi-1 to Hi-2 occurs after ~7mins (6min53sec, to be exact!)
no matter which voltage the cell has, in High-mode the torch comes on always on Hi-1, for example in series you'd get something like this:
#1, 0.655...0.768A, then down-step (from 0.768A) to 0.448A
#2, ...0.823A, then down-step to 0.xxxA
#3, ...0.838A, then down-step to 0.481A
#4, ...0.862A, then down-step to 0.487A
#5, ...0.872A, then down-step to 0.xxxA
#6, ...0.926A, then down-step to 0.510A
#7, ...1.055A, then down-step to 0.551A
#8, ...1.750A, then drops out of regulation
If you sum these intervals, the (max. possible) accumulated runtime on Hi-1 is about 49min (7*7min), or in other words, if you need max brightness you could turn on and switch to Hi-1 (period#1), then after ~7mins, cycle thru the modes again to High-mode (Hi-1; period#2), for a total of 7 periods. After that, when you're in your 8th period, the cell is becoming depleted and you get only a few more minutes (< 7min) on Hi-1 until the light completely drops out of regulation: the light would dim steadily within minutes from 1.750A to low light output.
10440's:
The older PWM-regulated LD01 versions (Q4, Q5, R2, R3) were known to support 10440's, see the many CPF references. So what about the current version, the LD01 R4 which is not PWM-regulated but current-regulated (no PWM confirmed!)? First let's start off with this link from authorized Fenix dealer Lighthound:
The product sales webpage states clearly that the LD01 R4 black aluminum version can use 10440 LiIon cells! There are "hundreds" of Fenix LD01 threads on CPF and often the 10440's topic is included in the discussion, most of which date from 2008-2010 and cover the PWM-regulated versions. i've selected the most relevant or interesting threads, may they be helpful related reading (in no preferred order):
- review: Fenix LD01 SS XP-G R5, AAA light, includes measurements and outdoor beamshots (HKJ, 04-2011)
- review: Fenix LD01 Q5 Stainless Steel Special Edition 2008-12-16 2350 7.1 (mev, 12-2008)
- review: Fenix LD01 R2R3 2010-05-16 820 7.6 (mev, 05-2010)
- Fenix LD01: some real world beamshots comparing output on NiMh vs 10440 (hyperloop, 05-2009)
- W~O~W, now, finally, I'm a true AAA flashlight believer... (DHart, 05-2009)
- LD01 Output Comparison by cell type (DHart, 05-2009)
- New LD01 low output? (SixM, 11-2009)
- Who got their LD01 Stainless Steel? (Splunk_Au, 11-2008)
- AAA lights that can take 10440? (rickypanecatyl, 04-2010)
- Has your ITP A3 EOS blown on a 10440 ? (JulianP, 03-2012)
- Protected 10440 (AAA size) Li-ion cells! Finally!!! (Vamp, 11-2009)
- At what point do 10440's become dangerous (LightScene, 01-2009)
- Is there any single AAA better than the Fenix LD01? (davidt1, 12-2008)
- Fenix LD01 Stainless Steel Limited Edition (squaat, 10-2008)
- Fenix LD01 Stainless Steel Comparison Review (UnknownVT, 01-2009)
- Has your Fenix LD01 blown on a 10440 ? (shelm, 04-2012)
I did enough reading, i've had it! :tired:, now i just go ahead and use 10440's for the sake of this review:
tailcap readings.
tailcap readings with freshly charged Protected Ultrafire 10440 (4.215V resting voltage)...vs...depleted cells (3.600V resting voltage; within seconds switftly drops/sags down to 2.750V under load, shortly before the protection trips):
Med: 0.890A...0.105A
Lo: 0.169A...0.019A
Hi: 1.316A...0.187A
comment: on Hi, for a cell with 300mAh capacity, the initial discharge current is 4.4C which is way beyond the 2C safety specification of 10440 LiIon cells which says that the continuous discharge rate of a 10440 cell should not exceed 700mA. Assuming that the actual capacity of 10440's (often rated with a nominal capacity of 500mAh or 600mAh, see Trustfire or Ultrafire 10440 cells lol) is somewhere between 250mAh and 350mAh the initial discharge current calculates to between 3.7C and 5.3C. 320mAh would be a generous bet, and this calculates to 4.1C. However, since the light is not regulated on Li-Ion's, amperage decreases with decreasing cell voltage, the light gets dimmer and dimmer on Li-Ion's and there is no continuous (or constant) 4C discharge rate to be feared. In fact, on Hi the discharge rate continuously declines from 1.3A (4C, 4.215V) to 0.2A (0.6C, 2.750V).
FYI, even if a torch (the PCB and the LED) can withstand for example 4C with proper cooling, it doesnt mean that you or the torch are safe. Continuous constant 4C is a hazardous discharge rate for normal 10440 LiIon cells and it could lead to poof or kaboom. in practice you are safe to discharge at 4C for short periods of time, e.g. for 20sec time intervals. for the sake of this detailed review with tests and measurements, i am venturing continuous discharge tests on Hi mode (and on the other 2 modes).
Protected 10440 runtimes on Hi, until the protection trips:
cell1 (marked): 20m27s (60sec intervals) / 28m12s (full run) / 25m24s (full run) / 18m36s (60sec intervals)
cell2 (unmarked): 17m37s (90sec intervals) / 20m15s (full run) / 20m37s (full run) / 20m13s (full run)
Protected 10440 runtimes on Med, until the protection trips:
cell1 (marked): 33m26s / 32m50s / 31m38s / 30m16s
cell2 (unmarked): 26m25s / 25m48s / 25m8s
Protected 10440 runtimes on Lo, until the protection trips:
cell1 (marked): 2h19m31s / 2h18m46s
cell2 (unmarked): 2h7m4s / 2h8m36s
some details of the runtime measurements.
Now let's put some efforts in measuring tailcap current and cell voltage in detail during the above testruns, especially on Hi-mode. See the following discharge graphs of continuous runtimes (marked cell on Med, unmarked cell on Hi) to get an idea of how fast the current decreases within the first 2mins (="120,0" on the x-axis) both on Hi- and Med-mode. The above 2 underscored numbers are taken directly from this measurement graph:
measurements and graph by kreisler, UT61E and Excel2010, thx to HKJ for helping with it
you can clearly see that the light is not regulated on 10440's. if it were, then the current would increase(!) with progressing runtime, to stabilize the brightness ( wattage = amperage x voltage ). the LD01 R4 on 10440's, when time progresses voltage decreases (because the 10440 cell is being depleted) and amperage decreases! therefore the light dims. no constant brightness on 10440's! what else can you see from the above graph? you can see that shortly before reaching 7.0mins continuous runtime on Hi-mode, the light drops in amperage from Hi1 (~0.86A) to Hi2 (~0.76A) .. in a similar way as we have been observing with Eneloops. this means that the light uses a built-in timer (capacitor?) every time when you switch the light to Hi-mode, and this is independent from the cells (Eneloops or 10440's). Anything else we can see from the above graph? Well, the actual "average continuous" current draw on Hi-mode is ~0.8A (2.5C), and ~0.55A (1.5C) on Med-mode, which is way below the initial 4.4C. You ask me: So kreisler is 2.5C finally a safe discharge rate yes or not or what?? And i answer: Get off my back thx haha and simply enjoy the next visualized 3 testruns, all on Hi-mode, but this time conducted in short intervals.
Each interval has a length of 90sec runtime:
unmarked 10440 cell | accumulated runtime | offline voltage at rest |
interval 0 | 0'0'' | 4.200V |
after interval 1 | 1'30'' | 4.06V |
after interval 2 | 3'00'' | 4.024V |
after interval 3 | 4'30'' | 3.952V |
after interval 4 | 6'00'' | 3.898V |
after interval 5 | 7'30'' | 3.856V |
after interval 6 | 9'00'' | 3.807V |
after interval 7 | 10'30'' | 3.788V |
after interval 8 | 12'00'' | 3.744V |
after interval 9 | 13'30'' | 3.703V |
after interval 10 | 15'00'' | 3.676V |
after interval 11 | 16'30'' | 3.535V |
after interval 12 | 17'37'' | tripped at 2.750V |
Each interval has a length of 60sec runtime:
interval 0 | 0'00'' | 4.200V |
after interval 1 | 1'00'' | 4.09V |
after interval 2 | 2'00'' | 4.03V |
after interval 3 | 3'00'' | 3.97V |
after interval 4 | 4'00'' | 3.90V |
after interval 5 | 5'00'' | 3.83V |
after interval 6 | 6'00'' | 3.81V |
after interval 7 | 7'00'' | 3.79V |
after interval 8 | 8'00'' | 3.77V |
after interval 9 | 9'00'' | 3.75V |
after interval 10 | 10'00'' | 3.74V |
after interval 11 | 11'00'' | 3.73V |
after interval 12 | 12'00'' | 3.72V |
after interval 13 | 13'00'' | 3.71V |
after interval 14 | 14'00'' | 3.69V |
after interval 15 | 15'00'' | 3.68V |
after interval 16 | 16'00'' | 3.66V |
after interval 17 | 17'00'' | 3.63V |
after interval 18 | 18'00'' | 3.54V |
after interval 19 | 19'00'' | 3.42V |
after interval 20 | 20'00'' | 3.29V |
after interval 21 | 20'27'' | tripped at 2.750V |
Same cell, same 60sec interval length, just another testrun, this time with stricter pauses of exact 9.0min between each interval:
marked 10440 cell | accumulated runtime | offline voltage (after 9min rest) |
interval 0 | 0'00'' | 4.20V (4.200V) |
after interval 1 | 1'00'' | 3.93V (4.116V) |
after interval 2 | 2'00'' | 3.88V (4.063V) |
after interval 3 | 3'00'' | 3.84V (3.996V) |
after interval 4 | 4'00'' | 3.82V (3.949V) |
after interval 5 | 5'00'' | 3.79V (3.904V) |
after interval 6 | 6'00'' | 3.76V (3.867V) |
after interval 7 | 7'00'' | 3.74V (3.839V) |
after interval 8 | 8'00'' | 3.72V (3.816V) |
after interval 9 | 9'00'' | 3.71V (3.797V) |
after interval 10 | 10'00'' | 3.69V (3.780V) |
after interval 11 | 11'00'' | 3.67V (3.766V) |
after interval 12 | 12'00'' | 3.66V (3.750V) |
after interval 13 | 13'00'' | 3.64V (3.731V) |
after interval 14 | 14'00'' | 3.62V (3.708V) |
after interval 15 | 15'00'' | 3.60V (3.691V) |
after interval 16 | 16'00'' | 3.56V (3.676V) |
after interval 17 | 17'00'' | 3.45V (3.578V) |
after interval 18 | 18'00'' | 3.22V (3.376V) |
after interval 19 | 18'36'' | tripped at 2.750V (3.212V) |
The above tables are more detailed than graphs and they can be helpful to determine how much runtime you got left if you check your (unprotected, for that matter) 10440 cell with a digital voltmeter. For example, when you remove the cell and it has been resting and the DMM measures 3.80V, then it means that you got only ~10mins on Hi-mode left, if you use the light intermittently for 60-90sec intervals. Likewise, if it measures the magical 3.60V limit, then you got 2-3min left (= 2x 60sec, or 2x 90sec) before the voltage under load reaches the (another magical) 2.75V limit. I mean, on the LD01 it's easy to notice when you just have reached the 2.75V limit: the light isnt bright anymore!! haha. No, seriously. As soon as you notice a considerable drop in brightness on Hi-mode (or Med-mode), it means that the light has passed the 2.75V limit (e.g. down to 2.10V) and you must stop using the light by all means. Then let the unprotected cell recover (e.g. up to 2.50V) and finally feed it to your charger and hope that the charger accepts the overdischarged cell. As a general rule, if the cell's resting voltage has reached 3.5999V (=2-3mins on Hi-mode left), you should stop using the cell and go recharge it. The above tables are also helpful/valuable for you for reproduction purposes: if you can reproduce the above measurements (tailcap readings with freshly charged cells, voltage readings after 60secs or 90secs of usage on Hi-mode), then it means that your copy performs exactly as my sample. Fenix has high production quality standards and we should assume that all produced LD01 R4 units perform equally well and safe (e.g. with 10440's) but users all over the world (amazon, forums, google, wiki, ebay, haha) do report about stupid tints, malcentered emitters, and dying specimen.
The above 3 tables (containing 4 sets of voltage measurements) generate these line graphs with interpolated points. The 3 blue lines (=resting voltage of cell1 or cell2) share an interesting common characteristic: after 16mins of accumulated Hi-mode runtime, the lines would part from that intersection on! The resting voltage at that time is ~3.67V which is therefore a critical voltage in the LD01 R4 so to speak:
comment: as you can see from my published multiple runtime tests on 10440's, continuous runtimes heavily depend on the state and quality of the particular cell. there seems to be a considerable quality difference (capacity difference) between cell1 and cell2, both of which were bought together in the identical 2-pack from DX. also note that the runtimes got shorter with each test run! indication of cell degradation and cell aging? You're asking 'hey kreisler i've seen such shaped line graphs before! is it coincidence that the Fenix LD01 R4 10440 discharge curve (amperage vs. runtime) looks so similar to battery discharge curves (voltage vs. capacity)?' and my answer is 'well observed, well well! maybe it has something to do with DD'. haha.
duh.
and last but not least note that continuous runtimes are longer than using the light in intervals. the interval method, e.g. max 60-90 secs on Hi1 with 10440's, may be healthy for the Cree XP-G R4 LED's life but dont wonder about the short accumulated runtime. the high initial discharge currents (e.g. 1.316A with a freshly overcharged 10440 cell) when you switch on (or to) Hi1-mode do explain why accumulated runtimes from the interval method have to be shorter in sum.
IMPORTANT NOTE (DISCLAIMER):
since the LD01 R4 is not certified for use with 10440's i do not recommend or encourage feeding 10440's. during the many runtime tests conducted for the sake of this review (and for the sake of giving complete information, which was btw never done before! so this is a world-premiere for the LD01 R4 --- a full-fledged review!!!) there was no harm done to my LD01 R4 copy and other users on cpf report the same: their LD01 R4 copies do withstand the high current/high voltage of protected or unprotected 10440's without problems. however, in all fairness, this is no guarantee that your copy will not fry at some point. my strong advice is: DO NOT USE 10440's IN YOUR LD01 R4! the point is: the light is incredibly bright on Eneloops (conservatively rated 72lm) and it looks even brighter because of the tight beam (tight spill + very tight hotspot, rated 50m throw), the LD01 R4 produces higher actual brightness and runtimes than the Klarus MiX6 (rated 85lm lol), you also got the most perfect beam beauty and the best possible pure white tint and in both it beats the legendary premium MiX6 which comes itself with immense beam beauty and pure white tint. in other words, it's already the #1 top best performing 1xAAA keychain light (and many people who "know" the long-existing Fenix LD01 product are not aware of this sensational fact), so why would you desire or risk driving the light beyond design specifications? for what good reason? out of boredom? or maybe simply because you are extremely curious, possess tons of dollars and dont mind possibly ruining a perfectly working #1 top best performing 1xAAA keychain light? well, if you're curious, which is a valid good reason imho, then this detailed review (and up to this date, it's the only existing review of the R4 version of the LD01!!!) should have satisfied your §$%&! curiosity. 10440's in the LD01 R4: I've proven that it works, i've proven that it rivals the iTP A3 XP-G R5 on Hi, i've shown that you get 3 distinct (even if bad-spaced) modes, i've clocked continuous runtimes, i've measured accumulated runtimes, i've measured amperages both on fresh and on depleted cells, i've been ruining (=wasting) my cells with the multiple and repeated test runs, i've published full amperage discharge graphs on Hi and Med, and i've created several animated beam slice GIFs which visualize the absolute and comparative brightness. so what else could you possibly be curious about?? all you need to know about 10440's in the LD01 R4 is presented in this kicka$$ review so your curiosity (about this sort of info) is herewith officially satisfied, and it cant be named anymore as reason why you would want to risk it. in any case or which other personal reason you might have .. the LD01 R4 is really(!) not designed to run on 10440's: you lose a real Lo! With 10440's on Lo, the LD01 R4 is as bright as on Hi with Eneloops. that's a real bummer and kills many possible uses of a versatile keychain light (preserving night vision, reading a book at total darkness). a keychain light without a real Lo is inacceptable, you'll realize this in practice in the long run believe me. there are lights which you can run with confidence on 10440's so use them if you need to wow your fellas: the iTP A3 XP-G R5, the Tank E09, and others. Here a suggestion: if you are beyond the 30 months Fenix warranty period and dont care much anymore for yours (e.g. because you got better ladies at home), then ..etc..
brightness levels, given freshly charged 10440's:
lo (eneloop) < med (eneloop) < hi2 (eneloop) < lo (10440) < hi1 (eneloop) < med (10440) < hi (10440):
ANIMATED GIF
jojo
Hi bro, very good post thanks.
Can you help me decide something please...should I get the stainless Worm or a colored aluminum one? I cant really decide...Stainless is 30$ so that makes it a big purchase for me...(above my mental impulse to buy-now), and the Aluminum is only 17$...but if you could only pick one, what would you get since you have them both in hand...is the stainless one really nicer? Or too heavy, etc??
Thanks!
i guess you cant wait until the review huh? lol
actually i am taking back .. i ve just retested the brightness E09 vs. Worm with fresh Varta 1.2V NiMH cells. The Worm throws further and is brighter (peak beam intensity).. By the end of this week i should have completed the relative comparison.
SS or Alu? There is little which counts for the SS, except for the key attachment point. It is considerably heavier. Good to EDC it to a party (for the bling). If you dont mind the Olight i3-type of mini split ring attachment point (i use a special large thin split ring for the Worm Alu), then believe me this is an easy decision. Alu.
But most importantly, do not get old stock of the Worm but a latest production sample. Lumintop cares a lot about optimal LED's (brightness, tint bin), as mentioned.
Where?
AFAIK, SS has XP-G R5.
Where to get the new stock? How to differentiate the old from new stock? Is the difference between old and new that much?
Hi SashiX, congrats to your Worm! Sorry to hear about the lens o-ring (limóng onó¿). SMO reflector? Wanna share some pix?
let's validate the integrity of your emitter (XR-E, XP-E, R2, R3, ..)
I've measured Eneloop runtimes, see OP.
Kreisler, thanks for pasting my comment here, couldn't find this thread yesterday :bigsmile:
Yup, came with SMO reflector. I think LOP will smoothen a little bit better those "normal" artifacts when you use SMO. I've made some pic using my phone and magnifying glass :bigsmile: Don't know if it's R2 or R3 :| (they, AFAIK, should be the same, visually). I still need to buy new NiMh.
The upper-left part of the o-ring is slightly out.
nice photo, thanks!!
here a picture from my past :bigsmile:
yours looks nicer. so whaddya think?
boring torch? *GGG*
btw, time to update your signature, and kick the dealer's a$$ for sending the o-ring issue
is xpe R3! ...at that time is what you wish xD but you really ordered that color?
:quest:
( two me looks like xpe R2! )
As I said before and AFAIK, visually, R2=R3 :| How do you know if it's R3, mixo?
Yup, I ordered that color and, Kreisler, as for "kickin' the dealer's a$$ for sending the o-ring issue"... I'm on it :bigsmile:
Anyway, I think LOP would be a bit better in such a small light. (but SMO will throw better :P ).
Will take some beamshots later.
read all evil, don't need another baby that cry about his R2 or greenish xpg xD
...and my mobile connection prefer JPG images instead of PNG ty xD
danos la corona y el no-hagas agujero graXias xD
That was one fantastic review. Hats off mate. Any clue where can I buy the 2012 version on ebay that ships to Mauritius free?
Would the XP-G really matter over choosing the XP-E version?? You totally sold me on getting one of these RIGHT NOW MATE. Im fighting the urge to buy one atm waiting for your reply...
Ok you bought this from hkequipment and he trades on ebay too....Can you please confirm if these are the 2012 versions?
OR
hi MountainKing,
SashiX has the Alu 2012 model and he could comment in detail on his sample (tint, brightness). runtime of the Alu is miniminimally higher (~80mins vs. ~74mins, and i am still running runtime tests) but in terms of light output, hotspot size (as seen in the table and animated gifs), the SS 2012 is an outperformer and i am highly surprised. I had the SS 2011 and it was extremely greenish and with low light output. So there is now a boost in improvement in the SS 2012. Amazing output, especially its integral brightness, and tint on low-mode is less greenish than it used to be. On high-mode the tint is slightly greenish and comparable to the typical greenishness of the iTP A3 XP-G R5 which everybody loves; the Klarus MiX6 has a much better tint, no doubt. I am running the Worm SS head on the Worm Alu body (to save weight) but i could run it also on my iTP A3 body (to save weight).
So it's a little difficult to decide between SS and Alu. It depends on the purpose, really. If you need a great great AAA torch, then better just go with the Tank E09 (i dont mind the low-frecuency PWM. i find it cool!) because it has all versatility and safe operation with a total of 6 brightness levels (3x Eneloops, 3x Protected 10440's). And the head is supereasy to twist. If weight matters to you a lot (the Klarus MiX6 Ti weighs 12grams!), then you should have a spare body (iTP, Olight, Worm Alu, E09) .. also in order to queen-shelf the shiny SS body.
I wont recommend the Worm SS as torch if it has to be your ONLY 1x AAA torch for a flashaholic. If a flashaholic plans to own just 1 torch (of the 1x AAA form factor), then i will always recommend the Tank E09. (or the iTP A3, or even the Fenix LD01, for those who dont want to fiddle with the E09's insulation issue new out of the box). However, in any other case (non-flashaholic, or flashaholics with 1 other AAA-sized torch), i would full-heartedly recommend the Worm. My personal nods goes to the Worm SS. The weight is still acceptable (compare with Preon Revo SS, Rofis ER10 SS, Klarus Mi10 SS, Fenix LD01 SS, and any other 1xAAA SS model), and personally i can just swap the SS head onto my Alu body.
btw, the review isnt 100% done yet. Once it is, i will change the thread title. SashiX wanted to contribute a set of beamshots, and i wanted to run a few more runtimes in low mode (SS).
The SS is more like a piece of jewelry (with the best output on Eneloops one could imagine, integralwise), and the Alu is thrower -- not too suitable for reading books ;). too bright, too tight hotspot, too intense.
Maybe SashiX can share more of his experiences?! :)
Awesome review kreisler. I started reading out of curiosity and a sort of politeness; after all, someone puts this much work in, the least I can do is to read it. I wasn't really interested in buying another AAA light, but by the end I was on the point of 'adding to cart'. Be very interesting to compare the Worm/s to the Brynite PD03B
Lensman, you know that i get commission from Lumintop when you buy this torch from your preferred dealer dont ya?
