Baofeng UV-6R Review (Ham radio / walky talkie)
knowing Very little about radios—can this be used as a radio scanner to monitor
local emergency agencies like CalFire and others?
Thanks for the review.
A question along Travis’s line, do these scan the UHF channels?
Yep, albeit rather slowly. You can either scan the full VHF or UHF frequency range supported by the radio in the increment that you choose, or else put it in channel mode and scan all of your saved channels in whatever band or order you programmed them in.
This looks like another great Baofeng product. Thanks a lot chrisc for the excellent review and comparison. I might have one of these coming in the mail, although the eBay seller’s account appears to have been suspended so it could have been a scam. At any rate, the only important difference I can see compared to my UV-82 is the lack of a metal chassis on the UV-6R, which is a bit of a regression in my opinion. It also doesn’t have the compact good looks and clean lines of the UV-5R or the traditional Motorola “professional radio” look of the UV-82.
Do you think the 8W models are worth the (slightly) higher price? Any measurable difference in performance compared to the normal 4-5W models? Can you tell if the TP actually puts out the advertised 8W?
Depends, some of them are switching to private trunked Motorola systems which, in addition to being digitally encrypted, are also in a higher frequency band that is out of the range of all consumer HTs.
Thanks sb. Are these items another interest of yours?
Thank you chrisc. Great info.
For folks knowledgeable in US laws, can this radio be used by someone without a Ham Radio License if they stick to certain frequencies? If yes, would it have greater range that typical higher-end non-Ham walkie talkies under similar conditions (osticals, etc?
How come label on the radio in the OP is labeld "Baofeng", but the labels on the BG product page say "pofung"?
EDIT: Content added.
Yep. :slight_smile: Always has been, although I never owned a VHF / UHF / ham radio until recently. I’m seriously impressed with my UV-82 in terms of build quality, features, and reception for the price.
“Pofung” is another brand name created by Baofeng as an attempt to make it more pronounceable in the Western world. Apparently the Chinese phonetic pronunciation of the word “Baofeng” is actually closer to “Pofung”. But the Baofeng name is already quite famous worldwide, so they also continue to sell units under that brand name. They’re both identical otherwise.
https://baofengradio.us/pofung-radio
Short answer: No.
Longer answer: eeeehhhh… It’s likely that no one would find out if you were using it on (for instance) FRS or GMRS frequencies. I wouldn’t do it (I already have an amateur license), but, hey, it’s a free country!
What a great piece of information. Thank you SB :)
Much appreciated Herb. Getting the basic license has been on my wish list. I have obtained materials to study to prepare for the test, but I'm still dragging my feet on the actual studying.
A ham buddy has a SWR meter and one day we got tired of lights, cars and other stuff and decided to measure all HTs we had flying around! The 8W on the latest Baofengs is an actual improvement, the meter showed approx. 7.5W (analog meter, so not very exact).
I personally don’t think I’ll need more than 5W power as most of my repeaters are not far away and my other use cases are driving with friends, shopping malls or something like that.
The UVR5 TP I bought was from Sainstore nextbigthink and was on sale/the same price as other 5W were advertised.
I am pretty sure Baofeng is like the ThorFire or Convoy of ham radio.
Also the extra power on some of the rubbish antennas could be more harm than good. They aren’t known for being the best tuned antennas but the radios are really hardy and dont mind a massive antenna mismatch.
Thanks for the informative review! I remember being interested in HAM radio in my earlier days. At that time the radios were HUGE and you could talk to people all over the world. Are the current radios still so large and how does the UV-R6 compare to those radios ability to communicate all over the world? Also, how does one go about obtaining a HAM license (testing, cost, etc.)? Lastly, the UV-6R appears to be out of stock at BG currently, would you recommend the 5R or waiting for the 6R?
The range all depends on the frequency being used. The 2m (144 MHz - 148 MHz) and 70cm (420 MHz - 450 MHz) very-high and ultra-high frequency bands that Baofeng supports definitely won’t work for worldwide communication, in fact you’ll be lucky to talk to the closest nearby city. The ham frequencies that are good for communication across the world or to the ISS are in the low, medium, and high frequency bands (ref), and the Baofeng models don’t support those bands.
Make sure that you can legally use the Baofeng models where you live, and on what frequencies. If so, there’s definitely no reason to wait for the UV-6R, although you can readily find it on eBay if you prefer its styling. Inside the shell, it’s basically a UV-82, which is also an excellent option. The UV-5R is also great, as are the BF-F8+ and GT-3 Mark-II and Mark-III.
Thank you sb! So, in light of what you stated regarding reception, what exactly is the a radio like the UV-6R used for and how does it differ from a walkie talkie?
There are hams that use them for chatting with other local hams, and some areas have repeaters with high antennas that allow them to extend the coverage a bit. But aside from that, they’re mainly useful for groups of people or organizations / companies to communicate with other members within a fairly small local area. In that sense, they are basically walkie talkies, in other words, handheld radios. The Baofengs are just special because of their affordable price and feature set, combined with removable antennas and batteries and higher transmit power compared to the little FRS radios that they sell in plastic packs as outdoor sports accessories. The Baofengs can also be configured to communicate with those FRS radios, but again it’s a legal gray area in many countries.
OK, so basically they are a super long distance walkie talkie? So, if one purchased multiple UV-R6’s, this is something that one could use to communicate with friends and family within their town for example?
Super flexible, I’d say. And yes, they should be sufficient to communicate with friends and family within their town, but there’s a lot of factors that can drastically increase or decrease the effective range.
How about the licensing; what is required and how much would it cost?
