[REVIEW] Thorfire TG06S (XP-G2, 1xAA/14500) (Pictures, Beamshots, etc.)
17 posts / 0 new
SoCalTiger
SoCalTiger's picture
Last seen: 1 month 1 week ago
The Thorfire TG06S is an upgraded version of the TG06 which is the successor of the TG05. The TG06S is Thorfire's current "flagship" 1xAA/14500 light and also their newest product. The TG06S is a tube-style light which utilizes a Cree XP-G2 in a throwy polished reflector. Output is speced at a max of 500 lumens when powered with a lithium-ion 14500 or 150 lumens with common AAs (NiMH, alkaline, etc.)
I had the opportunity to evaluate the new Thorfire TG06S and was provided a copy for review by Thorfire. I was really looking forward to this because I am a big fan of EDCs which accept common AA and AAA batteries in addition to having a 14500 option (for AA lights).
http://amzn.to/2p62Ipv
COUPON CODE: MQHZYUZC
Official Product Specifications
  • TG06S LED flashlight is the upgraded version of ThorFire TG06 flashlight. TG06S has 5 modes: High-Mid-Low-Moonlight, hidden Strobe. gives out MAX 500 Lumens
  • Extremely Bright Mini Light: TG06S flashlight uses single XPG2 LED, gives out MAX 500 lumens when powered by premium 14500 battery(NOT Included).
  • Multi-functional Light: High(500LM) - Middle(200LM) - Low(50LM) - Moonlight (1LM ) and Strobe , perfect for daily different applications
  • Durable: aircraft graded aluminum alloy to ensure durable, sturdy, non-slipping performance
  • Package Includes: 1x TG06S flashlight; 2x spare O rings; 1x manual and helpful customer services.
New Features on TG06S
1. More Modes: When use premium 14500 battery, the brightness can be High(500LM) -Middle(200LM) -Low(50LM)-Moonlight (1LM ), and Strobe(500LM); When powered by AA battery, the mini light gives out High(150LM) -Middle(80LM) -Low(20LM)-Moonlight (0.5LM ), and Strobe(150LM)
2. Easier Operation. Fully press the turn on/off, tap to change modes, double tap to activate Strobe mode for emergency.
We still keep the old features on TG06S as below:
1. The lightweight makes the newly designed ThorFire TG06S fits easily into your pocket, backpack, purse, or tool bag.
2. With one considerate metal clip, you can clip it to your shirt pocket.
3. It is great for multiple indoor and outdoor applications including searching, camping, hiking, or even use as an emergency light when suffering a power outage.
4. One cooler thing is that the O-ring behind the lens glows in the dark, which makes it easy to be found in the dark.
Warranty
ThorFire promise to offer 40 days money back and worry free customer services, if you encounter with any question, please contact us.
Technical Details
Item Weight:  1.6 ounces
Product Dimension: 4.3*2*1.6 inches
Packaging and Contents
The TG06S arrived in a small "no frills" cardboard box. The light itself was in a small bubble-wrap tube along with a pocket clip (installed), 2 spare O-rings and the manual. The contents were sitting on top of black foam for additional cushioning during transport. The packaging is more than sufficient in addition to the mailer packaging. There is no significant risk of damage or scuffing to the light during delivery using this packaging. This packaging is better than I have seen for some other lights (in other lights I've experienced scuffed finishes from poor packaging).
Fit and Finish
The TG06S has smooth black anodizing. The anodizing was applied well and my copy did not have any notable defects in the finish. In many pictures, the finish looks glossy black. However, in real life, it is a nice non-glossy sheen. I feel that this finish looks very nice and professional in quality. This is the level of quality that I expect at the price point of this light (many cheaper lights have an overly glossy or painted-on appearance).
The body of the light is a tube design which is cylindrical with the exception of the base of the head which has a hex-cut ring. The hex-cut is smooth with no sharp edges and transitions smoothly and cleanly to the tube. This feature is a nice addition as it adds character to the appearance of the light as well as practical roll-resistance.
The center and tail of the body has a subtle diamond pattern knurling which adds grip, a clean look, and some scratch resistance. The knurling is not overly aggressive and it feels good in hand. This is perfect for use bare-handed.
The front and rear threads are square and very smooth. The tail threads much smoother than my Nitecore but not quite as smooth as my Convoy.
The tail thread is anodized to allow for mechanical lock-out.
Clip
The TG06S includes a pocket clip, which was preinstalled on the tail end for carry with the light facing down. The clip can also be installed on the head end for facing the light outwards (such as if you wanted to install the light on the bill of a baseball cap). The clip is secure and would be relatively hard to accidentally remove. Keeping the clip installed also adds a significant level of roll-protection.
Tail Stand
The TG06S can tail-stand on a smooth and level surface. However, because the contact surface of the ring on the tail is less than 50% of the ring's potential diameter (it is not a complete circle), it may fall on an uneven surface and can be disturbed by movement.
User Interface and Modes
The light uses a standard reverse-clicky in the tail which utilizes full and partial presses.
Output is ordered H -> M -> L -> ML. (This is my preferred order for smaller EDC lights)
There is no mode memory so the light always activates on High.
Strobe is hidden (double-click).
Operation:
  • To turn the light ON or OFF, the tail switch is depressed fully.
  • To advance modes, the tail switch is depressed partially (light press).
  • To activate strobe (hidden), the tail switch is depressed partially twice in rapid succession.
Battery Support and Fitment
The TG06S can be powered by either lithium-ion 14500s (INR, IMR, ICR, etc.) or common AAs (NiMH, alkaline, etc.) The highest output will be achieved using lithium-ion 14500s.
When using AAs, I recommend using rechargable NiMH batteries such as Eneloop because these rechargables will not leak the same way that alkalines do. If using alkalines, be sure to replace them frequently especially once they are drained. Alkalines are most likely to leak in hot environments (like in a car) or when drained. For long-term storage such as a light left in a car or emergency kit, you may also use lithium-primary AAs (ex: Energizer L91).
The 2100mAh LSD Eneloop AAs fit fine with room to spare on the tail spring end without putting too much pressure on the spring. I do not have the high capacity 2550mAh Eneloops (which are physically wider) to verify fit.
The un-protected Windyfire 14500 IMR fit fine.
Protected Batteries: The EVVA Protected Sanyo UR14500P fits completely fine length-wise at 53mm. However, the width provides a little bit of resistance when inserting or removing the battery. The width is not concerning. However, removing the battery required either shaking the light or removing the head to push from either side.
Button vs Flat-Top: Either button-top or flat-top work fine.
The positive contact is flat. The negative contact is a firm spring.
Output, Runtime and Power
I measured light output using a quasi-integrating sphere.
Using the Windyfire 14500 IMR battery gave roughly 20-25% more output than using the EVVA Protected Sanyo UR14500P.
Current measurements were done at the tail cap using a DMM.
Just for giggles, I threw in a comparative measurement of an old 4D incandescent Maglite. The TG06S is 8 times brighter than the Maglite when powered by a 14500 and just over 2 times brighter when powered by 1xAA.
PWM
The TG06S driver does use PWM (Pulse Width Modulation). This light uses PWM in ALL modes EXCEPT full-power with AA batteries. Personally, I am not sensitive and did not notice it in practical use with this light. For my use, the frequency was fast enough that it is not an issue. The frequency appears to be slower at lower output.
Beam Profile
Moderately Throwy. The TG06S uses a domed XP-G2 combined with a polished reflector so the hot spot is relatively tight with a somewhat defined corona that transitions nicely with a reasonable amount of spill.
Beamshots, Color Temperature and Tint
I estimate that the color temperature is right in the neighborhood of 5500K. When white-balanced in Adobe Lightroom against "Daylight 5500K", the beamshots appear neutral. The light appears pure white in practice.
Personally, I would love if they also had an option for a warmer tint in the neighborhood of 4000K.
Regulation
When using an Eneloop AA NiMH, this light exhibited a gradual ramp-down of roughly 10-12% from activation during the first 2 minutes which is not noticeable during use. After that, this light does not appear to step-down any further during the first 10 minutes.
Even when powered by AAs, due to the small form-factor, this light becomes hot at the highest setting if you are using it for extended periods of time at room temperature. I would not leave this light on unattended with a lithium battery. Like most powerful EDC lights this size, they are designed to be used briefly if at full power.
Lock-Out
The tail-end can be mechanically locked-out with just a slight twist thanks to the anodized tail threads.
There is no electronic lock-out.
I recommend locking out the light if there is a possibility of accidental activation.
Summary
This is a good well-built AA/14500 light. The body is light and thin and would be good for EDC. The finish looks excellent, is clean and my copy had no defects. The modes are well-spaced with a perfect moon setting and a hidden strobe mode. The beam profile is moderately throwy and the color is cool white.
Save
Save
Save
Save
Save
Save
Save
Save
Save
Save
Save
Edited by: SoCalTiger on 05/16/2017 - 11:26
Muto
Last seen: 3 hours 49 min ago
Nice complete review!
Got this one a week ago and like it, but the moonlight seems to be higher output than the old model.
Tint is better however.
Thanks!
Keith
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
SoCalTiger
Thanks! I don’t have the old model to compare it to but I thought that the tint was great. Definitely a good EDC IMO. With a 14500 the High is great to impress muggles with given the size.
Thorfire
Thorfire's picture
Last seen: 1 month 4 weeks ago
Thanks for the nice review. Now the TG06S is on big deals to all BLF friends. Use this coupon code (MQHZYUZC ), you could get one TG06S for ONLY $10.99.
Purchase Link: http://amzn.to/2p62Ipv
ThorFire is looking for dealers/retailers/distributors from Europe countries and other countries around the world. If you are interested, PM me!
NeutralFan
NeutralFan's picture
Last seen: 23 hours 16 min ago
Nice thorough review SoCalTiger! Looks like a good EDC.
I’d rather use my flashlight around the house than turn on the lights.
KeepingItLight
KeepingItLight's picture
Last seen: 3 weeks 8 hours ago
Well done!
freeme
freeme's picture
Last seen: 53 min 38 sec ago
@SoCalTiger Excellent job! Thumbs Up
tantrik77
Great review! Thank you.
I was really interested in this light, but PWM is a no-go for me. Otherwise, everything else looks great. If it were constant current, I would buy several.
Dusty
Last seen: 18 hours 52 min ago
Thanks for the great review. I’ve been using one of the older TG06 models as EDC, for over a year. It came up missing a couple of weeks ago, and really miss it. With the offer from Thorfire, I will have the new model on Monday.
The older model I believe only used PWM on low, but I’m not that susceptible, so it works well for me.
Brian
Bug
Jerommel
Jerommel's picture
Last seen: 11 months 1 week ago
I think the tail threads are anodized to prevent wear and provide smoothness, not for lock out, because you don’t need lock out with a reverse clicky switch, because it’s hardly possible to accidentally turn it on and there is no parasitic drain when off.
SoCalTiger
Interestingly enough, I lock mine out when it is in my pocket. I tend to fiddle with my hands when idle. I also keep chapstick in one of my pockets and frequently find the tube unscrewed, etc. I guess I could subconsciously screw the tail back on and them press the button but that hasn’t happened yet. haha
Jerommel
Jerommel's picture
I said that because i have some lights with bare aluminum threads, and when you lubricate them (silicone grease), the aluminum seems to dissolve a little and you get that grey goo as a result, which doesn’t help making it go smoother..
Candle wax works better though, but is a little hard and crumbly.
So the anodized threads are definitely a plus on this (or any other) light.
SoCalTiger
Jerommel wrote:
I said that because i have some lights with bare aluminum threads, and when you lubricate them (silicone grease), the aluminum seems to dissolve a little and you get that grey goo as a result, which doesn’t help making it go smoother.. Candle wax works better though, but is a little hard and crumbly. So the anodized threads are definitely a plus on this (or any other) light.
That’s interesting. I know that silicone grease is a no-no because it can react with silicone O-rings but didn’t know that it could react with the aluminum as well. Are you sure that the grey goo isn’t the result of reacting with the O-rings?
Jerommel
Jerommel's picture
Yeah i’m quite sure.
It’s even worse with thermal grease, like Fujik etc..
Never had any problems with O-rings though.
I used to have a small syringe with silicone grease, but now i have “Yezl” silicone grease (Fasttech), which is more solid, less runny.
SoCalTiger
Alright, I’ve made several improvements to my output measurements:
1) I realized that my current measurements were inaccurate due to using poor leads on my DMM. My updated numbers should be correct now.
2) I re-calibrated my output measurements so these numbers are now estimated lumens.
3) For “High”, I show both the peak output and output at 30 seconds.
4) I added % Output and % Amps columns.
Finally, just to make sure no one misses the coupon code:
Thorfire wrote:
Use coupon code (MQHZYUZC), to get the TG06S for ONLY $10.99.
Jerommel
Jerommel's picture
Interesting.
Less output with protected 14500.
I think that means there is no current regulation on 14500, only PWM, but basically direct drive.
The XP-G2 can handle that though.
SoCalTiger
Currently $9.90 on Amazon (US) after coupon code.
http://amzn.to/2znBCyk
40% OFF Coupon Code: 8YGYJ38C
