Today three of my lights that where using 105C/D drivers with that crappy stock firmware got a new life.
Convoy C8 with dedomed xp-g2 led running on 12 7135 chips
Convoy S2+ with Nichia 219C led running on 8 7135 chips
UF SK98 with dedomed xp-g2 led running on 6 7135 chips
I flashed their drivers with biscotti firmware. It was first time i did something like this so i may say that i leveled up my skills. Following some instructions that i found here on this forum made this much easier than expected, 10/10
Nice job BobbyMK. FW editing and flashing was sort of a leap for me, but as you said it really wasn’t too hard with the documentation on the forum. It really opens up a new area of customization.
A few odds and sods. Successfully rolled and brazed .25mm sheet brass into an 18650 tube for woodifying the thinner 18650 host tubes that are only ~20mm OD at the o-ring lands(S2+, X6, E2L, etc). Also a few coats of epoxy on a mahogany tube and filled a custom copper C8 spacer with an aluminum slug tapped so it can be screwed to the stock pill(old style).
Today, I finally did a mod where I could use a Khatod quad optic, which is quite a bit taller than the Carclo.
Astrolux K01.
Removed the reflector and single MCPCB (which, oddly, was a 16mm DTP copper, even though the cavity can take a 20mm) and measured it against the T-pad/Khatod and found I would need about a 5mm spacer. I had an S2+ copper spacer from Mtn, but it was closer to 10mm. I managed to grind and file it down to an appropriate thickness.it slid in nice and snug with a little Antec 7 diamond thermal compound… I had to grind the bottom half of the legs on the optic to match the MCPCB, which didn’t leave much material, but enough, to fit in to the pill.
For now, I just reused the stock driver and wires.
I am extremely pleased with the result! The only T-pad I had already populated had some XP-G3 S5 3A. These optics are, as I had hoped, way more narrow than a 10507 Carclo. It is almost as narrow as the stock reflector, but has 4 LED’s feeding the spot!
I can’t wait to check it out in the dark!
I’ll probably swap the driver out eventually for something with active thermal management and do a spring bypass in the tail, but I’m real happy with the way it turned out!
A teaser for a scratch-build I’m planning. It will be a 7x C8 reflector light with dedomed XPL emitters. 125mm diameter head. 2s 26650; the same electrical setup as my 7xXPL convoy L2. The drawing is actual size, with a convoy C8 for scale.
A drawing of the head, with my 7xXPL L2 for scale.
Should do around 9000 lumens OTF and 800+ Kcd. Made from “off the shelf” aluminum plate and tubing.
After my UF1504 only put out around 200kcd I figured the bottle neck was that dang half inch long solid brass button resting on the tailcap spring. I don’t understand why brass buttons are used. I always have to drill through them. Drilled a hold down the middle and ran a bypass wire up through. Hoping that will at least double the throw numbers. Haven’t taken measurements yet.
Modded a threaded copper pill from Rey Ti , added a 16mm round copper plate to make the flat surface on top , all using only hand tools , and installed a fet driver and nichia 219b hi cri leds on KD board and optics :
Added some solder on the bottom , now even flat top batteries work :
And inside the head :
About the tube , i shortened it using the human lathe method kyfishguy described :
It could be better of course .
Changed tailcap’s spring to a bigger and more flexible one :
Khaki painting was in pretty bad shaped , so i removed it from the areas without knurling .
And final product :
Thanks to kyfishguy for helping me , and Lexel for providing the light .
It’s great to see you’ve finally completed your triple micro mag. It looks great and I bet it puts out a pretty wall of light! That seam on the battery tube actually looks pretty good, did it take much adjusting to function smoothly or was it one of those rare ones that goes back together great on the first try?
The battery tube came pretty good , i was modifying it and testing it back again for 2-3 times until i get a good fit , without creating much resistance .
Love the mod George and good to see Justins traditions being carried on. I’ve said this before and will more than likely say it again, The AA Maglite would have to be one of the best looking lights on the market.
