Review: Manker E14 II Pocket Dragster Floodlight (18650/18350 - 4 XP-G3)
28 posts / 0 new
Budda
Budda's picture
Last seen: 3 days 12 hours ago
I received the E14 II from Manker for the review.
The E14 II is an upgrade to the previous E14.
The light shares the overall look of the previous model, with the big and heavy copper head (with a transparent coating that protects the material from oxidation) that hosts 4 emitters with flood tir optics, but there are several differences.
The light comes in this box. I got the light with clip, spare o-ring, lanyard.
Here is with the old E14
Compared to the old E14, the new E14 II has several differences:
There are 4 XP-G3 emitter, instead of the XP-G2 of the old E14.
The switch is now an electronic one and it is positioned at the head.
The central part of the 18650 body can be removed, obtaining the 18350 body.
The body hosts a charging circuit that is powered with a micro USB port.
Different UI and modes.
Here with the 18650 insert, 113 mm long, and wide 28 mm at the head and 25 at the tailcap.
Here in the 18350 configuration: without the 18650 insert, the light gets shorter and is 78 mm long
The tailcap has a double nested spring
Here’s the micro USB charging port at the head. On the the wide square cut threads will always be some residue from the twisting-untwisting of the head.
Here’s the deep pocket carry clip.
UI
The UI is the classical Manker UI
There’s a led in the charging circuit that is red when charging
And solid blue when charging is completed. Blue flashing in event of not recognized cell.
Output and runtime
Tested with 18650 IMR LG HG2 3000mAh cell.
Note that using non IMR but 10A capable cells, like LG MJ1 will result in significantly lesser output.
At the end of every test the batteries were found around 3 volts, above the minimal voltage recommended for li-ion batteries.
Beamshots at 0.5 meters from the wall.
The 4 emitters give a very wide beam, with a wide bright spill and a big brighter spot.
Without a doubt, a light made for close distances.
My thoughts
  • The light is well built and finished.
  • The light is heavy, but believe me, the higher weight is well compensated by the fact that this light can produce a very high output without melting. It will still become VERY WARM (temporized stepdown).
  • I like the deep pocket carry clip, and the switch at the head makes the light easier to operate.
  • I like the interface that allows quick access to minimum output (that can be personalized as well), turbo and last used mode.
  • I’d like that the turbo mode stepped down to a higher output mode, maybe around 1200-1500 lumen mode. And a thermal control wouldn’t hurt either.
  • I’d like an higher high mode and with better regulation.
  • I’d like the charging colors to be red (solid charging, flashing when battery is not recognized), and green (charging finished).
  • I’d like the electronic switch to be bigger and more stiff to operate.
The E14 II adds some improvements to the old E14:
  • Smaller size
  • Integrated charge
  • No need to purchase the separate 18650 tube
  • Better Interface
But remains a “dragster” flashlight, pushed on the edge of its capability at the turbo mode. Remember to use high quality IMR cells in this light.
Thanks to: Antoled for the camera advices, the camera help, the E14 and the luxmeter.
More (thermographic) tests will follow.
Here are all my reviews on BLF
Edited by: Budda on 05/07/2017 - 19:28
CRX
CRX's picture
Last seen: 3 days 20 hours ago
This looks good, would be nice to know how does the LVP and thermal regulation work, what is the USB charging current? Glued?
Dragon breath mode, love it LOL
Would be a great light with a different driver.
Anthon
Last seen: 3 weeks 2 days ago
Stepdown from 2700 to 133 lumen in less than a minute? I think the UI is a total deal breaker…It lacks a thermal regulated mode of around 1200 lumen where turbo stepdown should stay
Great review, thank you for showing use these two new models
Jerommel
Jerommel's picture
Last seen: 11 months 3 days ago
Very nice photo’s, but do they have to be 1 MB each?
Page loads a little slowly over here..
About the light, i think the guy who designed the copper part didn’t care about the rest of the parts or the Manker (mateminco utorch astrolux) look.
Looks a bit like it doesn’t belong together.
(i.m.h.o.)
Muto
Last seen: 3 hours 13 min ago
Dragster?
Or Pre mature Ejack?
40 sec of spunk.
Fail
Nice review however!
Saved me $
The difference between Hoarding and Collecting is the illusion of Organization
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
my9221
Last seen: 1 hour 28 min ago
Beautiful light. Thanks for the lenghty review and pics!
deleted-200707
Last seen: 9 months 2 weeks ago
the switch is in the hottest point in the whole light?
BeardedRaleigh
BeardedRaleigh's picture
Last seen: 1 hour 59 min ago
Iv’e grown fond of “E-switches” I like it.
Slow is smooth, smooth is fast.
RollerBoySE
RollerBoySE's picture
Last seen: 4 days 10 hours ago
Thanks for the nice review!
Can it show the charge level?
maukka
maukka's picture
Last seen: 3 weeks 5 days ago
Thanks for the review. This time there’s more differences between the Manker and Astrolux variant.
RollerBoySE
Hmm, no copper and probably different driver (retaining ToyKeeper’s UI, which is excellent).
It sure makes you wonder how the relationship between Manker/Mateminco/Banggood/Astrolux works…
Edness
Edness's picture
Last seen: 1 week 2 days ago
Muto wrote:
Dragster?
40 sec of spunk.
Fail
Saved me $
yup…I just bought another S41. That’s the 4th one for me. It’s so mod friendly!
stephenk
stephenk's picture
Last seen: 18 min 27 sec ago
Holy step down Batman!
deleted-200707
my s41 w/vtc6 gets so hot I can’t hold the endcap after a few minutes
so how the hell can I access the finger burner switch on that copper head in order to turn it off?
deleted-200707
OK, another use for my stylus/pen
michael.k
michael.k's picture
Interesting light .
I hope output on turbo could be better .
texas shooter
Last seen: 3 hours 47 min ago
So, anyone see a price yet? Plus, Budda are the threads inter-changeable with the BLF/Astrolux. Specifically all of them from the bezel down. I’ve got the BLF A6 and four Astrolux; one S41, three S41S. Big selling point is all parts interchange. This would be a nice Lego addition.
firedome
Thanks for the review and photos. Thumbs Up
We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light --- Plato
hIKARInoob
hIKARInoob's picture
Last seen: 1 day 6 hours ago
Gone in 60 seconds
deleted-200707
BatDude prolly don’t need “roll of quarters” in his utility belt, butt I do!
TBone
On your photos of the two lights the head of the E14 II looks more yellowish, like brass. Is Manker saying somewhere that it is copper?
TBone
Hm. I love to have the last word but this is a bit scary.
They do not even claim it is copper? So we carry around three times the weight for nothing?
At least it looks good.
Budda
Budda's picture
patmurris
patmurris's picture
Last seen: 4 hours 45 min ago
What unit are the temperature reading? Tell me it’s no Celsius degrees! Evil
I have the full aluminum Astrolux S42 on order… I’m curious to see if it behaves the same on turbo… or how fast it melts.
SteveMidwest
SteveMidwest's picture
A batch of these Manker E14 II’s have made their way the the U.S. this week, Wednesday. But with the Blade Show going on in Atlanta, Friday through Sunday. No one has had time to unpack them yet. Tired
Lightbringer
Lightbringer's picture
Last seen: 2 hours 35 min ago
Jerommel wrote:
About the light, i think the guy who designed the copper part didn’t care about the rest of the parts or the Manker (mateminco utorch astrolux) look. Looks a bit like it doesn’t belong together.
Yeah, gotta confess I like the original way better’n the II.
RollerBoySE
Agree.
I alteady have the original E14 with 219C, so I will pass on the new one.
SteveMidwest
I passed on the first one, because the copper alone was not enough to sway me all on its own. It had a run of the mill lumen count, and we had to purchase a second tube, to run a 18650.
Now this one does it for me. I am not after the usb charging, but it’s a nice perk!
