making 3. Batch Texas Avenger "TA" / Bistro HD OTSM drivers fully tested running Bistro or Narsil, Clicky or E-switch, SIR800
196 posts / 0 new
Lexel
Lexel's picture
Added info about the springs, to stay below 10mm envelope thickness is 2.2€ cheaper to ship, so they are not soldered to the boards
I will start ordering parts, ask for Narsil configuration and send payment instructions the next days
steve42
Last seen: 9 months 2 weeks ago
Quick question: I’m building out 2 jaxman E2L triple hosts (single 18650 cell, nichia 219c leds) with clickie switches. Is there any advantage to having the Bistro HD OTSM in my 17mm drivers?
OK, found the answer & yes, put me down for Bistro HD OTSM
3/26 Flintrock wrote: “OTSM. (I think TA named it that). I think it means off-time sleep mode or something like that. It’s the replacement for OTC in bistro HD. It means that the length of a medium click is as steady as the watchdog timer, which as far as I can tell is about 10% even when hot, which is much better than many caps. It’s also not sensitive to all the resistor tuning that the OTC is, so should eliminate those headaches.”
http://budgetlightforum.com/node/41067?page=63
steve42
Texas_Ace
Texas_Ace's picture
Last seen: 18 hours 19 min ago
Yes, the OTSM is by far the better option. The old OTC is the largest complaint I have had with BLF drivers by far.
Jensen567
Last seen: 2 years 7 months ago
Put me in for a 17mm and 30mm. 30mm w/ e-switch, 2S (5V cutoff) and Narsil. 17mm with Bistro HD, 1S, 2.5V cutoff.
Lexel
Lexel's picture
I highly recommend 2.8 or 3V LED cutoff voltage, down to 2.5V there is almost no capacity and the cell ages a lot more when discharged that low
Lexel
Lexel's picture
I am sending out the PM requesting for final information which hard and firmware settings people want
on first PMs there was an error stating Narsil v1.4 has no LVP this is only for 2S configuration
Also Narsil with a tail switch there are different options how the light reacts when the driver gets powered up
Lowtech
Last seen: 1 year 1 month ago
What options?
JasonWW
JasonWW's picture
Last seen: 18 hours 34 min ago
Lowtech wrote:
What options?
Lights like the L6 with tailswitch can be set up to go in turbo when battery power is applied (called “tactical”), or 2 low blinks or nothing at all – Lexel
Lexel
Lexel's picture
NarsilM has cut the option in advanced settings to memorize last level, making the settings UI easier
first boards ordered from Oshpark
KawiBoy1428
KawiBoy1428's picture
Last seen: 3 days 14 hours ago
Thanks for the PM Lexel! Letting you know, I just now received the (6) 30mm drivers from the first batch, and they look very Professional! Great Job my friend!!! Beer
KB1428 “Live Life WOT
steve42
Lexel; If its not too late to easily add 1 more driver-everything identical-to my two 17mm bistro HD OTSM please do. I’ll add $ to my total & paypal once you let me know. Cheers
steve42
Lexel
Lexel's picture
Topic is now change from interest list to making 3. batch
Excel sheet updated
check if the order is listed there correctly
PM are sent to all
requested for detailed information how you like the drivers configured and which shipping service to estimate final pricing
Payment can be done in € as well, with Paypal exchange the currency the fees they charge me are ridiculus high,
makes only sense if you have Euros or not USD as your currency
doing paypal transfers fill the right side out, so it calculates your local currency
JasonWW
JasonWW's picture
Dang. I haven’t got my first one yet, so I don’t know if I should get more. Lol
Lexel
Lexel's picture
the first drivers from last batch arrived in USA, so it will be there soon
just couldnt find the tracking receipt for your driver
JasonWW I will try to find the receipt with the tracking number when I visit my parents tomorrow
steel_1024
steel_1024's picture
Last seen: 2 days 19 hours ago
(SMT Stencil) Order from China, very cheap, for TA series
Sorry for my poor english.
Texas_Ace
Texas_Ace's picture
Not bad, if you could get the PCB’s printed out as a panel then you could solder paste them all at once and save a ton of time!
Lexel
Lexel's picture
I would need one of those sheets, but with the different sizes for TA drivers, also including the AMC7135 side, but I got no clue how to get those Oshpark files into one mask that contains all those sizes on one stencil plate
Then cut out the different sizes into round form to place em on top of the board
Lexel
Lexel's picture
ordered today the 46mm boards
I did order last week the first boards (even before i bothered to send out PM for driver details or payment instructions)
and they got shipped today
I hope springs from kaidomain and 400 AMCs ordered as wqell last week from Aliexpress will arrive not with too much time delay
Texas_Ace
Texas_Ace's picture
Don’t bother trying to get them all in one sheet, that would be WAY harder to deal with then just getting them individually. Just make sure to label them so that you know what is what. You can also reduce the edge clearance to the smallest they allow with this tiny drivers, there is no need for all that extra space.
Lexel
Lexel's picture
as this stencil sheets are quite big I just would put costwise all stencils on one big sheet and cut em out later
Texas_Ace
Texas_Ace's picture
They charge by the inch, so the total cost would be able the same buying them together or separately. unless you squeezed them together really close, which would make it very hard to handle later when you were actually using it.
Lexel
Lexel's picture
on this one sheet you could place all sizes of driver stencils
the cost for one of those frames is always the same in those chineese shops, but I found only pretty expensive ones
Texas_Ace
Texas_Ace's picture
Well, if you are ordering from some other stencil manufacture then yes, the pricing could be cheaper. From oshstencils though it would be able the same price due to how they charge by the inch and not by the sheet.
Lexel
Lexel's picture
Excel sheet up to date
missing only a few ones
please check if the information of drivers, settings, shipping and address is correct
JasonWW
JasonWW's picture
Do you have a 30mm available? You ordered 7 boards and have 7 orders, but it says you have 2 on order? I’m not sure I understand the chart.
I like my first one a lot. Is it possible for me to order a 30mm or is it too late? If too late, will there be a 4th batch?
I was hoping for a 30mm 2S LDO Narsil v1.2 with LVP, large spring, (tail switch – no output)
Tjhosan
Tjhosan's picture
Last seen: 2 years 3 months ago
If not to late i would like to order
1× 17mm Bistro HD OTSM 2s LDO no spring
1× 17mm Bistro HD OTSM no spring
use lead solder on both
Lexel
Lexel's picture
7 boards 30mm are requested so far
9 boards ordered from Oshpark, 6 last week, 3 yesterday as I got past 6 boards
So I got 2 boards that are left, like the 15,20,21mm that are left from last batch
From Oshpark you have to order 3,6,9 aso.
Thats Why I say big sizes makes no sense if I got only one requested and have to buy 3
Its no problem to make more drivers atm, if needed I will order more PCBs from Oshpark
But
when first Oshpark boards and the AMC7135 arrived here, then I am going to order parts from Digikey which get delivered within 2 working days UPS express
At this point the parts for a few more drivers are within that Digikey order for the case I screw up destroying a component building the ordered drivers.
Thats the phase, where I can add a few more orders and thats it for this batch.
Sprinkles
Last seen: 2 months 4 days ago
Question regarding LVP in Narsil – can it be calibrated/set through the config settings or just in code before it’s flashed to the board?
My driver is going in a modded T01, so I’m trying to determine specs ahead of time unless it’s possible to do it in config.
Thanks!
EDIT: found the answer – it’s done in the firmware before flashing. I like the default lvp stepdown. Nicely done.
Lexel
Lexel's picture
Yeah Tom E changed LVP to 2.8/3V for the Q 8 before it was 3.0/3.2V I can calibrate that to any level you want, 2S needs modified voltage divider And then change the setting before flashing to match 2S LVP
For medium single LED lights or big multi LED lights I recommend Over Temp Protection of 60-70dC
If your light has a tailswitch as well you can choose how the driver reacts to be powered on with a forward clicky tactical with turbo makes sense
Lexel
Lexel's picture
more 30mm driver requests come in
I ordered today 6 more 30mm boards, but those drivers ordered lately will be ready a bit later as those boards will be produced almost 2 week later than the first
For Bistro OTSM 2S I got the information it may be running only with LDO properly, I asked flintrock if this is the case
