I could have done this instead of searching and probing for a positive battery source? I didn’t bother to check this because I assumed it only had power when the main beam was turned on.
Well what I said above applies to the BLF FET drivers in reply to DB. Some buck and boost drivers do switch the positive side, so you need to see if yours is one of those. If so then you can usually tie into the LED ground and then into a voltage source.
The easiest way to find the V+ voltage source is generally to look for the vias from the spring and see where they come up and follow them to the first easy to tap into location.
Okay, so it’s best to take it case by case. Don’t assume. Just apply power to the driver and probe around to make sure you find a good voltage source.
My next driver is going to be one of yours and it has a spot to add a “power on” led. Now since the led has to use the same negative wire as the momentary switch, can you tell me which pad is positive and negative?
I labeled them A and B.
Hmmm, maybe it’s not important. I can try the red switch wire to A and the blue switch wire to B. If the LED doesn’t light, I can switch them around.
Nope, that could damage the driver. Pad A is for the red switch wire and pad B is the ground so that gets the blue switch wire.
Oops, forgot the picture.
If you are using narsil with the indicator LED then it needs to go to the correct pin, no idea which one that is as I have never used it.
If just having it on anytime power is applied then it would work the same as I listed above, you could use the bleeder resistor pads as well.
I’ll have Narsil v1.2.
I’m not using the “indicator” led. I’m not sure what it’s supposed to be used for actually, but I just need a simple light to tell me if the rear switch is on or off. Nothing fancy. Positive power to the switch LED is shown on the picture above (lighted side switch). I’ll use a smd resistor to drop the power down.
The negative side of the switch LED shares the same wire as the momentary switch. So polarity of the momentary switch is a factor.
You can connect the negative wire to any of the locations I listed above, they all go to the same place, the ground ring. Indeed the e-switch ground is perfectly fine.
The positive is the only thing you need to worry about, in the case of the TA driver the easiest V+ is the bleeder resistor, the pad closest to the LED V+ wire.
I think I have it figured out now.
I can see a lot of new folks with the TA driver in an L6 that might want to do a simple lighted side switch.
Well, I tried it and failed… again. I tried to use a 22K resistor but that’s not going to work, not without some form of support, as the end cap simply pulls off the resistor. In trying this, I somehow messed up my FET driver. Ended up removing the SIR800DP FET and replacing it with an SIR404DP. I have it working again, without the lighted switch but with a clear boot cover and led’s on board. Still have to figure out how to power em up.
I now am getting 12.03A at the tail with the Uni-T clamp meter and 7077.5 lumens with these LiitoKala 5000mAh cells.
These pain meds are totally screwing me up! Even the MCU ended up coming off the driver! Heating up the board with my hot air to remove the FET I somehow got the MCU loose and ended up with it literally falling off when I was trying to test everything. One thing after another when you’re mentally least ready to deal with it all, but of course.
What pads are you using? It is a TA driver right?
Try using the bleeder pads for the LED. Do you have a lighted tailcap? If so then yes, that will screw with things. In fact that could get interesting to figure out.
Nope, just a little 17mm MTN driver board. I have a bunch of those and a bunch of Wight’s A17DD S08 boards. Richard had OshPark mess up on an order of boards where they covered the spring pad with mask. They worked it out but he had way too many of these to deal with so I bought em from him, I usually build one at a time compared to his hundreds so it works out for me. I don’t need the extra 7135 chip on a ramping e-switch driver anyway. I also don’t use lighted tail caps as they’re just a battery drain for me. I like draining the battery in other ways.
What do you mean by “the end cap pulls off the resistor”?
Are you using a momentary switch like the one that comes on the FX30 driver that has the extra LED pads built in?
If so, then the polarity of the switch wires becomes a factor due to the traces on the pcb.
Normally it doesn’t matter which switch wire (red or blue) goes to ground and which goes to the “switch signal” part of the driver because it’s a simple contact switch. When you add LEDs, the polarity of the switch wires suddenly become important because the LEDs are polarity sensitive and share a ground wire with the switch.
Since the blue switch wire is a common ground (for 3 things, the switch, the left LED and the right LED) you want to make sure it’s going to a ground source. If it’s not, you need to swap the switches red and blue wires around where they make contact on the driver.
If you switch wires were backward then that might have been what caused your problem. You might have fed 3 or so volts into the switch positive trigger when its designed to only sense ground.
Polarity of the LEDs is also important. They need to be like this.
Now if your using a different momentary switch you’ll need to map out its traces on the pcb. I just used the continuity circuit on my multimeter.
Here is the switch from the FX30 again. All the blue dots go to the blue wire. Red dots to red wire.
Hopefully that will fix you up.
Received shipment of my Shockli 26650 5500mah batteries today. Came with a nice case, carabiner clip, & magnets. They don’t easily make in series contact, without pretty good spring pressure, 65mm long x 26.7mm. Not enough spring reach / pressure without using magnets, at the moment, although I was able to take tail amp readings without.
Got at least an extra +1.0 tail amp measurement (9.71 @ 4.20 volts) with my cheap setup using 6” x 10ga leads over the Keeppowers. They do make the L6 with TA Driver get warm, real quick. Hard for me to get good representative distant pics, differences are more obvious in person. I can fairly easily tell the difference at a 600 feet (200m) treeline. This night shot is 150 feet (46m) to center brush/wood pile & 250 feet (76m) to background trees (just left of the wood pike in bottom pic).
A is positive switch
LED positive are always on the 4.7k resistors
R1 is not populated as Narsil v1.4 does not support 2s LVP
For those that want to use a lighted side switch on the TexaS Avenger FET driver in the L6, here is the basic layout.
My “power on” led resistor broke off when I tried to put test probes on it to measure the resistance. I hope that’s not a sign that there was an issue with the solder paste. Update, I broke the resistor, paste was fine.
Since I’m running 2 leds in parallel I’ll swap that 4,700 ohm resistor for something double in size. 10k to 20k should be fine.
I never could get my meter to read the resistance across it.
Can you elaborate on this?
What types of things would the “indicator LED” show you? Something to do with LVP?
yeah the solder connection is not the issue with this resistor, its just mechanical separated, so the rest of its conductive end still sticks to the solder blob
thos 0603 are pretty fragile if soldered only on one end
Indicator LED on Pin 7 was added in Narsil v1.3
so v1.2 has no indicator LED feature
Indicator LED
When enabled, the Indicator LED can be used for the following:
- to locate the flashlight in the dark (Locator feature)
- to blink out the battery level
- as a secondary indicator of blinking when the main LED blinks
When the Locator feature is enabled, the LED can be temporarily turned OFF (only in Mode Sets), with the main LED OFF, 1 quick click followed by a click&hold til the main LED goes off. To toggle it back on, repeat the same procedure (OFF -> quick click, click&hold). Note the locator feature is turned OFF when the light is in Lock-Out.
Okay, so that’s why the left side of the resistor looks a bit shorter than the right side. The resistor broke! Lol.
That’s why I can’t get a reading from it. :person_facepalming:
I’m glad to know it’s not an issue with the paste.
I just got my TA driver installed. Everything works including the lighted side switch! Yeah, I’m 2 for 2.
It’s pulling 12 amps with the Liitokalas at 4.1 volt. Yikes! It might be higher when fully charged. Maybe I should NOT have used 18ga wires? I need to tone it down a little.
The scary thing is after about 10 or 15 seconds I see the light color start to shift towards blue/purple. I quickly turned it down in brightness. Maybe the 20mm DTP copper star is having trouble with that heat? (EDIT, it was my copper shims, not the star or LED)
I tried my KeepPower protected 5200 and got 9.6 amps at 4.2 volts. No color shift seen.
I think I figured out the color shift I got. I pulled out my super thin stack of copper shims and tightened the star directly to the flashlight head. Now it seems to be working like I expect it to.
BTW, I added orange leds to the switch this time around just to be different. They are not as bright as the whites, but still okay.
Simple little video here for anyone interested.
