TrustFire TR-J12 5*CREE XML T6 from DX MF and KD
263 posts / 0 new
HB021
Last seen: 9 years 10 months ago
Here is lux test with 26650s instead of 18650s compared to 2,8A XM-L C8 and 11w 950lumen desk light:
Tail cap readings are with (4,23v) 3x2,1A and with 2cells 3,3A.
My lights:
Makita BML185 modded with 4x XM-L U2 @ 3A // Dry 5A(ordered) NW & CW // Trustfire TR-TJ 5*T6 // Trustfire ST-50 // Trustfire X8(ordered) // Trustfire 5xR2, Ultrafire C8 XML T6 // Solarforce L2 extended XM-L U2 // Ultrafire C8 XM
mitro
Last seen: 2 years 1 month ago
Ok, I got my TR-J12 today.
King Kongs do not work in 3x 26650 as-is. These cells have a bit of a recessed positive contact and in order to make a connection between the cells enough force has to be applied to squeeze them together. You can fix this in a number of ways, but AS-IS they don't work. I have not tried 2x26650 yet.
I have some IMR BatterySpace 26650s from a while back and they DO work in 3x26650. these cells have a bit of a raised button on the positive end and it enough to make contact. However, connection can easily be easily interrupted with a slight bump. (The good news is that it takes more than a bump to change modes.)
So unprotected cells will most likely require adjustment to work properly. I'll report back later.
EDIT: The positive contact inside the flashlight is either flush with or recessed in that white collar you can see in the pictures, so no matter how much pressure you put on the cells it's not going to make contact. The head either need a blob of solder, a magnet (at your own risk),or a heavy spring. Even then, with the KK cells you are most likely going to need solder blobs on the positive ends or magnets between the cells. On mine, the force required to make a connection between cells is so great I don't think it could be done reasonably. (Think old D Maglite spring levels of force).
Meaurements:
3x26650 IMR- 2.02A
3x26650 A123 (3.2v) cells - 2.4A
xed888
Last seen: 9 months 6 days ago
Nice! I cant wait for your TK70 comparison ! (hint, hint) haha
ah wait! Its ergotelis who's doing that! oops! Big Smile
ergotelis
Still nothing received from KD though...Ahhh cHristmas times make shipping time quite high....
HB021
Im using magnets on my plus side, what risk am I taking buoying doing this?
My lights:
mitro
Just a couple more thoughts/observations:
Nice build quality
Bad PWM
One cell operation - it looks like it goes DD (which I think is what we expected) - 4A on a single KK 26650, 1.6A on an A123 (3.2v) cell
Heatsinking seems good, but I haven't REALLY put the screws to it yet.
KDLST
Last seen: 6 years 10 months ago
Meaurements:
3x26650 IMR- 2.02A
Could you please test if 2 x 26650 works?
mitro
In general? Yes. 2 x King Kongs out of the package? No.
The positive "button" on the KK is the problem. It actually sits lower than the shrinkwrap on the cell.
KDLST
LOL
mitro
I just took out the light meter and got 24.9kcd (249 lux measured @ 10m).
(the cells were not fully charged and the light had been on for about 30 sec.)
dthrckt
dthrckt's picture
Last seen: 5 days 16 hours ago
tip for extending batteries, for those that don't want to solder, and have magnets
wipe anode and magnet w/ acetone or alcohol, put a thin layer of this on anode, then the magnet and let sit overnight (since it isn't exposed to air).
http://www.amazon.com/CircuitWriterTM-Precision-Pen-silver-based-grams/d...
it is basically conductive adhesive but in a much nicer dispenser than a jar.  it costs half as much at radioshack and you could do a few hundred batteries.  Store it tip down or the tip dries and clogs.
KDLST
I guess i'll just solder mine then, seems like the easiest way to achieve a reliable solution..
Still haven't bought a light to use them however. I ordered some king kongs in advance because i was so stocked about the tr-j12 but still haven't pulled the plug...
benckie
benckie's picture
Last seen: 8 years 7 months ago
Bugger about the king kongs
mitro
I attacked the positive contact tonight. It turns out that under that nylon retainer with the brass contact in the center is a spring. I took that brass plug out of the nylon retainer and replaced the spring underneath with a longer/larger one. I also drilled out the retainer to make the hole large enough for the new spring to come through. The spring I used is a standard spring from a Solarforce p60 switch or the like.
Connection is greatly improved. King Kongs still didn't work, but I added a solder blob to all of them and now I'm ready to rock and roll.
I'm only seeing a 5% 4% drop in lux from 10 seconds to 10 minutes. Smile The heat seems to stay in the head, the body stays pretty cool. That would generally worry me, but looking at the numbers (I know its only 10 minutes), it's looking good.
cd520
cd520's picture
Last seen: 8 years 2 months ago
Did you take a peek at the driver?
mitro
I did not. I didn't want to press my luck on the first day. Functionally, the driver is VERY similar to the one in the TR-3T6, just with more power.
2100
Last seen: 3 years 2 weeks ago
HB021 wrote:
Are you saying my 26650's might explode all of the sudden?
For you and many on this site, it is highly unlikely.  For me and some others, we usually do discharge capacity tests (on a hobby charger) on the cells so as to match them for multi-cell operation, in addition to voltage checks everytime we pop them cells into the light.  And remember, you choose/alternate between 2 or 3 cell operation, so you need to check.    2 cells might be at 3.9V simply because you used them for 10 mins before, and the 3rd might be 4.09V.
The thing is, folks are selling such lights on Ebay with grey trustfires, blue ultrafires, and some even noname blue Chinese LiCo.  One cell might have 1500mAh worth of juice, another just 900mAh. How not to expect an explosion?
2 cells are like 3.3A?  That is no joke.
Google reverse charging too....
You can prevent a lot of incidents with just a protection circuit.
But not to worry, it is highly unlikely, but every multi-cell light esp 3 cells, i feel there must be a warning.
mitro
I set out to do a runtime test, but I just got too nervous 20 minutes in. It had dropped about 8% but the head was very hot. I just had it tailstanding with no extra cooling. At the 20 minute mark I started using a hairdryer with no heat to blow on it for a minute or so out of every five. I could get the output to get back about half of that 8%. After a blowdrying session, i tried holding the light in hand for 5 minutes and the output only dropped a fraction of a percent.
The additional cooling was evident in the output within 10 seconds, leading me to believe the emitters are very well heatsinked and the head has a good thermal path.
I could use a fan for the runtime test, but I don't know about you, but I don't have an EDC fan (or hairdryer) and I'm surely not going to hold the light for 2 hours (EDIT: 1:30  - the cells wouldn't last 2 hours), so I'm going to assume it will run for that long provided I can keep it reasonably cool.
cd520
cd520's picture
All things considered thats pretty impressive. I wish this one had a "turbo" mode like the DRY as it seems it would handle the heat much better. On second thought screw the "turbo", I would be happy for 3A per emitter.
2100
Mitro, 4% for 10 mins is really good.  I think you have slightly lower temps than my case, that is definitely in the league of the Uniqurefire 3900 modded with foil and the Trustfire TF-3T6.
25k cd is good too, that is like the DRY in Turbo mode.
Actually my J12 at this moment is already being delivered, but nobody is at home to receive it. So need to collect it tomorrow from the PO and only test tomorrow night....but i guess i'll bring some 18650s and the DMM to play in the office.
So the S1 and J12 will be going to Indonesia soon next week for a full workout.  LOL!
mitro
I ran the light for most of an hour and at any time i could blow on it and get it within 4 or 5 percent of the 10 second reading. Also, the medium is about 65% brightness, so you can still get massive output with a decent bump in runtime.
2100
Yes mitro, the idea of such 3x and 5x XM-Ls is to get massive light output and still be able to do long runtimes without the issue of overheating.
To give people an idea on the big picture, some folks already encountered a kick down from Turbo to high in the Nitecore TM11 before 10 minutes, with this light just trailing a wee wee bit in OTF output possibly.  Yes they are definitely not equal, but just a frame of reference.
http://www.candlepowerforums.com/vb/showthread.php?326290-Nitecore-quot-Tiny-Monster-quot-TM11-(4x18650-3xXM-L)-Review-RUNTIMES-BEAMSHOTS-VIDEO
59 deg C stable, before kickdown.
asd
mitro
Sorry for so many posts, but I forgot to mention that I even fired it up on 4 C alkalines.  4Cs and a little spacer  at the back means that even those who like NiMH can benefit from this light. Smile
I'd like to know if it can take 4x li-on, but I'm not about to find out. Silly
EDIT: I tried 4 x AA Duraloops and got a 3.3A draw to start  and about 75% of the brightness of 3x li-ons. Not too shabby. Also, there is no difference in brightness (less than 0.5%) between 3 fully charged 26650 and 2 fully charged 26650s.
xed888
Music to my ears! I am planning on using 2 cells only! Smile
cd520
cd520's picture
I am absolutely floored by DX's quickness of my order for the TR-J12. In less than 72 hours from placing the order it is shipped with tracking number.
EDIT- and I cant wait to get my hands on this and to see how the driver is set up. This screams to be driven harder from what I am seeing on the reviews. I would love to have a high driving 3A each, followed by a medium at 1.5A.
mitro
Since I like flood I put some DC Fix on the lens and it now has a beam that is just about perfect for me. A huge wall of light. There is still a hotspot but it is quite diffused. The light still manages 10k cd through brute force. Smile
So far I like this light a lot. I wish I'd paid $70 instead of closer to $90, but that's the price I pay for impatience. Its not a revolutionary light, but the combo of 26650's and 5 emitters just works nicely. I'm the opposite of most people here, I wish the medium was actually the high(1.3A on 3 cells) and then give me a lower medium.
By the way... the lens appears to be the same size as the big throwers (59mm), are we ever going to get some decent glass in this size? I don't want to chop up a UCLp. I'm half tempted to just pay for a run of them and then sell them myself.
xed888
if you do get a run, let me know. Im tempted
LEDMatt
Last seen: 8 years 1 month ago
I'm not sure what's wrong with my order. My order was placed on 1-1-2012 and was thrown into their new account management system. It was then labeled as BackOrder on the 4th. I filed a support ticket for this problem. Had this happen to another recent order - waited two months as "backorder" and canceled. Not sure when they will refund me.
Anyone else order from DX? I have the "FandyFire" L1 on its way but would really like to play with this one too.
aoyue2702
aoyue2702's picture
Last seen: 3 years 10 months ago
I got some trustfire flames I bought a week ago that says backorder in their new account management system.
benckie
benckie's picture
So 2100 yours must be here now ?
