✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Lumintop Copper Worm And Nichia 110LM Wateproof Keychain LED Flashlight using coupon 2017fnl drops price from $32 to $21.70.
Last 17 pieces left.
how to use BG point to lower the price? I tried to use it, but it shows BG point can not be used for unbeatable price.
There must be some other item in your cart with unbeatable price - it doesn’t have any special designation beside usual orange Promo tag.
Purchase this item in separate order. You can use check marks on the left side of the item to disable it from current order to see which one is causing the problem.
If that’s not the case or you only have one item in your cart try refreshing your cart and/or clearing browser cache and cookies.
Update: Deal expired.
XANES 300LM Sensing Headlight Night Fishing Cycling Double Light Source Rechargeable Clip Cap Lamp is in preorder for $5.99. ~150 pcs left at that price. Main LED with reflector seems to be Cree XP-E, there’s also COB LED for diffused light. Package includes headband (not pictured) and apparently 2 USB cables.
IR sensor probably works similar to Boruit IR “sensor” headlamp - i.e. just for switching selected LED on and off. Description does not clarify that aspect.
Battery has standard 2 pin connector (same as used in small drones) and is easily replaceable.
BlitzWolf® BW-LT5 Pro IP68 Waterproof LED Panasonic 3350mAh Powerbank Emergency Camping Lantern with coupon travel is 20% off at $15.19.
Lamp uses single 18650 Panasonic NCR18650B 3400mAh (typical, 3350mAh minimum) cell but it’s not replaceable, it’s USB rechargeable and has ability to charge other devices via standard USB type A female port. It is completely waterproof, white light has two steady modes with up to 75h runtime in low mode + 3 modes red light (2 emergency blinkers + steady red), uses separate blue LED as charge indicator.
Restocking! Any chance of getting this sale again?
High quality Original Xiaomi 20000mAh Polymer Power Bank 2 Dual USB Output with Quick Charge 3.0
using coupon mipd2w brings price from $32.99 to $26.39.
Registered shipping included.
Rainbow heat treated stainless steel Astrolux M02 XP-G2/XP-G3/nichia 219B 100LM USB Mini LED Flashlight is for $13.26.
Three types of LEDs are available. Li-ion 10180 cell is included.
BLF A6 XPL 1600LM 7/4modes Non-anodized EDC LED Flashlight 18650 use coupon code 2017FNL to drop price from $26.95 to $18.86.
Silver version.
BLF A6 XPL 1600LM 7/4modes EDC LED Flashlight + INR18650-30Q Battery use coupon code 2017FNL to drop price from $29.95 to $20.96.
Black version with included high drain Samsung INR18650-30Q cell.
BLF A6 XPL 1600Lumens 7/4modes EDC LED Flashlight 18650 use coupon 8A955D to drop price from $26.95 to $22.91.
Black version.
Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 use coupon 76648A or 2017FNL to drop price from $29.95 to $20.96.
This is exactly the same flashlight as BLF A6 but with different name and additional matching 18350 tube already included in the box.
Those deals are time and quantity limited but I will try. We have to wait for enough stock to arrive.
how does it work? thanks.
Haikelite is under restocking right now so we have to wait until new stock arrives. When the light is avaiable again you can use BG points to drop price according to your account VIP level as shown in the table. You still need enough BG points to do so.
Update: :scissors: price drop! :scissors:
Original Xiaomi Miband 2 OLED Display Heart Rate Monitor Bluetooth Smart Wristband Bracelet use coupon MIBD2 to drop price from $24.99 to $19.99, registered shipping included in price.
BlitzWolf® 15W 2A Foldable Portable Dual USB SunPower Solar Cell Panel Charger with Power3S using coupon code D321CD brings price down from $32.99 to $26.39 (20% or $6.60 less). This panel can easily charge any smartphone and will also charge in overcast conditions as well (with decreased rate of course).
Registered shipping included but currently in preorder - stock is due to arrive on May 31.
Update: preorder deal ended. Now only coupon available.
Klarus G35 XHP35 HI D4 2000LM 18650 Outdoor Illumination 1000m LED Flashlight is now in preorder for $75.99 and BG points are working so it’ possible to drop price further, according to your account VIP level:
Update: Use coupon D1F1C4 to drop price to $83.99.
VIP0/1
VIP2
VIP3
VIP4
VIP5
$64.59
$63.83
$63.07
$62.31
$60.79
Astrolux S3 XPL-HI 1400LM EDC LED Flashlight 14500 for VIP2 and above accounts price is now $23.95 (instead of $35). BG points still work so price can be further lowered to:
VIP2
VIP3
VIP4
VIP5
$20.12
$19.88
$19.64
$19.16
Both tints: 1A and 3B are available at the moment.
Nitecore MT06MD Nichia 219B 180LM LED Pocket Medical Penlight Flashlight ◄ using this link drops price from $31.95 to $22.95 and BG points still work so it’s possible to bring down the price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$19.51
$19.28
$19.05
$18.82
$18.36
The flashlight uses 2xAAA cells and Nichia 219B LED with CRI over 90 at CCT=5000K. It has 3 modes and always starts in low (4lm), medium is at 45lm and high at 180lm.
ANENG AN8002 Digital True RMS 6000 Counts Multimeter AC/DC Current Voltage Frequency Resistance Temperature Tester ℃/℉ is now 25% off ($13.88). BG points still work, so it’s possible to drop the price further:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$11.80
$11.66
$11.52
$11.38
$11.10
Astrolux M01 nichia 219B/XP-G2/XP-G3 100LM USB Rechargeable Mini LED Flashlight with code 2017FNL is for only $12.56 ($5.39 less).
