TK, that really sounds wonderful. I love a true moonlight mode in almost every light and if it were there or not based on existing light… that would be awesome! The programming idea is interesting, thus having the extra space in the chip might be huge!
We seem to have new drivers showing up every day that have lots of potential right now. It is awesome! Just wish I could wrap my head around building them. I can see I will be ordering parts soon and testing this bad boy out!
I’ve just received the new v6 design for the F-2 and F-4, so I’ll build a few and make sure there aren’t any screw-ups.
The v6 component and pin design is already tested and working nicely though. I made a L4 dedicated version with 14 x 7135s which is the first of my v6 drivers to actually make it into a light: What did you mod today? - #2984 by Mike_C
I used a 22uF X7S rated OTSM cap on the L-14 which consistently gets over 10 measurable seconds at 4V and room temperature. I’ll have to lower the voltage and heat it up to test the margins.
Well, with the ATtiny85 without bending pins I found that the clip would pop off every now and then, and was sometimes difficult to get on right. It was much better when I bent the legs but would still sometimes be annoying to get on correctly and could still pop off easily, at least when it was installed in a light:
The acupuncture style has it’s drawbacks too, in particular if the wires used are too thin. It has happened that I’ve had to push on the wires as contact was lost, but it happens so seldom so I much prefer this method. Now I can have the MCU on the inside, keep a spring pad and flash the driver without taking it out. That’s a real advantage for a firmware developer
I have a dedicated development platform which makes development and testing much easier. Without the clip I find it even easier, but having the right size “needles” is key. The paper clips I use are pretty much spot on for the via size I used:
I have had that problem with the ATtiny85 clip popping off, but only pretty rarely. May have more to do with the solder flow on the legs. With bent pins, never a problem - rock solid clipping. Are you using the good blue clips?
The clips are blue, and mostly worked fine, but they might not have been the good ones. Sometimes the clips contacts would get bent and need straightening out. Possibly the stiff wire I ran over the 85s as battery contact had something to do with my issues, or possibly too little clearance to the 7135s:
Anyhow, these issues are now a thing of the past. I’ve fully converted to the 841 on all my drivers.
Small update for those interested… I’ve been testing and developing firmware for these v6 boards and so far so good. I’ve also made v7 series with some pin changes but it turned out that those changes weren’t really needed. I did make some other small adjustments so I’ll be using the v7 series anyway.
I’ve got off-switch and dual-switch functionality working fine, and I’m now working on E-switch only. It’s all the in same firmware but switch configuration is set by #defines. I did have a version where I could set switch type within the light’s config menu which worked well and was useful for debugging all three switch types in a single light, but that ate up too much memory.
On a single cell E-switch light I have got the parasitic drain down too low for both my DMMs to measure very well (Metex M-3650 and a Fluke 77). The lowest reading I can get from them is 0.1uA and that’s what I am seeing. When I pull the power to the driver it goes to 0 so the DMM is seeing something. Anyone know how accurate I can expect these DMMs to be at so low currents?
In any case I can’t get any lower as I’ve configured all pins and shut everything down for lowest power consumption while waiting for the switch pin interrupt to wake it up again. The datasheet specifies 1.3uA in power down mode but that’s with the WDT enabled. In power down mode I have it disabled. Anyway, I’m fairly satisfied the drain is low enough.
I haven’t built a multi cell LDO version yet but I expect the LDO to draw more than a powered down ATtiny841 in sleep mode. I’ll be building one of these shortly to try out if the AMC A705s can replace 7135s on 2S lights, so I’ll find out soon enough.
Thank you for the update. I feel like this is potentially groundbreaking and “next level” driver design. I really like it. just need to source the MCUs in small quantities somewhere.
Well, if we can get enough people wanting them, we might be able to talk Richard into carrying them at Mountain Electronics. That at least helps USA folks.
Thanks. I do have my eyes on the ATtiny1617 but I can’t get these easily, and more importantly I don’t have the tools to program them. I haven’t found any 1617 support for AVRDude, or even any info on anyone programing them with a normal USBASP.
I’ll come clean on this… I want to share them on OSH Park for anyone to order how they wish, but I do not want to share the project files. OSH Park have continuously told me that they are about to implement this, but they’ve been saying that for over a year. Personally I don’t understand why one should be able to download the project files just to order a board. It’s not even good business for them, one can just download the project files for any project and order from somewhere else. If I want to share the source files I’ll do it somewhere else, like here. Currently there is no way to share a board for ordering without sharing the project files, and I think that’s stupid.
