I’m in need of a couple. I’ll send a pm
I used these MCPCB’s to test a nichia 229AT today. The results were surprisingly good. It beat out the 219C all the way up to 4.5A when the lack of a thermal pad and DTP caught up with it.
They have the lowest Vf I have seen to date as well!
I take 2 as well to germany
PM me for pricing and paypal
Sent a message also for one board.
Hi djozz, i’ve PM’d you for two boards.
I had my Nichia 365nm LED in the Convoy run to long on the stock MCPCB it has lost brightness on parts of the emitter, 700mA are not good
Too bad I did not had this board from the beginning
Could I get 2 of these shipped to the UK?
About to order my first S2+ UV, and a reflow onto one of these seems advisable!
I’m behind in sending out stuff at the moment, and next week I’m away for work, so it will be next weekend before I will send the next boards.
for the Convoy Nichia LED I would strongly advise to make a resistor parallel to the LED which eats up 200mA
R=U/I=3.8V/0,2A=19 Ohms
P=U*1=3.8V*0.2A=0.76W
mine on this star is dying, lost about half its output
I used that light more than 20 minutes continously some times and its not good at 700mA
If you still have some to sell i will take 3 Boards.
Yes I do, 3 boards is fine, and thanks for the PM. I will reply this weekend because I’m not at home atm.
In general, I have so little boards leftover that at this point I stop the sale. Will update the OP and title.
These would be a nice addition to Clemenece’s new online shop I think.
Clemence has a version in the pipeline if I’m correct that should perform better than this board.
Hate to revive an old thread… but anyone know where i can find a few of these boards for the Nichia 119? I have a couple dozen 119’s that i have a project form, but no boards to put them on.
I think the clemence PCB’s will work with the 119. I would contact him.
Yes, the VirEnce VR16S1 board will fit the 119’s fine, but are a bit overkill at 4 dollar per board.
The boards from the OP were not cheap either and are unfortunately sold out, I had 200 of them made and sold most of them and have only a few leftover for own use. And it seems that you need many. I see no source for 119 boards on the internet atm
So sorry, that USD 4/pc is there for unlucky reasons. For anything below 10 watt it’s overkill. Any cheap non DTP board will do just fine. Try Digikey or Mouser.
- Clemence
Any cheap source for get them or similar at 1~2$ Piece, better if free shipping? need some
You should buy S2+ UV Nichia 276A very early, I changed the aluminum plate to copper plate for several years.
