Great deal, but I found this picture funny:
That’s what I call New Moon-light!
At first I thought it was complete black, but from an angle I can actually see a beam (Or whatever you call it) in the middle of the screen!
Oh and those convoy clips fit the D21 and D81
Hi friends
NEW LED is arrived
CREE XP-L2 V6 1C 5700K
http://www.kaidomain.com/p/S026187.Cree-XP-L2-HD-V6-1C-White-5700K-LED-Emiitter
CREE XP-L2 V4 3C 5000K CRI80+
http://www.kaidomain.com/p/S026460.Cree-XP-L2-HD-V4-3C-Neutral-White-5000K-LED-Emitter-CRI80
CREE XHP70.2 P2 1A 6000K
http://www.kaidomain.com/p/S026860.Cree-XHP70_2-P2-1A-White-6000K-LED-Emitter
CREE XHP70.2 P2 3B 5000K
http://www.kaidomain.com/p/S026863.Cree-XHP70_2-P2-3B-Neutral-White-5000K-LED-Emitter
Thank you
http://www.kaidomain.com/p/S026779.KDIY-KF8-Cree-XHP50_2-White-6500K-2650-Lumens-5-Mode-LED-Flashlight-Black
I am very interested in this light
When will it be restocked?
Interesting new driver :
I hope the mode order is a typo though : “Hi(2000mA) > Med(1000mA) > Lo(500mA) > Turbo(4000mA)”
Hi mrheosuper
Thank you for your interesting with KF8 flashlight.
It will not in stock in a short period.
Thank you
Ban
Hi friends
A new batch of CREE XHP35 HD is arrived.
Cree XHP35 HD D4 3C Neutral White 5000K CRI80+ LED Emitter (1 pc)
http://www.kaidomain.com/p/S026064.Cree-XHP35-HD-D4-50E-White-5000K-LED-Emitter
Thank you
Wow! Really nice move, this opens the door to the possibility of using a boost driver with emitters in series (perfect for home lighting high CRI triples, by the way).
There's already a wide selection of boost drivers, some of them marketed for 2S emitters while others for 4S (like XHP35s).
BanL, in behalf of this community, may you at least do some quick maximum output voltage tests for the 2S drivers? This can be as easy as measuring the driver output voltage without load. In order to drive 3S, the output voltage needs to reach at least 10+V, I believe. On the other hand, drivers geared for XHP35s should work…
Honestly speaking: it may be a good idea to build an in series triple and test out each driver with it (the Vout polling info would be quite handy too).
Cheers my dears
This triple also would do nice for RGB flashlights
Hi, Kaidomain I need your help! I know this is the dumb question but I am confuse? I bought a (H2-C 22mm 1.5A 1 or 2-cell 5-Mode Boost Driver Circuit Board for Cree XHP35 / XHP50 12V) diver and I using 1 cell on XHP35, can I use 2 cell on XHP35? Or it has to be XHP50 for 2 cell.
The boost driver works with any 12V LED with one or two cells
In 2S configuration its efficiency is better
OK I got it thank you Lexel!
Omg :heart_eyes:
What a nice flashlight.
We have someone from KD here on the board - we need pictures of the pill!
Edit: Also we need a XHP70.2 in it
I have several JKK lights very nicely built!
Alright, alright.
Ordered before it get’s sold out like the 18650 XHP50.2 one.
Since I like 26650s more, I just bought the bigger one as well a few days ago. http://kaidomain.com/p/S026765.KDIY-K5-Cree-XHP50_2-Neutral-White-5000K-2650-Lumens-5-Mode-LED-Flashlight-Black-(~~1x26650~~)
First powerful flashlights since a year or so.
I cant really find any reviews on the JKK lights, does anyone here have any experience with them?
Thanks.
