I’m interested in one. Thanks.
Interested for 1.
Curious to test alongside S70S too. The host changes look nice and UI with momentary also.
Two please.
Wow! I’m definitely in for 1! :+1:
Son of a b…. Another light!? Put me down for one two too!
I`m in for one please.
If there were not the Q8 and my lack of 26650 cells
Totally in for one. I’d like a dedomed XHP70, but that’s probably not feasible.
Interested
Interested in one. Thanks
put me down pls
Yeah, I’m in die one Light!
I’m in for one.
I would like one. Please put me down.
Please put me down for ” Two ” units.
Thanks
damn that what sweet light kronos, too bad i’m kinda low budget right now.
I`m in for one.
Greets
Carsten
I’m in for one
Great job Kronos! Your light looks great! But the thicker floor plate isnt going to help a whole lot in transferring heat through the head because its not the thermal bottleneck. What are the chances of making the head a solid 1 piece unit for a few dollars more, and keeping the aluminum walls thick to follow the contours of the reflector to better transfer heat through the head? All that dead air between the reflector and the head should be solid aluminum, as thick as possible, without any right angles, using only radius cuts, and of a 1 pc design to assist in maximum cooling. Any compromise here limits heat transfer, which heats the base of the floor plate assembly… which in turn heats up the battery tube and the cells. Then we wind up with another powerful light, where the battery tube is almost as hot as the head after a full power run. This has been the limitation in almost every high powered light sold up to this point. Now you have a chance to address that problem directly before its too late. As it is now, the light has the same thermal bottleneck as the S70 (and most others), which survives at 5 amps. Since you’re almost doubling the amps, I think you’d do much better in asking ThorFire if they can accommodate us. Every little bit is going to count at those power levels, and cells shouldn’t be used as heat sinks for such an awesome light that you’ve created!
Thoughts?
I’ll take one.
Nice project, thanks.
Regards Frank
