Trigonometry help please?
14 posts / 0 new
vestureofblood
vestureofblood's picture
Last seen: 1 day 18 hours ago
Hi gang,
I need to know how to find a particular angle without any special tools. I didn’t write down some of the angles on a light when I made them but now I need to know what they are.
How do I find what that angle is based on the measurements?
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
cbrake10
Last seen: 2 years 2 months ago
-Clark
-X3-
-X3-'s picture
Last seen: 2 hours 10 min ago
tan x = ((0.885-0.785)/2)/(0.090)
x = arctan(((0.885-0.785)/2)/(0.090)) = 29°
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
coolperl
Hi,
I’m not sure which angles you mean exactly, but here’s a crappy pic I made from yours:
If you are looking for ‘alpha’ then you need to calculate tangent of this angle which is 0.050/0.090=0,55555(5)
If you have this value, you go to online calc and check, what angle value corresponds to this result, and for tg=0,55555(5) the angle is 29,0546°
MRsDNF
MRsDNF's picture
Last seen: 3 days 15 hours ago
Does 29 degrees sound right?
cbrake10
The angle of the sides of the trapezoid with reference to the “body” should be 146.25 or 33.75 for the angle coolperl illustrated. Right?
edit: hurrdurr, derp, etc.; .090 corresponds to leg height not hypotenuse length….durr I feel so stoopid
-Clark
cera@1967
Last seen: 2 hours 20 min ago
 Both ,X3 and coolperl are correct ! 29 degrees !
Adrian
coolperl
Nope. That would be the case, if the 0,090 value was the lenght of the diagonal part. On the picture this value is lenght of vertical projection of diagonal part.
Or in another words, your values are calculated from the sine function, but should be from tan (or tg) function, because only dimensions for tangent function are provided.
MRsDNF
MRsDNF's picture
coolperl wrote:
Hi,
This is correct. The angle is 29 degrees. Thumbs Up
vestureofblood
coolperl wrote:
Hi,
29 degrees would make sense, since that is where my compound sits by default most of the time. Smile I think this is exactly what I needed.
So to be sure I understand. Half the distance of the change in diameter divide by the distance traveled. Then plug that number into the inverse tangent calculator and that is my angle?
So if all other things were the same but the head diameter was 1.250” I would go… 0.2325/0.090=2.5833333 For an angle of 68.83?
Also why in the equation does the decimal turn to a comma? 0.050/0.090=0,55555(5)
Thank you
hIKARInoob
hIKARInoob's picture
Last seen: 1 hour 25 min ago
USA: 1,000 = thousand
Other countries (including your calculator): 1,000 = one point zero zero zero
So the “.” is also reversed.
hIKARInoob
Correct!
(P.S. make sure your calculator is set in “deg” instead of “rad” or “grad”)
coolperl
Thank you
Sorry, that’s a typo. Ignore it.
vestureofblood
Thank you
LOL… Shows how much I know about trig. you could have put %(*()#@)#!!)) or kldswiqeorpugjriwqfpeiofj and I would have assumed it meant something.
