Yeah, OSHPark does 4-layer. Richard made one of his MTN-MAX buck drivers in 4-layer. I don’t know if he still sells that one. But, he was getting them from OSHPark. The price is a bit higher and the lead time is longer compared to the regular 2-layer boards.
OSH Park does four layer boards. They don’t support buried or blind vias though. The lead time is shorter than the two layer boards with extra copper thickness, and not noticeably longer than regular two layer boards.
Oh yeah, I forgot that they don’t do blind vias. But, even if you have to do a via all the way through the board, that still takes up less space on the top and bottom than a complete trace. The vias can be made small and placed under components or in some other out-of-the-way place. Still, if the layout can be made to fit onto a regular two-layer board with a 17mm diameter and no air-wires, that would be better.
Very nice indeed. I just saw this thread after finished reading your PM. I’ve been looking for a compact 20mm buck boost driver for some of my projects too (non flashlight). Sweet, now we have a good programmable driver for those 144AM.
Mike C asked me to share the libraries I used in EAGLE to design my first attempt of the 17mm board,
so here are the devices I created myself: My Library
If you need the ATTiny84a footprint as well, I suggest downloading the Sparkfun library here: Sparkfun Library
If you want me to design the MAX5424 as well, just ask for it
loneoceans: When you have made these boards, have you used stencils or applied solder paste by hand? I have had a few shorts on MCU pins when using default MCU footprint for my 841 when applying by hand. The default mask pad size is bigger than the actual pin and overlapped with the other pins. I made it better by customizing the footprint so the mask pad size is exactly the same is pin pad size. However, I’m now using stencils I made with an even smaller cream pad size for the pins.
Laying out the board on 4 layers would certainly not only allow better performance but also allow better routing. However specifically avoided a 4 layer stack to keep the PCB costs as low as possible. Adding blind or buried vias significantly increases cost so I usually try to avoid them as much as possible. I'll explore a little with the 17mm version when I have time though it looks to me that there should be no problems making a 2-layer 17mm version.
I didn't bother fabricating a stencil for this since I was expecting to only make a very small number of boards, so I soldered them all by hand with a combination of reflow and solder paste applied by hand using a toothpick (typically I don't get any bridges if the right amount of paste is used, or I fix it using solderwick), and solder the rest by hand under magnification with a tiny tip soldering iron. Like you mentioned soldermask expansion needs to be adjusted. I think I used 1 or 2mil expansion, depending on the fab I go with.
Yes it will work just fine with some small adjustments (e.g. to make sure it doesn't try to drive 9V at 3A, adjust components to make it more efficient st the desired drive currents etc).
I have run them up to 12A and they still worked fine. Check my sig for a test of them, they didn’t even reach peak lumens until ~6A. Although around 4-5A is ideal IMO.
Besides heat from the LEDs, running at 3A at 9V output is also impractical from a single 18650 cell drive in most flashlights as well. The 27W output will require at least 30W input or more, which for most 18650 cells will require about >=10A input current which will be just about too much for the driver to handle safely. Contact and switch resistance will also lead to significant losses. However, 9V at 2A or so is completely OK (at least for the GXB20) :)
I didn’t see this in the OP. Curious what are the limits of this driver when it comes to power. I assume that the true limits lie in the input current?
I assume this could boost power to an 12v XHP35 as well with some component changes, what kind of output current would be possible?
Also, did you ever say what components you are using for this driver? I never saw a parts list, curious what boost IC you are using along with the rest of the parts.
If this could be shrunk to 17mm an xhp35 S2+ could be a really interesting EDC light (or xhp50.2 for that matter).
