the code can be reused ;)
Got the code and purchased! Thanks M4D M4X!
I ended up with the XPG3 after a lot of back and forth between that and the Nichia… Was a hard choice for sure, but too good a deal to not get one. Maybe a S41S deal will pop up thats too good to pass up and I will grab that in Nichia… (hinthint)
thank you all for your support! :beer:
i wanted to order…but not sure about the cheap usb flashlights….never had any….what do you think?
I am thinking the same. I will still preorder two to test. Already have blf A6 and going off that, it will be a great little light.
Thanks a lot Martin, XP-G3 ordered!
Thanks. Got mail and placed order =)
I went back and forth between the much higher output xpg3 and the nichia. So at this price I opted to get both. I’m not a fan of the rings and color bands of the xpg3, but outside it really doesn’t matter. I too wasn’t fully convinced from the listing that the 18650 tube wasn’t included, just that the battery wasn’t.
I don’t have any 18350 IMR cells, so what going to be good? I’m sure Mte Windyfire cells would be great, but those aren’t currently in stock. Also, it’s usually safest be to get button top since I don’t know if the light as physical polarity protection, but will flat tops work as well?
Hi Martin! May I request for the code? thank you!
Hi Martin, code please… thx
Hi Martin!
Thanks for the code, now I have to wait for my first Nichia torch….
I’d like to request a code please
Codes sent :)
:beer:
XP-G2,XP-G3,Nicha 219C
Light Temperature: XP-G2(6500K),XP-G3 (6000-7000K),219C(5000K)
Light Color: Cool white,Cool white,Warm white
Material: Aluminum alloy
Total Emitters: 4X
Group2:Low,Med2,High1,High2 (with memory function,duble click the button,short press<0.5s)
Lumens: 2lm,20lm,140lm,240lm,545lm,735lm,2023lm (XP-G3)
1lm,17lm,125lm,220lm,490lm,650lm,1740lm (XP-G2)
1lm,16lm,125lm,210lm,475lm,630lm,1630lm (Nichia 219C)
plan on 70 cri but might be 83?
Well I ordered one but thought is was a 18650 flashlight. Not a big issue can order an extension tube. But if its an 18350 write it down.
I might have missed seeing my post- But I’d sure like a code please if you didn’t send me an email. Sorry if this is a duplicate post. Will the output vary much between the 18350/16340/18650 batteries? I’ve got plenty of 18650’s arounf— I apologize if I messed up writing. I have catarsacts and my vision is kinda messed up today… I did see this spec and thinking on the XP-G3. Thanks for the chance to save some money. onnha
Any pre- tests somewhere of this light!?
I’m having a hard time figuring out the runtime info:
Runtime: 2.9D,1.3D,6h,2h,1h,0.4h,0.39h (18350)
14D,6.4D,29h,9.7h,4.8h,2h,1.99h (18650)
So, you only gain .01h runtime going from 2023lm to 735lm?
Maybe that means only 0.1h on turbo before stepdown
Well, shoot I could buy that to some degree, .01hrs or a 36sec turbo stepdown, seems reasonable. I would expect then to see 8 durations listed for the 7 different levels, but it is 7 and 7.
