Uh, yeah, 8.4v was already too much for the old XHP50, the 50.2 has even lower Vf so wiring it directly to 2s would instantly blow it.
You need to use a 7135 or buck constant current driver.
Lipo cells are rated at a max current but they can provide much more than that in short bursts, to the point where they can melt down.
Unless it is a protected cell, in which case it would just shut off. to prevent damage.
You need a driver to limit the current.
Obviously I’m not talking about lipo cells. Lithium only.
Do all over current protection circuits just shut off? I have some protected KeepPower 5200 cells (rated at 10 amps) used on a FET driver and they pulled 9.7 amps. Unprotected cells pulled 12 amps. Now I assumed the protection circuitry was limiting output. Are you thinking that 9.7 amps was the most the batteries could provide and that if it were capable of over 10 amps the circuitry would kick in and shut off power completely?
They are the same thing…
Lithium, li-ion, lipo, they’re all basically the same technology with different names for the shape of the battery.
You know because they are all 3.7v cells with 4.2v max, with a few exceptions of course.
idk if the protection in your protected cells limited your current output, or if the circuitry in them just added more resistance, but I would still use a constant current driver for any LED.
Technically lipo means specifically the pouch cells as opposed to cylindrical, I call them all lipos though, the part that maters is the lithium not the shape
I sure hope it is because of the 18650 and 18350 will live fine as I have a C8 XHP50.2 build as richard posted here (unless he used buck driver) and now it’s a ticking time bomb.
XHP50.2 definitely has a lower vF than original XHP50...it seems like with 2x18650 or bigger you have to use caution. My setup with 2x18350 seems to have been working fine. 2x18350 sags voltage pretty hard compared to 2x high drain 18650.
They must also be more fragile than XHP50....I've desoldered XHP50 from so much heat then reflowed them back on and kept going.
For the XHP50.2 and FET...I would try to use some long, thin wires (cheap and effective low value resistors).
Unfortunately I had already used the premium wires that come with your FET drivers. Too late. I also have the same setup with two 18350 and so far so good. But two 18650 and no go. I might add it to the site to add caution. I don’t want others to waste money too.
The last batch of 17mm and 20mm MTN-MAX 4-layer boards were botched---same design as before, but every single one has internal shorts that made them useless. I am waiting for more PCBs.
I will add a note to the XHP50.2 listings sometime tomorrow.
Asked via the Contact link also — is there a way to search/sort out only the protected cells?
When I search “protected” the software helpfully retrieves all the unprotected cells also.
