Firstly can you link to that thread you mention.
Secondly yeah I'd like to know that too.
Am I wrong ( most likley) or did I read vasaline works in a pinch?
link to another thread asking about lube.
Superlube is good stuff. price is reasonable. safe for everything. conductive. low viscosity. it's what i use. check eBay.
Vaseline or any other petroleum based lubes shouldn't be used on rubber. petroleum will cause latex rubber to harden and become brittle. if your o-rings are made of something else, like silicone, i think it's okay. i think Maglite is the only flashlight company that recommends Vaseline.
Silicone lube is safe for rubber, but not on silicone o-rings. silicone lube can cause silicone o-rings to soften and expand.
if you don't know what your o-rings are made of and don't want to have to find out every time you get a new light, a synthetic lube like Superlube is the safest.
Fishing reel grease at walmart works great ,preserves any type of orange and also helps with water a debris;)
Spare some of your engine oil from your next service. Easy Peasy.
i think there are several types of product varities from the "superlube" series. which one to get?
Kreisler, use this one (it also comes in a can):
http://www.amazon.com/Superlube-21030-Multipurpose-Synthetic-Grease/dp/B000XBH9HI
A tube like this will last quite a long time. I picked mine up at Ace Hardware.
Thanks, i will look into it!
i have cancelled my DX order because they didnt have the silicone flashlight oil in stock for weeks/months. let's see how fast they process the refund.
!!!!!!!!!!!!!!!!I WANT MY 02.00 US-DOLLARS BACK!!!!!!!!!!!!!!
:D
This is the version I use
I'm using this product; I hope I'm not doing long-term damage to my o-rings but it seems to be working well here...
http://www.amazon.com/Super-Lube-Oils-P-T-F-Cap/dp/B000BXOGHY
i cant find any lube/lubricant/grease/oil for flashlights on Kaidomain or Manafont or Dinodirect wtf
DX is the only place. but out of stock
This Dupont Lube is the best I have had so far. Once it dries it makes the threads feel as smooth as butter.
Thanks I wrote it down, Im going to see if they have it at the store.
"Kreisler, use this one (it also comes in a can):
http://www.amazon.com/Superlube-21030-Multipurpose-Synthetic-Grease/dp/B...
A tube like this will last quite a long time. I picked mine up at Ace Hardware."
Yep, same stuff I use. It works great, lasts a long time and does not stain like a moly grease.
Don't know if they have Ace Hardware in Canada, but that's where I was able to find Super Lube. A couple of dollars for a little tube that will last forever. Looks like vaseline.
Thanks very much for the link...I will go to the Walmart tonight for the SuperLube and if its not there I will order that one in your link. Price looks good and its easy to order.
Harbor Freight carries Superlube.
http://www.harborfreight.com/85-gram-super-lube-grease-cartridge-93744.html
i'll get the nextorch stuff! ( ordering the original superlube from AmazonUSA or ebay costs lotsa shipping. nextorch shipping is free. says the budgeteer. *ggg* )
I was going to suggest Harbor Freight, but then I checked and didn't see Harbor Freight with any stores in Canada. That's where I bought mine. I actually bought it for another purpose, but when I came across a thread where atbglenn posted about using it on flashlights I was glad I already had it!
-Garry
