“Theoretical arithmetic”… WTH is that supposed to mean? You take the battery capacity and divide by tail cap amps? Can’t they just do a runtime test? This light has impressive specs in a tiny package, but i hate it when manufacturers put up numbers out of the blue like that. Same thing with the “300h runtime”… you have to read through to understand it is at 1 lumen.
BTW: we need a BLF boost driver to deal with all those 6V and 12V emitters… I’d love to see a XHP50 inside a BLF A6 for $30.
This item has an irresistible size/power ratio in its size classification. Most power for size. For me, that alone is a show starter.
I can always run any light at medium mode for medium heat generation and medium run time. How exciting can that be? I am getting more and more excited about this item, just as I am typing this post.
Per NITECORE Concept 1 1800 Lumen EDC Flashlight lists this at a pre-order price of $64.95 (same as the P30). I don’t have any experience ordering from this site though. They are the authorized US distro. Hope this helps! I am curious about this light as well, hope to see a video review soon.
Rather than doing a 30min test on turbo, they do a longer test on a lower power setting, find how many amps it draws, then by measuring the amps at turbo you can just calculate how long it would last on turbo.
A/B = C/D
It’s not hard, just elementary school math.
It’s theoretical because on those high powers the runtime can vary a lot depending on ambient temperature, airflow, and other stuff that would affect the battery and driver current delivery.
So it’s 18g lighter, slightly smaller and puts out only 200 lumens more then an bypassed BLF A6. But it costs 3 times as much? Ahh the lumens war…. Although Nitecore do under rate most of there products.
I thought about all this 30 secs after I thought, damn I want one.
From the pictures, the switch pivots on the hinge at the front.
I think the phillips screw at the back is just there as a stop to keep the pivoting switch cover flat against the light. Without the screw the cover could flip 90 degrees perpendicular to the light.
