I did order the newest 2.2 version boards. I’ll keep this thread updated with progress. It’ll be 20 or so days for the fab in China to make the PCBs and them to get here via HK Post (largest delay is the shipping time).
Man, I’m interested, but don’t have a lot of extra spending money right now! I actually have some batteries and a BMS that I bought to make a pack, and haven’t done it yet because I’m not sure soldering the tabs is a good idea for high draw battery power tools.
Are you talking bout just the pcbs or the whole BOM? I am interested in the pcb and the alu profiles. But depending from where you live it might be cheaper for me to order in EU.
Could really do either. I’m more likely to do more just bare boards than whole BOM sets.
If you’re in the EU it might be better for you to order right from the guys shop who did the instructable
For us in the US it might be better for us to just the BOM stuff locally and not worry about currency conversion/euro value and international shipping
Unno. When I used to spot-weld sub-C NiCd cells, I’d take a thin strip of metal, put a dimple in it where I’d want the weld to be, securely have one contact go right to the cell, and the other end to the tin strip. Carefully lower it down into place, and ❋pouf!❋, the arc would weld that critter tight.
Used a few of beefy caps, like 80,000µF power-supply caps with screw terminals, in parallel, with ~14ga wire coming together at the “probes”.
Was enough to “stick” a screwdriver to whatever it’d touch, so…
Maybe not for critical applications, but for connection a few batteries a DIY effort is fine (It is easy to test if the welding works and is solid enough).
The cheap Chine spot welder and the DIY design, will probably work about the same and the DIY design may last longer.
I don’t think any of us are proposing to use this for high precision manufacturing of battery packs. Welding on button tops, or building a multi cell battery pack is closer to the truth. Perhaps even rebuilding a cordless tool battery.
The instructable linked has a video that shows the build process. I shall attempt to link it here que’ed up to the place where he starts testing it.
Be forewarned, you may want to have your safety glasses on before clicking the link.
^ Peter, watch that video and realize the cells remain wrapped. There’s also multiple welds on each cell on each tab. So the likelihood that a single tab would have 4+ welds fail for the tab to come completely loose and short something is not going to happen I dare say.
Fwiw, when I’d spot-weld sub-Cs, I’d do it with the cells essentially side-by-side, then fold then over to be coaxial (ie, a battery “stick”). So having a mil-spec weld wasn’t necessary, as they’d be just lying in a trench or rack and not get jiggled around too much. Soldering was pure Hell, but a quick spot-weld made things lots easier.
I built a mot welder last year. I control it wth a footswitch to a relay. Most of the time it works well but I have a twitchy foot :person_facepalming:
I’ve been trying to think of a way to do a timed double pulse. Wonder if I could use the timing part of the circuit. Hmm?
The version of the board I ordered has an auto pulse feature which would require no use of a foot switch. It sees both probes are in place on the strip, waits 2 seconds, and then pulses the welder.
