“Theoretical arithmetic”… WTH is that supposed to mean? You take the battery capacity and divide by tail cap amps? Can’t they just do a runtime test? This light has impressive specs in a tiny package, but i hate it when manufacturers put up numbers out of the blue like that. Same thing with the “300h runtime”… you have to read through to understand it is at 1 lumen.
BTW: we need a BLF boost driver to deal with all those 6V and 12V emitters… I’d love to see a XHP50 inside a BLF A6 for $30.
This item has an irresistible size/power ratio in its size classification. Most power for size. For me, that alone is a show starter.
I can always run any light at medium mode for medium heat generation and medium run time. How exciting can that be? I am getting more and more excited about this item, just as I am typing this post.
Per NITECORE Concept 1 1800 Lumen EDC Flashlight lists this at a pre-order price of $64.95 (same as the P30). I don’t have any experience ordering from this site though. They are the authorized US distro. Hope this helps! I am curious about this light as well, hope to see a video review soon.
Rather than doing a 30min test on turbo, they do a longer test on a lower power setting, find how many amps it draws, then by measuring the amps at turbo you can just calculate how long it would last on turbo.
A/B = C/D
It’s not hard, just elementary school math.
It’s theoretical because on those high powers the runtime can vary a lot depending on ambient temperature, airflow, and other stuff that would affect the battery and driver current delivery.
So it’s 18g lighter, slightly smaller and puts out only 200 lumens more then an bypassed BLF A6. But it costs 3 times as much? Ahh the lumens war…. Although Nitecore do under rate most of there products.
I thought about all this 30 secs after I thought, damn I want one.
From the pictures, the switch pivots on the hinge at the front.
I think the phillips screw at the back is just there as a stop to keep the pivoting switch cover flat against the light. Without the screw the cover could flip 90 degrees perpendicular to the light.
I find the SS look of the hinged switch appealing, along with the smooth lines of the light and the knurling where it matters. I saw a couple of video reviews on it that showed it can easily be changed between the 2 groups by loosening the tail cap then holding the switch down while re-tightening the cap… a double blink indicates the successful group change.
Also found that if one uses a pair of the CR123 cells then there is no Turbo mode. This 1800 lumen mode only works with an 18650. I like the police style strobe as well, so, I plunged… Nightcore is good about building an excellent light, with a good warranty and well made drivers. Figured it’d be hard to go wrong on this one and for the price, well, not often you find a newly developed top brand name at these prices…
Edit: Ordered one yesterday, couldn’t resist it’s sleek sophisticated look.
I got excited about the size/performance ratio of this item when it was first announced. I have been sitting, waiting for it to be offered from one of my two favorite dealers. Time for waiting is past, now it is time to just simply get this item. The triggering event: Your post, quoted above; very very positive, very upbeat. It makes my day to be be refreshed by reading cheerful content. Thank you for your pleasantly informative content.
I got one in earlier in the week and will hopefully have a full review out this weekend but I first decided to do a demo of the UI since it’s a bit different.
