well we have to wait what Thorfire will respond right
Jason, we see your point
Going camping tomorrow, the Q8 goes with me, but just for show, it is more hanging around with a few families, lots of children and a camp fire than exploring the wild.
And although no rain is forecasted for the coming days, tonight I tried a very mild submersion test on the proto3. I know that the design goal was no more than that the Q8 could withstand some wet weather without actual water pressure, we had the switch redesigned with a silicon cover for that, I reckoned that it should survive a bit more than that.
So I lubed the three o-rings of proto3, and filled a bucket with 12cm (as it turned out) of water.
Switched the light on and dunked it in the water for a minute.
As you can see there’s just one air bubble popping out of the light, right in the beginning, and I believe it was just some trapped air from outside the o-ring, after that first bubble, nothing came out. Afterwards I inspected all entrances of the light, and there were some droplets in the threading that may or may not have passed the o-rings, but the opening of light after the test could as easily have done that. The inside of the light was completely dry everywhere. The switch design is very waterproof, nothing happened there. I mostly feared for the o-ring at the reflector but that one I’m certain of that it stayed dry, no droplets at all could be seen that passed the o-ring.
So I’m pretty happy with that, I will not hesitate to use the Q8 in heavy rain. Would I trust it for 10 minutes submerged instead of 1, or in deeper water? No, the way the Q8 is built, not really.
Teacher, your forgetting one very important thing. Springs sag over time. The fact that the shortest cells have very little spring pressure on them is in fact, a problem. No one measured the spring compression on all the previous prototypes, which was a slight oversight. This hidden problem only came to light when Djozz “accelerated” the sag in a spring and found that they don’t have much compression on them in the first place. We now need to address this and a slightly longer spring seems like a good solution.
Read what I posted earlier:
Nice test djozz.
I could see no reason on my light why the light would leak water at the lens as the oring sits proud of the reflector which would allow a good seal in this area.
What other lights are you taking camping? I couldn’t think of a better light in my arsenal that would do a better job than the Q8. Have fun and dont miss us to much.
Ha nice bold test Djozz!
That reminds me to tighten the switch thing, I have the LEDs there now at 12 and 6 o’clock position which I like (it comes at 9 and 3)
Please use a plastic cup as diffuser to see how it fares
Thanks, I will have fun
And since you asked :innocent: :
Apart from proto3, I will take the driver-less Mitko thrower with Black Flat led, and my Jetbeam E10R that I swapped a 219B V1 sw45 R9080 led in. And as a general light my KD 18650 host with A6 driver and 90CRI 3000K XM-L2 led.
Well, that answers my question, pages back, if it would tolerate rain! I don’t intend to swim with it! If I’m swimming we have far more problems on this planet than me swimming with a light. Thanks!
Enjoy your camping!
Great video djozz…. thanks for sharing it. :+1:
Have fun on your trip……
LOL, only a couple hundred, such a noob.
You should try my advanced technique… First I start with a soldering iron, but nothing goes where I want it, so then I put away the iron and zap the thing with my eye lasers. It damages the driver beyond repair, so I toss it and order one pre-built from RMM.
That counts as “technique”, right?
LOL, BLF has a thing with going beyond spec.
Yep, as far as I am concerned it counts. And a darn good “technique” it is too I might add! :+1:
teacher:An older gentleman gave me some words of wisdom almost 40 years ago that stuck with me……. “If it ain’t broke, don’t ”fix” it.”
Well, as far as I can tell ; the host design of the Q8 certainly “ain’t broke”… by a long shot.All this talk of shortening tube length, changing this. possibly changing that, etc., etc. is nothing more than unwarranted rhetoric.
- Djozz has said from the start of this that a different spring will solve the “problem”^.
I, and obviously at least a few more people; think he has enough sense to know what he is talking about. A different spring will fix the “problem”, ^ <span class=“change minor a warrants that discovery a just is it “problem”… a it call even can we if”>.
- And as far as battery length. Tom E has done extensive testing with a number of different batteries. He has listed the results in several different posts here in this thread. All the ones he tested fit and worked in the Q8 :+1:
So………. IF you want to make sure your batteries are going to fit……… get something he has tested. That is a nobrainer.
One or more springs can sag just over time. It’s normal for a spring to loose a little of it’s free height after being compressed for long periods. To give them some leeway to account for sag and still have decent spring pressure.
JasonWW, I’m not forgetting that. In essence that is exactly what we have been discussing. Djozz mentioned what he had found and also what would solve it…… a longer & beefier spring if I remember correctly. Simple as that……
That is about the time when what I referred to above as “unwarranted rhetoric” began…. Really doing nothing more than confuse the issue & start to make a mountain of a mole hill.
Djozz had already stated what would “fix” what he found.
Personally, I think he has enough sense to know what he is talking about.
I also think the rest of the ‘team’ do too. Remember, they also actually have Proto 3 in their possession, to measure, to test, to do whatever be needed to spot any potential “”problems”” so that they may be rectified before production.
None of us in the “peanut gallery” has the option to actually touch or see a Q8. So really, any commentary from us is really little more than speculation that may range from an educated guess to p poor.
At this point I have confidence ‘The Team’, ThorFire included in that; will figure out what is best.
*munch*
I didn’t know we had a peanut gallery, but I’ve been enjoying the snacks over here in the popcorn gallery.
*munch*
Really though, I’m not worried about the Q8. We’ve got some of the most talented people on BLF working on it, so I’m sure that what we get will be the best anyone could have made in the same situation.
Will it be perfect? Probably not. But what is? I mean, aside from me of course. Obviously. I never make mistakes. Duh. Why would you even imply that? I don’t like you any more.
*munch*
Would someone pass the salt?
Good one. LOL
BLF has a thing with going beyond spec. Smile
— TK
As J. Baldwin of the old Whole Earth Catalog (ask your grandparents about that, kids) used to say,
“You don’t know how to use a tool until you know six ways to break it.”
teacher:the “peanut gallery”
*munch*
*munch*
*munch*
TK… I find it hard to believe you did not know there was a “peanut gallery”….
That is where the “entertainment” comes from while sitting in the “popcorn gallery”. … Where you are now……
And, by the way; whether you have a Q8 Proto in hand or not…. I would consider you, or any opinion you might share; about as far from the “peanut gallery” as broad daylight is from pitch dark……
Edit: I’m not worried about the Q8 either…. I think it is going to be “the best it can be”…… :+1:
PLEASE CHECK IF YOU ARE ON THE LIST OK
The Q8 list (from post #1) sorted alphabetically .
(As of post #7551)
See post #8357 for the latest list.
2 DOGS | 186 | |||||||||
264 | 641 | |||||||||
2Ace | 165 | 1119 | ||||||||
5ar | 697 | |||||||||
7pot | 982 | |||||||||
a12luke | 932 | |||||||||
a_idiot | 740 | |||||||||
Aardvark Spleen | 253 | 402 | 403 | |||||||
Abe87 | 876 | |||||||||
Abqjohnny | 51 | 1169 | ||||||||
abril | 50 | |||||||||
adirondackdestroyer | 545 | |||||||||
adrianlights | 255 | |||||||||
AEDe | 923 | |||||||||
Ag76 | 1345 | |||||||||
aggillator | 458 | |||||||||
aginthelaw | 278 | |||||||||
Agiri | 110 | |||||||||
aim120 | 430 | |||||||||
AirBreaker | 155 | |||||||||
akhyar | 387 | |||||||||
akoposilester | 56 | 1111 | 1112 | |||||||
akovia | 937 | |||||||||
albertopnp | 365 | |||||||||
Alcius | 105 | |||||||||
alejandrov | 523 | |||||||||
alex64 | 1159 | |||||||||
AlexGT | 495 | |||||||||
Alkpwn77 | 204 | |||||||||
allthumbs | 218 | |||||||||
alphazeta | 335 | |||||||||
alternety | 564 | 565 | ||||||||
Alux | 702 | |||||||||
amplificus | 904 | 983 | 984 | |||||||
Andmiller | 1064 | 1065 | ||||||||
andrewmac | 407 | |||||||||
Andybibbville | 147 | |||||||||
Andyman? | 13 | |||||||||
Angel Martínez | 128 | |||||||||
ant0 | 1195 | |||||||||
Antenne | 801 | |||||||||
Anthon | 568 | |||||||||
antiparanoico | 32 | |||||||||
AppA | 1208 | |||||||||
aprendiz | 1160 | 1261 | ||||||||
apt323 | 47 | 544 | ||||||||
archi | 1157 | |||||||||
archimedes | 67 | |||||||||
aremihc | 910 | |||||||||
ARMS.AARON | 1089 | |||||||||
ARsee | 1228 | 1229 | ||||||||
Arufonsi | 921 | |||||||||
aslpg | 398 | |||||||||
asnidi2 | 1327 | |||||||||
asot | 690 | |||||||||
Astromanic | 424 | |||||||||
AsylumSweep | 863 | |||||||||
atbglenn | 567 | |||||||||
Atom00 | 358 | 359 | ||||||||
Autoclave | 1099 | |||||||||
Awdtsi | 1221 | |||||||||
Awkward Stretch | 619 | |||||||||
AwkwardPause | 464 | |||||||||
b1i1l1l1y1 | 1052 | |||||||||
B42 | 685 | 686 | 1019 | 1020 | ||||||
BackpackNY | 571 | 1084 | ||||||||
bakalakos | 202 | |||||||||
balazs1956 | 1341 | |||||||||
baldo21 | 260 | 261 | ||||||||
Bam35 | 1039 | |||||||||
bamawthu | 599 | |||||||||
banker | 1013 | |||||||||
basslovin808 | 446 | |||||||||
Bastarrdo | 117 | |||||||||
Batch1 | 293 | 344 | ||||||||
battletross | 809 | |||||||||
bawilson2 | 500 | 501 | ||||||||
Bc412 | 5 | |||||||||
bd52 | 399 | |||||||||
BDM | 1018 | |||||||||
BDWrabbit | 1244 | |||||||||
BeardedRaleigh | 662 | |||||||||
bella-headlight | 49 | 411 | 877 | |||||||
Bernard | 232 | |||||||||
Bevo | 1086 | |||||||||
bhuge00 | 1049 | |||||||||
bigpix | 84 | |||||||||
bigrick | 754 | |||||||||
bikedave99 | 1174 | |||||||||
bikenber73 | 14 | |||||||||
Bill 63 | 752 | 1296 | ||||||||
Bill_tong | 896 | |||||||||
Billcheese5 | 949 | |||||||||
bionictony | 1338 | |||||||||
bkling | 1067 | |||||||||
BlackList | 1350 | |||||||||
bladesmith3 | 607 | |||||||||
BLFD80 | 933 | |||||||||
BlindingL5s | 312 | |||||||||
blinker | 1306 | |||||||||
blinky | 1209 | |||||||||
blueb8llz | 70 | 553 | 1120 | 1121 | 1122 | 1123 | ||||
Bluzie | 785 | |||||||||
bmaddison | 248 | |||||||||
Boaz | 391 | |||||||||
BobbyMK | 462 | |||||||||
bobdotorg | 1271 | 1272 | ||||||||
bobofire | 1313 | |||||||||
Bogdan | 370 | 371 | ||||||||
bogdanr | 466 | |||||||||
Bohemian | 775 | |||||||||
bonfire | 412 | |||||||||
Bong lick | 763 | 1075 | ||||||||
Bonham | 262 | |||||||||
borealis | 1098 | |||||||||
BorisBar | 575 | 1238 | ||||||||
Boro | 360 | 361 | ||||||||
bossf350 | 803 | |||||||||
Box | 671 | |||||||||
Brettg4215 | 864 | |||||||||
Brian Metcalfe | 318 | 319 | 374 | |||||||
BrianK | 447 | 560 | ||||||||
BrianTheJay | 950 | |||||||||
brightlights | 243 | |||||||||
brjones | 504 | |||||||||
brno602 | 913 | |||||||||
brted | 249 | |||||||||
Bruno28 | 513 | |||||||||
BT100 | 1087 | 1138 | ||||||||
Bungle88 | 610 | |||||||||
Buzzy243 | 1179 | |||||||||
bwl123 | 870 | |||||||||
cabfrank | 443 | 988 | ||||||||
Caleb | 203 | 547 | ||||||||
Caleb-v | 444 | |||||||||
Calmaja | 35 | |||||||||
Cano | 661 | 1151 | ||||||||
Captainvideo | 1302 | |||||||||
caramba | 748 | |||||||||
carmantl | 345 | 346 | ||||||||
casi29061965 | 467 | 490 | ||||||||
cavorite | 1028 | |||||||||
Cawi | 1276 | |||||||||
cbrake10 | 749 | |||||||||
cclight | 897 | |||||||||
cdjaney | 825 | |||||||||
Chadvone | 63 | 693 | ||||||||
Charga | 124 | |||||||||
charles lin | 1124 | |||||||||
CheapThrills | 469 | |||||||||
cheesecheeks | 816 | |||||||||
ChibiM | 1310 | 1321 | ||||||||
Chicken Drumstick | 131 | |||||||||
chinooker | 1260 | |||||||||
chooma | 210 | 351 | ||||||||
chrisc | 741 | 742 | ||||||||
churchilllafemme | 1230 | |||||||||
CircaM | 894 | |||||||||
Cjlee89 | 951 | |||||||||
cjoe7 | 146 | |||||||||
CJW | 367 | |||||||||
clagged | 991 | |||||||||
clange50 | 479 | 480 | ||||||||
clinicdoc | 1226 | |||||||||
Cliwilnew | 795 | |||||||||
cloggy | 404 | |||||||||
cmflippen | 83 | |||||||||
cnrffl1 | 577 | 1113 | ||||||||
cocoschnauzer | 363 | |||||||||
contigo | 1351 | |||||||||
Coolerness | 664 | |||||||||
coolriku | 517 | |||||||||
Corzy | 308 | |||||||||
Couchmaster | 245 | 551 | 552 | |||||||
cpd800t | 406 | |||||||||
CrashOne | 372 | 377 | ||||||||
Crazyeddie | 98 | 137 | 487 | |||||||
Creepo | 909 | |||||||||
cristhemuso | 388 | |||||||||
crx88ia | 683 | |||||||||
cujo255 | 1191 | |||||||||
cwb | 134 | |||||||||
cypher1024 | 973 | |||||||||
cypherz | 250 | |||||||||
Cythras | 956 | |||||||||
D10ten | 608 | |||||||||
Dadpool | 1161 | |||||||||
dafarui | 1339 | |||||||||
daninho | 468 | |||||||||
DarkerInSol | 615 | 616 | 617 | 618 | ||||||
darkpenguin | 718 | 719 | 735 | 736 | 737 | 738 | 739 | 860 | 861 | 862 |
darol | 798 | |||||||||
darrenm | 1054 | 1055 | ||||||||
darrylo | 507 | |||||||||
DarthTader | 830 | |||||||||
datiLED | 761 | |||||||||
dave101 | 1041 | |||||||||
DavidEF? | 7 | |||||||||
davidkappelt | 1026 | |||||||||
davidvns | 1128 | |||||||||
davos | 1062 | |||||||||
DB Custom | 713 | 722 | 997 | |||||||
dbesselt | 1156 | |||||||||
DBSAR | 136 | 169 | 1281 | |||||||
DBSS | 516 | 779 | ||||||||
deathless | 518 | |||||||||
Deep skull | 977 | |||||||||
DeJaVu | 669 | |||||||||
dekozn | 800 | |||||||||
Dennis | 934 | |||||||||
dentillozie | 488 | |||||||||
Dep668 | 687 | 688 | ||||||||
derfyled | 1237 | |||||||||
derpilgerer | 630 | |||||||||
Desmo | 805 | |||||||||
devdvr | 486 | |||||||||
dezoe | 1186 | |||||||||
dhsvcs | 265 | 1336 | 1337 | |||||||
dicksog | 559 | |||||||||
digitaltc | 1323 | |||||||||
Dimking | 425 | |||||||||
Dirt | 815 | |||||||||
Dirty_Pierre | 1045 | |||||||||
DiscoJoe | 1254 | |||||||||
djburkes | 188 | 878 | ||||||||
Djozz | 3 | 1115 | 1286 | |||||||
dmbaty | 1294 | |||||||||
Dobtruckers | 1058 | |||||||||
DOCFAR | 595 | |||||||||
Docp723 | 347 | 433 | 434 | |||||||
Doctawho | 440 | |||||||||
dodo | 88 | 274 | ||||||||
dogany | 813 | |||||||||
Dogsrule | 508 | |||||||||
donpachi | 1252 | |||||||||
dotBLF | 968 | |||||||||
doubleone44 | 887 | |||||||||
downlinx | 74 | 316 | ||||||||
doxerino | 1304 | |||||||||
Dr Forinor | 873 | |||||||||
Dradge | 1248 | |||||||||
Dralf | 1015 | |||||||||
Dregs | 172 | |||||||||
DrHook59 | 883 | |||||||||
driveX | 659 | |||||||||
DrJones | 75 | |||||||||
DT101 | 152 | |||||||||
dudunphy | 389 | |||||||||
Duke | 381 | |||||||||
dumptruck | 971 | |||||||||
Dusty | 327 | 328 | ||||||||
Dutcheee | 68 | 322 | ||||||||
duvallite | 889 | |||||||||
dw911 | 478 | |||||||||
Dwantink | 135 | |||||||||
e10sno | 405 | 1318 | 1319 | |||||||
Easyrr | 6 | |||||||||
eb1888 | 837 | 838 | 839 | |||||||
ebosh | 777 | |||||||||
ediaz | 906 | |||||||||
eebowler | 774 | |||||||||
Eggun | 1104 | 1312 | ||||||||
egrep | 594 | |||||||||
Eivwer | 171 | |||||||||
electricjelly | 237 | 256 | ||||||||
ElginAgain | 1204 | |||||||||
emarkd | 109 | |||||||||
embee | 511 | |||||||||
Enelooper | 417 | |||||||||
engber | 947 | |||||||||
ERDOS | 1150 | |||||||||
Erethryn | 1259 | |||||||||
erikk365 | 648 | |||||||||
Esskay | 995 | |||||||||
Etex | 829 | |||||||||
euphxenos | 408 | |||||||||
everydaysurvivalgear | 103 | |||||||||
Evilc | 65 | |||||||||
EyeballFryer | 189 | |||||||||
Fadetoblack | 1295 | |||||||||
fantomR | 636 | |||||||||
Far Thrower | 148 | 197 | ||||||||
Farmboy24 | 1234 | |||||||||
Farns | 277 | |||||||||
Fatlight | 663 | |||||||||
FBsLights | 790 | |||||||||
fcrespi | 1262 | |||||||||
fed893 | 307 | |||||||||
fedcas | 902 | |||||||||
feralcomprehension | 1194 | 1311 | ||||||||
finges | 561 | |||||||||
fireblade893 | 209 | |||||||||
firedome | 324 | 711 | ||||||||
Firelight2 | 397 | |||||||||
fishlite5 | 1046 | |||||||||
fixed it | 78 | 1097 | ||||||||
fixvid | 1264 | |||||||||
Flash Voyager | 652 | |||||||||
flashination | 87 | |||||||||
FlashMax | 1225 | |||||||||
Flashy Mike | 239 | 410 | 448 | 449 | ||||||
Flifish48 | 806 | 1096 | ||||||||
Flintrock | 629 | |||||||||
fluffman86 | 958 | |||||||||
FmC | 1182 | |||||||||
fonfan | 234 | 1023 | 1024 | |||||||
fonLED | 725 | |||||||||
Ford Prefect | 1068 | |||||||||
Foston Pete | 453 | 454 | 644 | |||||||
foton | 1030 | |||||||||
Fozzy-SP | 317 | |||||||||
Frank A. | 1172 | |||||||||
Frankie Baby | 342 | |||||||||
Franz | 788 | |||||||||
Freddy61069 | 282 | |||||||||
Fredylee | 223 | 1329 | ||||||||
FreeMagenta | 1050 | |||||||||
freeme | 514 | |||||||||
Fritz t. Cat | 484 | |||||||||
Funzel67 | 990 | |||||||||
fuzun | 1074 | |||||||||
fyesilova | 535 | |||||||||
g60 | 290 | |||||||||
g_sintornillos | 126 | |||||||||
gamezawy | 38 | 336 | ||||||||
gangstead | 53 | 922 | ||||||||
garrybunk | 254 | |||||||||
gboss | 832 | |||||||||
gds95 | 1199 | |||||||||
gedasd | 1309 | |||||||||
geepaw | 1038 | |||||||||
gehrmo | 289 | |||||||||
geo1952 | 455 | 457 | ||||||||
ger-slash | 416 | |||||||||
Gerrh | 531 | 1163 | 1164 | 1285 | ||||||
Gerrit | 106 | |||||||||
getbully | 609 | 1263 | ||||||||
Gilatabar | 638 | |||||||||
giorgoskok | 306 | 493 | 1092 | |||||||
GIR | 804 | 818 | ||||||||
gisewhcs | 384 | |||||||||
Gj | 580 | 581 | ||||||||
gleamer | 432 | |||||||||
GlinnDamar | 1342 | |||||||||
gnatx | 588 | 824 | ||||||||
goatfarmer | 770 | |||||||||
GoldenBatt | 383 | 589 | 590 | |||||||
gorb507 | 811 | 812 | ||||||||
goshdogit | 11 | 12 | 40 | 120 | 121 | 543 | 556 | 928 | ||
gpapa693 | 79 | |||||||||
gravelmonkey | 1027 | |||||||||
green_comet | 601 | |||||||||
GreenShrike | 190 | |||||||||
gregor | 215 | |||||||||
GTsuperheros | 179 | |||||||||
Gtt980 | 936 | |||||||||
guerrilla154 | 1316 | |||||||||
Guggga | 538 | |||||||||
GulfCoast | 880 | |||||||||
gungoat | 44 | |||||||||
Gunnerboy | 252 | 967 | ||||||||
Guns712 | 1300 | 1301 | ||||||||
h2o | 181 | 476 | ||||||||
Hairy_Steve | 340 | |||||||||
hank | 258 | |||||||||
Hardware | 1071 | 1200 | ||||||||
Hauwexis | 845 | 846 | 847 | 848 | ||||||
haxquiz | 226 | 927 | ||||||||
headburger | 592 | |||||||||
heatwaves | 994 | 1265 | ||||||||
hein11ag | 183 | |||||||||
Herb Tarlek | 931 | |||||||||
Hestbech | 994 | 995 | ||||||||
hexcode | 503 | 672 | ||||||||
Hezekiah | 286 | 759 | ||||||||
hideehoo | 859 | |||||||||
HighCaliber | 177 | 178 | ||||||||
hmihaylov | 502 | |||||||||
Hobo | 220 | |||||||||
hunter1 | 116 | 720 | 721 | |||||||
hurleyy | 993 | |||||||||
I_like_lamb | 915 | |||||||||
Ian2381 | 150 | |||||||||
igeigeige | 890 | |||||||||
IH8MYX | 546 | |||||||||
ii_pennies | 481 | |||||||||
ikaruz_500 | 989 | |||||||||
Illumenated | 426 | |||||||||
illusioned | 954 | |||||||||
Ilmatic | 1253 | 1332 | ||||||||
ilovejesuschrist | 294 | 295 | ||||||||
ImA4Wheelr | 19 | |||||||||
ISO | 705 | 734 | 929 | 930 | ||||||
iwandutchy | 1047 | |||||||||
J-Dub74 | 461 | |||||||||
J_R_J | 675 | |||||||||
jack-bkk | 356 | |||||||||
jacktheclipper | 1108 | |||||||||
Jailbrake | 1034 | 1090 | ||||||||
JakeDjanitor | 46 | |||||||||
Jalben | 187 | |||||||||
jama | 635 | |||||||||
Jambo | 912 | |||||||||
james y | 1043 | 1044 | ||||||||
javipiloto | 1154 | |||||||||
jaynick | 1048 | |||||||||
JayT | 62 | |||||||||
Jayzed | 1214 | |||||||||
jb1 | 224 | |||||||||
jdunlap27284 | 164 | |||||||||
jealous57 | 81 | |||||||||
Jensa41 | 731 | 732 | ||||||||
Jerommel | 637 | |||||||||
jerrod | 512 | |||||||||
jescereal | 228 | |||||||||
Jesjes | 153 | 154 | ||||||||
jfalk1 | 918 | |||||||||
jhalb | 297 | |||||||||
jhullin | 159 | 751 | ||||||||
jingleberry | 1022 | |||||||||
Jinx | 93 | |||||||||
jkbam | 550 | |||||||||
jmoots | 268 | |||||||||
jmpaul320 | 95 | 299 | ||||||||
jmwhite151 | 482 | 851 | 852 | 853 | ||||||
Joat | 184 | |||||||||
JockRobbins | 717 | |||||||||
Joe Darkness | 620 | |||||||||
joe1512 | 534 | |||||||||
joeangi | 756 | |||||||||
joechina | 633 | |||||||||
Joey Adams | 1021 | 1132 | ||||||||
John-Galt | 463 | |||||||||
Johnhywash1 | 966 | |||||||||
johnnydoe | 1227 | |||||||||
JohnnyMac | 496 | |||||||||
johnpc | 955 | |||||||||
johny723 | 1082 | |||||||||
Jonandreadolan | 1072 | |||||||||
JonnyC | 576 | |||||||||
JordanZHP | 1078 | 1196 | ||||||||
josephqool | 1061 | |||||||||
jpcuba | 684 | |||||||||
JPLight | 23 | 646 | ||||||||
JPM3 | 263 | 264 | ||||||||
JS721 | 216 | |||||||||
jsmn4vu | 793 | |||||||||
Jtm94 | 1035 | |||||||||
Juanesdan | 118 | |||||||||
juaquin | 219 | |||||||||
Juggeli | 745 | |||||||||
jurasik1 | 1231 | |||||||||
justanotherguy | 541 | 712 | 1080 | |||||||
Jvrthp321 | 691 | |||||||||
jycheang | 1009 | |||||||||
k-wong | 542 | 1005 | ||||||||
Kafar | 9 | |||||||||
kahvitahra | 796 | |||||||||
Kalchev | 400 | |||||||||
kali stupa | 1217 | |||||||||
Kalihi | 836 | |||||||||
KawiBoy1428 | 230 | |||||||||
kaybi | 1033 | |||||||||
Kazik | 1315 | |||||||||
kbro | 168 | |||||||||
keengeorge | 309 | 310 | ||||||||
KeepingItLight | 992 | |||||||||
Keepitsharp | 175 | |||||||||
Keisari | 1211 | 1212 | ||||||||
keithd | 753 | |||||||||
KenE | 355 | |||||||||
Kenjii | 385 | |||||||||
Kentuckywindage | 797 | 872 | ||||||||
Kepling | 333 | |||||||||
KFulton | 1331 | |||||||||
khas | 628 | |||||||||
Khuan | 1148 | |||||||||
KIKY | 1340 | |||||||||
Killforfood | 272 | 379 | ||||||||
Kindle | 698 | |||||||||
KingSmono | 578 | |||||||||
kiriba-ru | 525 | |||||||||
Kiukas | 640 | |||||||||
KiwiKane | 174 | |||||||||
Kkelleher | 99 | 100 | 101 | 102 | ||||||
Kloepper Knife Works | 194 | 195 | 196 | |||||||
knightstalker | 1219 | |||||||||
kntx | 1073 | 1116 | 1189 | |||||||
knudsengj | 1106 | |||||||||
Koaksijalac | 104 | |||||||||
Kodachrome40 | 170 | 1282 | ||||||||
KoekieMonster | 161 | |||||||||
kommessy | 108 | |||||||||
korpzgrinda | 1029 | 1133 | ||||||||
kotobuki | 799 | 1143 | 1144 | |||||||
koyotee | 276 | |||||||||
Kozy | 58 | 129 | ||||||||
krutone | 1298 | |||||||||
Kulumatic | 914 | |||||||||
Kurt_Norway | 593 | |||||||||
Kusie | 8 | 17 | ||||||||
KutKhemist | 123 | |||||||||
Kysumi | 925 | |||||||||
LAB | 259 | |||||||||
lachesis | 673 | |||||||||
lalomt | 1167 | |||||||||
Lamont56 | 808 | |||||||||
lamper | 727 | 1171 | ||||||||
lanceb1b | 884 | |||||||||
laststance | 972 | |||||||||
lawallac | 393 | 394 | ||||||||
Lazy-R-us | 25 | 900 | 1249 | 1250 | ||||||
Le_Zouave | 71 | |||||||||
leaftye | 694 | 1103 | 1183 | 1184 | ||||||
LEDtec | 823 | |||||||||
legan710 | 1088 | |||||||||
Legolas Jr. | 130 | |||||||||
leroycp | 236 | 266 | 450 | 451 | ||||||
Lexel | 696 | 1287 | ||||||||
Lfatman | 707 | |||||||||
Liber8 | 537 | |||||||||
lichtpfadfinder | 1292 | |||||||||
Light of Earendil | 700 | |||||||||
lightbulb | 281 | |||||||||
lightknot | 471 | 492 | 598 | |||||||
lightlight22 | 772 | 920 | 1040 | 1328 | ||||||
lightmog | 72 | |||||||||
lightx | 757 | |||||||||
Lilien | 978 | |||||||||
Lion42 | 246 | |||||||||
lionheart_2281 | 33 | |||||||||
litcrit | 871 | |||||||||
Litefighter | 1320 | 1334 | 1335 | |||||||
LloydV | 767 | |||||||||
Loneman | 510 | 903 | ||||||||
longmire | 1256 | |||||||||
Lopan | 1069 | |||||||||
lovetheguitar | 981 | |||||||||
Lowtech | 1042 | 1193 | ||||||||
ludolf | 348 | |||||||||
luisgcan | 1162 | |||||||||
Lumenmaster17 | 1145 | 1146 | 1147 | |||||||
Lumens Industry | 634 | |||||||||
lumiere | 231 | |||||||||
Lund1660 | 64 | 439 | ||||||||
luxlad | 831 | |||||||||
lyse99 | 1012 | |||||||||
Lyubo Yanev | 427 | 428 | 429 | 536 | ||||||
M4D M4X | 350 | |||||||||
M78 | 157 | 337 | 1007 | |||||||
MACS0647 | 313 | |||||||||
MAD TM26 | 656 | 657 | ||||||||
Magbrite | 584 | |||||||||
magnet | 302 | |||||||||
MagPap | 794 | |||||||||
Maiden666 | 92 | |||||||||
maildroid | 331 | |||||||||
Majoroverkill | 919 | |||||||||
malamask | 113 | |||||||||
mandala | 952 | 953 | ||||||||
manithree | 1255 | |||||||||
Manulous | 1270 | |||||||||
ManWithoutShadow | 1100 | 1299 | ||||||||
Mapache | 4 | |||||||||
markalike | 602 | |||||||||
Marothar | 1236 | |||||||||
marsalla | 475 | |||||||||
Martini | 82 | 726 | ||||||||
martook | 48 | |||||||||
martytown | 976 | |||||||||
Masejoer | 842 | |||||||||
Matchoo | 905 | |||||||||
matkovicha | 1185 | |||||||||
Matomoto | 1324 | |||||||||
mattlward | 16 | 34 | 214 | |||||||
MauiSon | 42 | 979 | ||||||||
maukka | 225 | 627 | ||||||||
Maxxsounds | 681 | |||||||||
MBuitendorp | 1210 | |||||||||
mcfarlie6996 | 964 | 965 | ||||||||
MCT | 162 | |||||||||
Mecallie | 1051 | |||||||||
MechEngVictor | 275 | |||||||||
Medvegy | 660 | |||||||||
Melven | 167 | |||||||||
meti | 470 | |||||||||
metz3006 | 843 | |||||||||
Meyer | 138 | |||||||||
MG | 353 | |||||||||
mhanlen | 77 | |||||||||
mi bill | 127 | |||||||||
Micael | 858 | |||||||||
Miguel_79 | 1114 | 1129 | ||||||||
Miguelintegral | 1175 | |||||||||
mikeyx | 622 | |||||||||
Mindaugass | 769 | 1081 | ||||||||
Minimoke | 30 | 975 | ||||||||
miswas | 760 | |||||||||
Mitko | 26 | 27 | ||||||||
mitrhandir | 1303 | |||||||||
mizjif | 714 | |||||||||
Mkduffer | 600 | |||||||||
mlodyulek | 1283 | |||||||||
moemin | 375 | |||||||||
MontyPyfon | 66 | |||||||||
moridin | 907 | |||||||||
Morpheus | 613 | |||||||||
MorpheusT1 | 762 | |||||||||
MortyDuck | 764 | |||||||||
MountainKing | 438 | 445 | ||||||||
MountainMan | 786 | 787 | ||||||||
mozart.f | 314 | |||||||||
Mr.Poppy | 192 | 267 | 1247 | 1308 | ||||||
Mr.Scott | 251 | 1077 | ||||||||
mrheosuper | 1110 | |||||||||
mrkelvin | 606 | |||||||||
MRsDNF | 325 | 326 | ||||||||
mrstealyourgains | 1014 | |||||||||
msg1285 | 173 | |||||||||
Mstevens113 | 114 | |||||||||
Mt.B | 392 | |||||||||
MtnDon | 158 | 498 | ||||||||
mud_muncher | 624 | |||||||||
mudguts | 680 | 716 | ||||||||
Muto | 20 | 242 | 689 | |||||||
mutts13 | 1343 | 1348 | ||||||||
muzzleblast? | 89 | |||||||||
mxlu | 396 | |||||||||
MyDangus | 1181 | |||||||||
myowin | 213 | 1235 | ||||||||
myst999 | 198 | 728 | 1266 | 1267 | ||||||
nanojack | 1036 | |||||||||
narin000 | 524 | |||||||||
Nathan42 | 946 | 987 | ||||||||
Navin_R_Johnson | 817 | |||||||||
neckbear | 935 | |||||||||
needmorlts | 911 | |||||||||
Neilyboy | 1307 | |||||||||
netprince | 176 | 378 | ||||||||
nexrace1 | 579 | |||||||||
nfetterly | 362 | 366 | ||||||||
Nguyen | 1277 | 1293 | ||||||||
nickdude | 591 | |||||||||
Nickke | 604 | |||||||||
Nicolaas | 857 | |||||||||
Nicolicous | 270 | |||||||||
Night Light | 1093 | |||||||||
NightLight | 369 | |||||||||
Nightshade | 574 | |||||||||
niktak11 | 782 | |||||||||
Nil | 959 | 960 | ||||||||
Nite Shadow | 1001 | |||||||||
Nitetime | 163 | |||||||||
nitrader0 | 1203 | |||||||||
nnmnu1 | 1349 | |||||||||
No Agenda | 431 | |||||||||
nofear87 | 382 | |||||||||
Noki | 573 | |||||||||
noob | 828 | 833 | 1025 | |||||||
Nord | 1170 | |||||||||
Nortson | 810 | |||||||||
novice1 | 338 | |||||||||
nqcken | 119 | 241 | ||||||||
nskn71 | 1136 | |||||||||
NuggetMcNugget | 166 | 332 | ||||||||
ObiWan-Kenobi | 422 | 423 | ||||||||
octav | 666 | |||||||||
OdorlessCurves | 529 | 530 | ||||||||
olivedrab | 658 | |||||||||
OrangePeel | 1275 | 1288 | ||||||||
orinjuse | 835 | |||||||||
Orionz23 | 1168 | |||||||||
osb40000 | 193 | |||||||||
OscarM | 1290 | |||||||||
Oswald3211 | 724 | |||||||||
oto | 888 | |||||||||
Ozythemandias | 625 | |||||||||
Pablogy | 441 | |||||||||
PabloVerde | 1037 | |||||||||
pacbough | 149 | |||||||||
papaslightsaber | 583 | 1125 | 1126 | |||||||
patchythepirate | 704 | |||||||||
patmet | 1347 | |||||||||
patmurris | 55 | |||||||||
Paul321 | 139 | |||||||||
pawwright | 151 | |||||||||
PBWilson | 557 | 558 | ||||||||
peabody | 207 | |||||||||
Peetz | 311 | |||||||||
Pegaso | 122 | |||||||||
Peho | 112 | |||||||||
pepe2017 | 1305 | |||||||||
pepinfaxera | 1158 | |||||||||
perche | 1155 | |||||||||
peterlcole | 924 | |||||||||
peteybaby | 549 | |||||||||
petr9999 | 1137 | |||||||||
Petroleum Lantern Guy | 891 | |||||||||
Phoenix_FIN | 395 | |||||||||
Pidro | 465 | |||||||||
pieman7 | 670 | |||||||||
pirate joe 22 | 678 | 679 | 783 | 784 | ||||||
piyoman | 840 | |||||||||
plntigrado | 1153 | |||||||||
pommie | 54 | |||||||||
pook | 330 | |||||||||
pooptoast | 519 | |||||||||
powerfultorches | 569 | |||||||||
praveendk | 437 | |||||||||
presterjohn | 586 | 715 | ||||||||
Presumptuous | 653 | 654 | 655 | |||||||
Primal | 364 | |||||||||
prisma | 401 | |||||||||
Prometheus | 1149 | |||||||||
ProtaBLF | 419 | |||||||||
pscal | 376 | |||||||||
puccio1969 | 76 | |||||||||
Pukachi | 205 | |||||||||
pukoid | 868 | |||||||||
Pulsar13 | 288 | |||||||||
qandeel | 631 | 632 | ||||||||
R.D. | 974 | |||||||||
radb | 856 | |||||||||
rag | 283 | 298 | ||||||||
Ragsy | 499 | 1117 | ||||||||
raiko | 570 | |||||||||
rajun50 | 651 | |||||||||
Randolph | 212 | |||||||||
RapidLux | 1346 | |||||||||
Rat_Racer | 999 | |||||||||
RaVeN | 160 | |||||||||
raynman | 706 | |||||||||
rdoc613 | 879 | |||||||||
red72vw | 521 | |||||||||
regaia | 1008 | |||||||||
reliant_turbo | 710 | 850 | ||||||||
ReManG | 320 | |||||||||
reno | 1118 | |||||||||
retiro675 | 352 | 826 | ||||||||
rexdog | 442 | 515 | ||||||||
rfd673 | 747 | |||||||||
ricardon | 300 | |||||||||
Ricflair | 323 | |||||||||
Rick | 199 | |||||||||
rjorge | 708 | |||||||||
rmkline | 436 | |||||||||
Rob_K | 244 | |||||||||
robbobus | 233 | |||||||||
Roberrt777 | 185 | |||||||||
RobertB | 140 | |||||||||
RocketTomato | 766 | |||||||||
RockHugger | 1173 | |||||||||
Romey310 | 969 | 970 | ||||||||
RonMuller | 111 | |||||||||
Roter | 649 | |||||||||
RotorHead64 | 1284 | |||||||||
Rpdos | 1180 | |||||||||
Rska | 650 | |||||||||
Rsqweezy | 814 | |||||||||
rufrydr | 765 | |||||||||
Rufusbduck | 60 | |||||||||
Rxich | 866 | |||||||||
ryukin2000 | 1220 | |||||||||
sac02 | 645 | 908 | 1215 | 1216 | ||||||
saf99 | 755 | |||||||||
Saigon | 247 | |||||||||
SamHaLeKe | 485 | |||||||||
samis | 509 | |||||||||
samnavy | 73 | |||||||||
san san | 926 | 1130 | 1131 | |||||||
sandanbob | 532 | |||||||||
Sarge930 | 86 | |||||||||
Savydude | 1222 | |||||||||
SawMaster | 45 | |||||||||
saypat | 141 | |||||||||
sb56637 | 191 | |||||||||
scarnific | 566 | |||||||||
scdaf | 271 | 296 | ||||||||
Schkü | 614 | |||||||||
schlockproof | 612 | |||||||||
Sciencetists | 257 | |||||||||
SciFiFreak | 31 | |||||||||
Scooby | 582 | |||||||||
Scooter000 | 315 | |||||||||
scootypuffjr | 844 | |||||||||
Scorpia | 596 | |||||||||
scotlarock | 329 | 1085 | ||||||||
Scottland | 334 | |||||||||
Scotty | 746 | |||||||||
scs | 80 | |||||||||
sebastiang | 611 | |||||||||
SebaZ74 | 1239 | 1240 | ||||||||
SeenTheLight | 301 | 819 | ||||||||
SFB | 1109 | |||||||||
Sgtpev | 206 | |||||||||
Shadowcactus | 916 | |||||||||
Shadowfax | 341 | |||||||||
Sharpie | 354 | |||||||||
shimano3000 | 409 | |||||||||
shimey | 211 | |||||||||
shirnask | 61 | 733 | ||||||||
Shoe | 957 | |||||||||
shogan | 227 | |||||||||
Shur | 284 | |||||||||
SIGShooter | 368 | |||||||||
Silent_Star | 1190 | |||||||||
Silentcropduster | 667 | |||||||||
Simplelight | 961 | 962 | ||||||||
slackwolf | 885 | 886 | ||||||||
slackwolf 3rd | 1000 | |||||||||
Sledge | 980 | 985 | 986 | 1326 | ||||||
Sledgestone | 677 | 841 | ||||||||
slickpenguin | 643 | 854 | ||||||||
slimkango | 52 | 1207 | ||||||||
slow2go | 221 | 222 | 692 | 1139 | 1140 | 1141 | 1278 | 1279 | 1280 | |
smed1275 | 494 | |||||||||
Smittymojo | 768 | 1142 | ||||||||
SmokinH | 855 | |||||||||
Snoballz | 1031 | |||||||||
SoCalTiger | 1344 | |||||||||
sochi111 | 1032 | |||||||||
Sofa | 834 | |||||||||
sol | 291 | 292 | ||||||||
SolarLumen | 776 | |||||||||
solRNY | 1291 | |||||||||
somnambulism | 562 | |||||||||
Sonpham | 621 | |||||||||
southland | 142 | 143 | 144 | 145 | ||||||
sp5it | 94 | 1201 | ||||||||
spade413 | 1178 | |||||||||
sparkyDK | 1188 | |||||||||
specialk | 865 | |||||||||
Speed4goal | 413 | |||||||||
Speedsix | 1083 | |||||||||
spkzzz | 474 | 526 | ||||||||
Sprinkles | 279 | 778 | 901 | |||||||
srs2000 | 1187 | |||||||||
stanley-beamish | 107 | |||||||||
starcrazed | 1330 | |||||||||
stareye | 540 | |||||||||
staticx57 | 238 | |||||||||
steel_1024 | 709 | |||||||||
Steenbhg | 701 | 1205 | 1206 | 1268 | ||||||
steepdrop | 435 | 497 | ||||||||
Stephen Elliott | 1322 | |||||||||
stephenk | 269 | |||||||||
steve42 | 1016 | |||||||||
Stevejj | 1218 | |||||||||
SteveMidwest | 1289 | |||||||||
stevez32 | 822 | |||||||||
Stittville Ed | 85 | 998 | ||||||||
Stoneface | 758 | 1127 | ||||||||
strango | 96 | |||||||||
strayz | 505 | |||||||||
Streamer | 1246 | |||||||||
strmix | 676 | |||||||||
Subterrestrial | 1003 | |||||||||
Sukoi | 642 | 1010 | ||||||||
Sullysat | 418 | |||||||||
Suncoaster | 682 | |||||||||
Swennie | 895 | |||||||||
Syncmasterklop | 867 | |||||||||
syracuse | 349 | |||||||||
T-boon | 304 | |||||||||
T18 | 390 | 1257 | ||||||||
t3rminal | 1213 | |||||||||
tapir | 489 | |||||||||
tarver | 132 | 229 | ||||||||
Tarvos | 15 | |||||||||
tas69 | 380 | |||||||||
tatasal | 506 | |||||||||
teacher | 321 | 1134 | ||||||||
tebeve | 893 | |||||||||
techieman33 | 456 | |||||||||
Tecmo | 57 | |||||||||
tekwyzrd | 37 | |||||||||
tenohfive | 802 | |||||||||
Tete | 217 | |||||||||
Texas_Ace | 472 | 473 | ||||||||
The Burgh | 235 | |||||||||
The Grand Pooh-Bah | 1056 | 1057 | ||||||||
The Imp | 1242 | |||||||||
The Jinx | 522 | 699 | ||||||||
The Last Katun | 90 | |||||||||
The Miller | 1 | 2 | ||||||||
thebaum | 585 | 807 | ||||||||
thecrc | 1177 | |||||||||
TheDude | 415 | |||||||||
TheHebrewHammer | 820 | 821 | ||||||||
TheJo | 1053 | |||||||||
TheMadcap | 97 | |||||||||
themaindude | 343 | 1094 | 1095 | |||||||
Theodore41 | 520 | |||||||||
theoldbill | 59 | |||||||||
TheOnlyDocc | 1135 | |||||||||
thijsco19 | 24 | |||||||||
tigris99 | 603 | |||||||||
timcodes | 1004 | 1017 | ||||||||
tindrum42 | 1059 | 1060 | ||||||||
tinowrx | 572 | |||||||||
Tixx | 371 | |||||||||
Tjhosan | 273 | |||||||||
Tjohn | 940 | 941 | 942 | 943 | 944 | |||||
Tmik | 287 | |||||||||
tmxod | 771 | |||||||||
Toccata | 1241 | |||||||||
Tom E | 28 | 29 | 874 | 875 | 1223 | 1224 | ||||
Tom_182 | 695 | 780 | ||||||||
tomtaylor | 201 | |||||||||
tonylim | 43 | |||||||||
torchjunkie | 483 | 597 | ||||||||
toxiccoccyx | 1107 | |||||||||
ToyKeeper | 339 | |||||||||
tracerfire | 1317 | |||||||||
Trashman531 | 285 | |||||||||
Trasnodel | 729 | |||||||||
trevglas | 200 | |||||||||
trevize | 1165 | |||||||||
treysoucie | 789 | |||||||||
tristanxoxo | 240 | 1070 | ||||||||
troisanh | 91 | |||||||||
tronx | 674 | |||||||||
TRoPHeuS | 1152 | |||||||||
tru3s1lv3r | 39 | |||||||||
Tunerman | 1002 | |||||||||
tungkon | 1011 | |||||||||
TurboLion | 917 | |||||||||
turbopscl | 892 | |||||||||
turpulator | 1066 | |||||||||
tzmxxhh | 21 | |||||||||
Ulric | 1198 | |||||||||
unit311 | 849 | |||||||||
unknown00101 | 548 | |||||||||
uqs1000 | 357 | |||||||||
Vagany | 647 | |||||||||
VaKo | 208 | |||||||||
Valdorg | 1202 | |||||||||
Van | 491 | |||||||||
Vanq86 | 1176 | |||||||||
vas | 133 | |||||||||
vasa_visost | 668 | |||||||||
Vattern | 18 | |||||||||
velocraig | 781 | |||||||||
vex_zg | 730 | |||||||||
Viamede | 948 | |||||||||
vinte77 | 414 | |||||||||
Volks1973 | 743 | |||||||||
vulpes | 539 | |||||||||
vwpieces | 881 | |||||||||
Wackyvegan | 156 | |||||||||
walty | 280 | |||||||||
WarHawk-AVG | 420 | 421 | ||||||||
warzi1975 | 528 | |||||||||
wattstar | 791 | |||||||||
websterjody | 996 | 1105 | ||||||||
weklund | 460 | |||||||||
Werner | 10 | |||||||||
WestBam | 1333 | |||||||||
westcoastwonders | 639 | |||||||||
Wieselflinkpro | 125 | 750 | 1079 | |||||||
Wildcat | 827 | 945 | ||||||||
wildmermaid | 1091 | |||||||||
Wildthing | 533 | |||||||||
willmo | 605 | 882 | ||||||||
WillyD | 303 | |||||||||
wilwok | 1076 | 1258 | ||||||||
Wineslurper | 554 | 555 | ||||||||
wisefire | 869 | |||||||||
wishiwereaskibum | 587 | |||||||||
wkhchin81 | 477 | |||||||||
Wojto | 1325 | |||||||||
WolfA | 69 | |||||||||
Wrathbringer27 | 41 | |||||||||
wunderhe | 115 | |||||||||
Wyre | 1269 | |||||||||
Xandre | 527 | |||||||||
xCentrino | 1314 | |||||||||
xed888 | 305 | |||||||||
xelario | 773 | |||||||||
xjsnake | 36 | |||||||||
xray291 | 1192 | |||||||||
xtrosity | 723 | |||||||||
XXX-Man | 1197 | |||||||||
xzel87 | 665 | |||||||||
yasenf | 1006 | 1232 | 1233 | 1273 | 1274 | |||||
yclongthrow | 898 | 899 | ||||||||
YoFlash | 744 | |||||||||
Yokiamy | 1245 | |||||||||
Yourrid | 1101 | 1102 | ||||||||
zachary6227 | 1297 | |||||||||
zak.wilson | 182 | |||||||||
Zanders | 792 | |||||||||
zara | 180 | |||||||||
zelee | 22 | |||||||||
Zeratull | 703 | |||||||||
zeroair | 452 | |||||||||
zifzif | 1243 | |||||||||
zipelgas | 386 | |||||||||
zoysiamo | 1251 | |||||||||
ZozzV6 | 626 | |||||||||
×73rmin8r | 1063 |
1001 names
1346 lights
- 2 DOGS, 264, 2Ace, 5ar, 7pot, a12luke, a_idiot, Aardvark Spleen, Abe87, Abqjohnny
- abril, adirondackdestroyer, adrianlights, AEDe, Ag76, aggillator, aginthelaw, Agiri, aim120, AirBreaker
- akhyar, akoposilester, akovia, albertopnp, Alcius, alejandrov, alex64, AlexGT, Alkpwn77, allthumbs
- alphazeta, alternety, Alux, amplificus, Andmiller, andrewmac, Andybibbville, Andyman?, Angel Martínez, ant0
- Antenne, Anthon, antiparanoico, AppA, aprendiz, apt323, archi, archimedes, aremihc, ARMS.AARON
- ARsee, Arufonsi, aslpg, asnidi2, asot, Astromanic, AsylumSweep, atbglenn, Atom00, Autoclave
- Awdtsi, Awkward Stretch, AwkwardPause, b1i1l1l1y1, B42, BackpackNY, bakalakos, balazs1956, baldo21, Bam35
- bamawthu, banker, basslovin808, Bastarrdo, Batch1, battletross, bawilson2, Bc412, bd52, BDM
- BDWrabbit, BeardedRaleigh, bella-headlight, Bernard, Bevo, bhuge00, bigpix, bigrick, bikedave99, bikenber73
- Bill 63, Bill_tong, Billcheese5, bionictony, bkling, BlackList, bladesmith3, BLFD80, BlindingL5s, blinker
- blinky, blueb8llz, Bluzie, bmaddison, Boaz, BobbyMK, bobdotorg, bobofire, Bogdan, bogdanr
- Bohemian, bonfire, Bong lick, Bonham, borealis, BorisBar, Boro, bossf350, Box, Brettg4215
- Brian Metcalfe, BrianK, BrianTheJay, brightlights, brjones, brno602, brted, Bruno28, BT100, Bungle88
- Buzzy243, bwl123, cabfrank, Caleb, Caleb-v, Calmaja, Cano, Captainvideo, caramba, carmantl
- casi29061965, cavorite, Cawi, cbrake10, cclight, cdjaney, Chadvone, Charga, charles lin, CheapThrills
- cheesecheeks, ChibiM, Chicken Drumstick, chinooker, chooma, chrisc, churchilllafemme, CircaM, Cjlee89, cjoe7
- CJW, clagged, clange50, clinicdoc, Cliwilnew, cloggy, cmflippen, cnrffl1, cocoschnauzer, contigo
- Coolerness, coolriku, Corzy, Couchmaster, cpd800t, CrashOne, Crazyeddie, Creepo, cristhemuso, crx88ia
- cujo255, cwb, cypher1024, cypherz, Cythras, D10ten, Dadpool, dafarui, daninho, DarkerInSol
- darkpenguin, darol, darrenm, darrylo, DarthTader, datiLED, dave101, DavidEF?, davidkappelt, davidvns
- davos, DB Custom, dbesselt, DBSAR, DBSS, deathless, Deep skull, DeJaVu, dekozn, Dennis
- dentillozie, Dep668, derfyled, derpilgerer, Desmo, devdvr, dezoe, dhsvcs, dicksog, digitaltc
- Dimking, Dirt, Dirty_Pierre, DiscoJoe, djburkes, Djozz, dmbaty, Dobtruckers, DOCFAR, Docp723
- Doctawho, dodo, dogany, Dogsrule, donpachi, dotBLF, doubleone44, downlinx, doxerino, Dr Forinor
- Dradge, Dralf, Dregs, DrHook59, driveX, DrJones, DT101, dudunphy, Duke, dumptruck
- Dusty, Dutcheee, duvallite, dw911, Dwantink, e10sno, Easyrr, eb1888, ebosh, ediaz
- eebowler, Eggun, egrep, Eivwer, electricjelly, ElginAgain, emarkd, embee, Enelooper, engber
- ERDOS, Erethryn, erikk365, Esskay, Etex, euphxenos, everydaysurvivalgear, Evilc, EyeballFryer, Fadetoblack
- fantomR, Far Thrower, Farmboy24, Farns, Fatlight, FBsLights, fcrespi, fed893, fedcas, feralcomprehension
- finges, fireblade893, firedome, Firelight2, fishlite5, fixed it, fixvid, Flash Voyager, flashination, FlashMax
- Flashy Mike, Flifish48, Flintrock, fluffman86, FmC, fonfan, fonLED, Ford Prefect, Foston Pete, foton
- Fozzy-SP, Frank A., Frankie Baby, Franz, Freddy61069, Fredylee, FreeMagenta, freeme, Fritz t. Cat, Funzel67
- fuzun, fyesilova, g60, g_sintornillos, gamezawy, gangstead, garrybunk, gboss, gds95, gedasd
- geepaw, gehrmo, geo1952, ger-slash, Gerrh, Gerrit, getbully, Gilatabar, giorgoskok, GIR
- gisewhcs, Gj, gleamer, GlinnDamar, gnatx, goatfarmer, GoldenBatt, gorb507, goshdogit, gpapa693
- gravelmonkey, green_comet, GreenShrike, gregor, GTsuperheros, Gtt980, guerrilla154, Guggga, GulfCoast, gungoat
- Gunnerboy, Guns712, h2o, Hairy_Steve, hank, Hardware, Hauwexis, haxquiz, headburger, heatwaves
- hein11ag, Herb Tarlek, Hestbech, hexcode, Hezekiah, hideehoo, HighCaliber, hmihaylov, Hobo, hunter1
- hurleyy, I_like_lamb, Ian2381, igeigeige, IH8MYX, ii_pennies, ikaruz_500, Illumenated, illusioned, Ilmatic
- ilovejesuschrist, ImA4Wheelr, ISO, iwandutchy, J-Dub74, J_R_J, jack-bkk, jacktheclipper, Jailbrake, JakeDjanitor
- Jalben, jama, Jambo, james y, javipiloto, jaynick, JayT, Jayzed, jb1, jdunlap27284
- jealous57, Jensa41, Jerommel, jerrod, jescereal, Jesjes, jfalk1, jhalb, jhullin, jingleberry
- Jinx, jkbam, jmoots, jmpaul320, jmwhite151, Joat, JockRobbins, Joe Darkness, joe1512, joeangi
- joechina, Joey Adams, John-Galt, Johnhywash1, johnnydoe, JohnnyMac, johnpc, johny723, Jonandreadolan, JonnyC
- JordanZHP, josephqool, jpcuba, JPLight, JPM3, JS721, jsmn4vu, Jtm94, Juanesdan, juaquin
- Juggeli, jurasik1, justanotherguy, Jvrthp321, jycheang, k-wong, Kafar, kahvitahra, Kalchev, kali stupa
- Kalihi, KawiBoy1428, kaybi, Kazik, kbro, keengeorge, KeepingItLight, Keepitsharp, Keisari, keithd
- KenE, Kenjii, Kentuckywindage, Kepling, KFulton, khas, Khuan, KIKY, Killforfood, Kindle
- KingSmono, kiriba-ru, Kiukas, KiwiKane, Kkelleher, Kloepper Knife Works, knightstalker, kntx, knudsengj, Koaksijalac
- Kodachrome40, KoekieMonster, kommessy, korpzgrinda, kotobuki, koyotee, Kozy, krutone, Kulumatic, Kurt_Norway
- Kusie, KutKhemist, Kysumi, LAB, lachesis, lalomt, Lamont56, lamper, lanceb1b, laststance
- lawallac, Lazy-R-us, Le_Zouave, leaftye, LEDtec, legan710, Legolas Jr., leroycp, Lexel, Lfatman
- Liber8, lichtpfadfinder, Light of Earendil, lightbulb, lightknot, lightlight22, lightmog, lightx, Lilien, Lion42
- lionheart_2281, litcrit, Litefighter, LloydV, Loneman, longmire, Lopan, lovetheguitar, Lowtech, ludolf
- luisgcan, Lumenmaster17, Lumens Industry, lumiere, Lund1660, luxlad, lyse99, Lyubo Yanev, M4D M4X, M78
- MACS0647, MAD TM26, Magbrite, magnet, MagPap, Maiden666, maildroid, Majoroverkill, malamask, mandala
- manithree, Manulous, ManWithoutShadow, Mapache, markalike, Marothar, marsalla, Martini, martook, martytown
- Masejoer, Matchoo, matkovicha, Matomoto, mattlward, MauiSon, maukka, Maxxsounds, MBuitendorp, mcfarlie6996
- MCT, Mecallie, MechEngVictor, Medvegy, Melven, meti, metz3006, Meyer, MG, mhanlen
- mi bill, Micael, Miguel_79, Miguelintegral, mikeyx, Mindaugass, Minimoke, miswas, Mitko, mitrhandir
- mizjif, Mkduffer, mlodyulek, moemin, MontyPyfon, moridin, Morpheus, MorpheusT1, MortyDuck, MountainKing
- MountainMan, mozart.f, Mr.Poppy, Mr.Scott, mrheosuper, mrkelvin, MRsDNF, mrstealyourgains, msg1285, Mstevens113
- Mt.B, MtnDon, mud_muncher, mudguts, Muto, mutts13, muzzleblast?, mxlu, MyDangus, myowin
- myst999, nanojack, narin000, Nathan42, Navin_R_Johnson, neckbear, needmorlts, Neilyboy, netprince, nexrace1
- nfetterly, Nguyen, nickdude, Nickke, Nicolaas, Nicolicous, Night Light, NightLight, Nightshade, niktak11
- Nil, Nite Shadow, Nitetime, nitrader0, nnmnu1, No Agenda, nofear87, Noki, noob, Nord
- Nortson, novice1, nqcken, nskn71, NuggetMcNugget, ObiWan-Kenobi, octav, OdorlessCurves, olivedrab, OrangePeel
- orinjuse, Orionz23, osb40000, OscarM, Oswald3211, oto, Ozythemandias, Pablogy, PabloVerde, pacbough
- papaslightsaber, patchythepirate, patmet, patmurris, Paul321, pawwright, PBWilson, peabody, Peetz, Pegaso
- Peho, pepe2017, pepinfaxera, perche, peterlcole, peteybaby, petr9999, Petroleum Lantern Guy, Phoenix_FIN, Pidro
- pieman7, pirate joe 22, piyoman, plntigrado, pommie, pook, pooptoast, powerfultorches, praveendk, presterjohn
- Presumptuous, Primal, prisma, Prometheus, ProtaBLF, pscal, puccio1969, Pukachi, pukoid, Pulsar13
- qandeel, R.D., radb, rag, Ragsy, raiko, rajun50, Randolph, RapidLux, Rat_Racer
- RaVeN, raynman, rdoc613, red72vw, regaia, reliant_turbo, ReManG, reno, retiro675, rexdog
- rfd673, ricardon, Ricflair, Rick, rjorge, rmkline, Rob_K, robbobus, Roberrt777, RobertB
- RocketTomato, RockHugger, Romey310, RonMuller, Roter, RotorHead64, Rpdos, Rska, Rsqweezy, rufrydr
- Rufusbduck, Rxich, ryukin2000, sac02, saf99, Saigon, SamHaLeKe, samis, samnavy, san san
- sandanbob, Sarge930, Savydude, SawMaster, saypat, sb56637, scarnific, scdaf, Schkü, schlockproof
- Sciencetists, SciFiFreak, Scooby, Scooter000, scootypuffjr, Scorpia, scotlarock, Scottland, Scotty, scs
- sebastiang, SebaZ74, SeenTheLight, SFB, Sgtpev, Shadowcactus, Shadowfax, Sharpie, shimano3000, shimey
- shirnask, Shoe, shogan, Shur, SIGShooter, Silent_Star, Silentcropduster, Simplelight, slackwolf, slackwolf 3rd
- Sledge, Sledgestone, slickpenguin, slimkango, slow2go, smed1275, Smittymojo, SmokinH, Snoballz, SoCalTiger
- sochi111, Sofa, sol, SolarLumen, solRNY, somnambulism, Sonpham, southland, sp5it, spade413
- sparkyDK, specialk, Speed4goal, Speedsix, spkzzz, Sprinkles, srs2000, stanley-beamish, starcrazed, stareye
- staticx57, steel_1024, Steenbhg, steepdrop, Stephen Elliott, stephenk, steve42, Stevejj, SteveMidwest, stevez32
- Stittville Ed, Stoneface, strango, strayz, Streamer, strmix, Subterrestrial, Sukoi, Sullysat, Suncoaster
- Swennie, Syncmasterklop, syracuse, T-boon, T18, t3rminal, tapir, tarver, Tarvos, tas69
- tatasal, teacher, tebeve, techieman33, Tecmo, tekwyzrd, tenohfive, Tete, Texas_Ace, The Burgh
- The Grand Pooh-Bah, The Imp, The Jinx, The Last Katun, The Miller, thebaum, thecrc, TheDude, TheHebrewHammer, TheJo
- TheMadcap, themaindude, Theodore41, theoldbill, TheOnlyDocc, thijsco19, tigris99, timcodes, tindrum42, tinowrx
- Tixx, Tjhosan, Tjohn, Tmik, tmxod, Toccata, Tom E, Tom_182, tomtaylor, tonylim
- torchjunkie, toxiccoccyx, ToyKeeper, tracerfire, Trashman531, Trasnodel, trevglas, trevize, treysoucie, tristanxoxo
- troisanh, tronx, TRoPHeuS, tru3s1lv3r, Tunerman, tungkon, TurboLion, turbopscl, turpulator, tzmxxhh
- Ulric, unit311, unknown00101, uqs1000, Vagany, VaKo, Valdorg, Van, Vanq86, vas
- vasa_visost, Vattern, velocraig, vex_zg, Viamede, vinte77, Volks1973, vulpes, vwpieces, Wackyvegan
- walty, WarHawk-AVG, warzi1975, wattstar, websterjody, weklund, Werner, WestBam, westcoastwonders, Wieselflinkpro
- Wildcat, wildmermaid, Wildthing, willmo, WillyD, wilwok, Wineslurper, wisefire, wishiwereaskibum, wkhchin81
- Wojto, WolfA, Wrathbringer27, wunderhe, Wyre, Xandre, xCentrino, xed888, xelario, xjsnake
- xray291, xtrosity, XXX-Man, xzel87, yasenf, yclongthrow, YoFlash, Yokiamy, Yourrid, zachary6227
- zak.wilson, Zanders, zara, zelee, Zeratull, zeroair, zifzif, zipelgas, zoysiamo, ZozzV6
- ×73rmin8r,
I sure do like this place.
