Put me on the list.
I’ll take 2 please.
Please put me on the list.
I want at least two.
Yes, Champagne Gold and Dark Grey aavailable. Pic updated in 1st post.
Now the price is 120$. Including 5000mAh battery, type-c charger, cable, and aluminum box.
Box: WubenLight: Box:Put me on the list. What about a group buy on the T102 prometheus? I just want one cause of the name lol
The 1st batch was not perfect, we are making on the new version. 2A charging, XHP70.2
Oh ok. Any idea how long it will be and pricing gonna be similar?
Thanks. You didnt add me to the list for this pen light
Sorry, added.
I like the black version. One more question. Does it use a Parker style ink cartridge?
The light uses this refill, it does write very nicely and fits the hand well. I should have a review up by Monday.
You didn’t add me either. I’m interested in at least two!
Interested in 1
Thanks. It does look very similar to a Parker refill shape wise.
Also interested in 1, though not entirely sure if I need it…
It’s not about needing, it’s about wanting
Any word on whether the new version of the T102 is still going to have a low-voltage stepdown to 40% at 4.0V (!) and a timed stepdown to 50% at 100 seconds? How about shortcuts to something other than strobe?
It is about 2 mins step down. Battery at 3.4V, output drop 50%.
Maybe it’s supposed to be 3.4, but look how mine behaves.
The timed stepdown seems to be shorter than 2 minutes as well - more like 100 seconds. There’s no need for it given this light has a thermal sensor. It definitely does have a thermal sensor, as when I got the light hot running it on other batteries, then popped in the factory battery fresh off the charger, this happened.
I probably sound grumpy here, but my intent isn’t to give you guys a hard time: it’s to help you fix this light so that version 2 can actually be a good.
Maybe it’s supposed to be 3.4, but “look how mine behaves”:T102 stepdown behavior - Album on Imgur. The timed stepdown seems to be shorter than 2 minutes as well - more like 100 seconds. There’s no need for it given this light has a thermal sensor. It definitely does have a thermal sensor, as when I got the light hot running it on other batteries, then popped in the factory battery fresh off the charger, “this happened”:http://i.imgur.com/mCrljOQ.png. I probably sound grumpy here, but my intent isn’t to give you guys a hard time: it’s to help you fix this light so that version 2 can actually be a good.
Thank you, it's really appreciated. I will talk them to upgrade this.
