Yeah, yeah, always picking on me. I need a safe space now. :innocent:
I might have to take some beamshots of it one of these days. For now you will just have to use your imagination. Picture Putin bare-chested on a Grizzly chasing Trump with his hair flapping in the wind, riding a Giant Red Kangaroo, both shielding their eyes from the magnificence.
Thanks and I bet that TK61 rocks, probably fairly similar to this one. Just tons of lumens blasting a tight beam a looooooong way. It impressed me and I don’t impress that easy. XHP-50 dome off in these big reflectors is really something else. Great combo.
Ps. If you ever do convert you pack, make sure you have three strong springs about an inch long. I almost started with springs that were too short. I tested the size before I put everything together and had to find some longer ones. I didn’t do a spring mod yet either, I’m not sure if I will. I think I’m getting pretty close to maxing this emitter out as it is.
Here is a couple pic’s of both, in the SR90 I pulled the brass sink and cut a 32mmx.500mm deep pocket in it to center the Maxtoch XHP70 board, didn’t take any pics, shaved XHP70 P2-1C, then just piggy backed a 5 level FETDD driver.
The TK61 I made a pressed in pocketed 8mm stepped copper sink, direct soldered the board to the copper sink and cut the bottom of the reflector off. I went with the XHP50 J4 5A0 for that old school Incan tint because I want it for Hunting, Storms, all around bad weather light, didn’t think I would like the tint till I went for a walk in the rain, it was a good decision! It has a 6 level + moonlight FETDD piggy backed to the contact board. Like how the shaved XHP50 throws in these big reflector lights too, minor artifact associated with these quad dies, very easy to live with when shaved, very impressive big beam with down range distance!
Figured I might as well have a TK61 flood/thrower to go with my TK61 XHP35 L/R thrower!!
Thanks for the tip on the SR90 battery pack springs, very good to know, and thanks for sharing Brad!!! :+1:
No pictures of the actual work, just the result. I built a black Jaxman E2L from host to 18350 flashlight: BLF X5/X6 driver, 3x Nichia 219B V1 sw45 R9080, very dim lighted tail. Jaxman has improved the led-shelf in the black host compared to the first batch of grey hosts: the ledboard-shelf is super-flat (hardly any AS5 paste was need to fil up the gap) and the board fits without sanding the sides, very nice!. The host and parts (I ordered the board and optic with the host) were very good quality (but I swapped the green o-ring for the lens for a clear one, and I used a short S2+ battery tube from Simon), the build-up was easy and very fast (maybe an hour), and then I made the lighted tailcap and that costed me the rest of the day before it worked and did not interfere anymore with the driver UI :facepalm:
That’s good to here. I just got my grey host from RMM and will be sanding the MCPCB sides. Was the shelf hole big enough for the wires, or did you have to make it bigger? Apparently I will need to enlarge mine.
That looks sick.
Did you have any issues with fibers getting lose when you drilled the switch hole?
Also, have you seen sanded carbon fibre? I think the matte look is very cool, maybe even better than glossy.
Not sure if it is less durable without the coating though.
Sounds like you have experience with the material, I use progressively sized bits and a wooden backing support plus instead of pulling any broken fibres, I cut them off with a scalpel. Helps stop stripping lines. The weave helps stop it too.
Yeah the matte looks intetesting, got some on the way to try. Sanding the gloss isn’t very good.
Built a Convoy M2 with a XP-L HI V2 1A LED and a 8x 7135 driver with guppydrv firmware. It turned out better than I thought it would. I got the host from RMM with an orange peal reflector. I feared that it could be too much of a thrower, but it turned out to be a perfect combination of throw and flood. It has a great beam without any rings or artifacts. A lot of throw for a smaller flashlight.
I had an issue when I first put everything together. The flashlight would not turn on. I initially thought that maybe I reverse connected the LED. But I was able to get the LED to turn on by screwing on the head loosely and moving it back and forth. Then I figured out that the battery tube end was partially anodized and was preventing a good connection. So I sanded the battery tube and then the flashlight worked as expected.
Today I modded my old Lustefire 3XU2-X3. FET driver, longish 24 gauge wires and 3x regular amp batteries does the trick with 3x de-domed XHP-50's. Gets crazy hot on turbo but it's not turning the emitters blue. Nice tint and it's got a great hot spot dead center and of course still has tons of flood.
Just thought I would post a few beamshots of 3 different Thorfire VG10’s I ordered when they had the big sale going on them.
There is not anything special as far as the mods go , but it does show the difference in what the stock light and driver does compared to the other 2 lights I modded.
Both the modded lights have the FET + 7135 Driver - 17mm - MTN-17DDm from Richard at Mountain Electronics. HERE
Also both ends have a spring bypass with 20awg Turnigy wires.
The first one has a XP-L V6 OD that has been dedomed. This one is making 1113 lumens and 4.97 amps at start.
The second one has a XP-L HI V3 3C. This one is making 1081 lumens and 5.91 amps at start.
I guess the Dedomed XP-L V6 is the winner in the efficiency department , although both lights make fairly close to the same lumen numbers.
