i cant find any lube/lubricant/grease/oil for flashlights on Kaidomain or Manafont or Dinodirect wtf
DX is the only place. but out of stock
This Dupont Lube is the best I have had so far. Once it dries it makes the threads feel as smooth as butter.
Thanks I wrote it down, Im going to see if they have it at the store.
"Kreisler, use this one (it also comes in a can):
http://www.amazon.com/Superlube-21030-Multipurpose-Synthetic-Grease/dp/B...
A tube like this will last quite a long time. I picked mine up at Ace Hardware."
Yep, same stuff I use. It works great, lasts a long time and does not stain like a moly grease.
Don't know if they have Ace Hardware in Canada, but that's where I was able to find Super Lube. A couple of dollars for a little tube that will last forever. Looks like vaseline.
Thanks very much for the link...I will go to the Walmart tonight for the SuperLube and if its not there I will order that one in your link. Price looks good and its easy to order.
Harbor Freight carries Superlube.
http://www.harborfreight.com/85-gram-super-lube-grease-cartridge-93744.html
i'll get the nextorch stuff! ( ordering the original superlube from AmazonUSA or ebay costs lotsa shipping. nextorch shipping is free. says the budgeteer. *ggg* )
I was going to suggest Harbor Freight, but then I checked and didn't see Harbor Freight with any stores in Canada. That's where I bought mine. I actually bought it for another purpose, but when I came across a thread where atbglenn posted about using it on flashlights I was glad I already had it!
-Garry
Is it electrically conductive? I read in it's specs that it's thermally conductive but I can't find anywhere that it's electrically conductive.
If the grease says dielectric, it is non-conductive (electrically). I'm not sure if that's important to you or not. You may not want to grease the crap out of your threads with a dielectric grease or you're going to be creating problems with your tailcap connections.
Dielectric grease is a nonconductive grease. As such, it does not enhance the flow of electrical current. Dielectric grease is, however, often applied to electrical connectors, particularly those containing rubber gaskets, as a means of lubricating and sealing rubber portions of the connector.
The widest use of dielectric grease is in high-voltage connections associated with spark plugs. The grease is applied to the rubber boot of the plug wire. This helps the rubber boot slide onto the ceramic insulator of the plug. The grease also acts to seal the rubber boot, while at the same time preventing the rubber from becoming stuck to the ceramic. Generally spark plugs are located in areas of high temperature, and the grease is formulated to withstand the temperature range expected.
Another common use of dielectric grease is on the rubber mating surfaces or gaskets of multi-pin electrical connectors used in automotive and marine engines. The grease again acts as a lubricant and a sealant on the nonconductive mating surfaces of the connector. It is not recommended to be applied to the actual electrical conductive contacts of the connector because it could interfere with the electrical signals passing through the connector.
i use it on non-anno threads and it works fine. no conductivity problems for me.
I have been using Super-Lube since My first flashlight. I was almost out of the 1/2 ounce tube so I was reading on hear about lubes and I went to Lowes and got DuPont Teflon Multi-use Lubricant and there was DuPont Teflon Chain-Saver a waxed based chain lube so I bought both and tried them. I went to Harbor Freight and bought 2-3oz tubes that should last me forever. I didn't care for the DuPont products but that's just me.
Do you have hardware stores where you are? Super Lube is fairly common and easy to find here in the U.S. in Ace (National hardware chain), Home Depot, Sears Hardware etc.
I went to the Walmart...no SuperLube :( Nothing at all really, all they had was half a shelf of WD40 (with a free hockey puck - I live in Canada) and a few other aresol bottles like liquid wrench.
Tomorrow I will check the H-D then the Manafont order...then my goal to put this behind me will be over.
(Couldnt find any fishing-reel grease either...)
I'm no expert, but I've been using silicone grease that I found at Home Depot in the plumbing department for the last 6 - 8 months.
No problems here...
I've been using that Nextorch silicone and while it is great for o-rings, I hate what it does to threads. I'm thinking Mobil 1 might do the trick.
dirtythreadsFoy
dirtythreadsFoy
oh oh, that sounds bad...what do you mean what it does to threads? I dont want to make my lights worse or take away the anodizing...or be harsh to the aluminum.
Id be very careful not to put any grease on the o-rings.
Fenix or someone should make a dedicated flashlight grease and that would that...In the Fenix video the guy has a 5 gallon jug of grease but they dont say what it is... :(
It's not a huge deal but I think there might be something better than silicone . . . or, maybe I could just keep it off the threads?
trilaanderrorFoy
