More on charger wiring setups at: balance charging 18650's / 26650's
yeah, I google a question and it leads me right back to a thread at BLF.
That thread is talking about balance charging the cells, this is not needed if you charge them in parallel and parallel is much faster then balance charging in series.
Simply get a cell holder that is wired in parallel, hook it up and set the current and let it run. No need to bother with anything else. I charge 14 cells at a time like this and they come out perfectly balanced everytime.
Where do you find one of those for, say, four 18650s?
You can find them on ebay or aliexpress pre-wired or bare. I just got bares ones and wired them up myself but if you can’t solder then you can get the pre-wired ones. The wires are usually a bit thin though.
I’ve been wanting a reason to use my rc charger for 18650s, now I have a reason, thanks.
I just hate how slow my nitecore d2 charges. Takes several hours for a single 18650. I can charge 3 5000mah 2s lipos in that time with balancing.
Watch the cell length. A similar holder with the same BLM name at fastech has a note that max cell length is 65mm.
https://www.fasttech.com/products/0/10003906/4816900-3-18650-battery-holder-case
Yep, that will do it. Wire those leads together in parallel and connect it to the B6 and boom, you have a charger capable of 5A charging and if you reflash the firmware, a ton of advanced options and high precision.
Yeah, these holders won’t work for protected cells but I never use protected cells anyways.
I have the Panzer and like it. Also a Litokala500.
Thank you for the link T_A……… :+1:
Hmmm, I have almost all protected cells. Any pointer welcome to a slightly longer cell holder wired parallel.
I have the HobbyKing clone Accucel 6
but I’ve only used it for charging one cell at a time, so far
(e.g. it works fine for the 3.6v NiMH Black and Decker Versapack cylindrical cells)
but I ought to get into multiple-18650 lights at some point, without blowing anything up.
You can get a 26650 holder for protected 18650’s most likely. Mine are a bit longer and should fit a protected cell, I don’t own any protected cells to try though.
Mt friend used to run the Maxamps 1 cell lipos in a range of things, coupled together as what ever he needed to power, but he always charged a bunch of those as 1 cell and then put 20 amps on it.
Still took a while as this was 5450 mah cells.
We lovingly nicknamed the batteries “The LEGO batteries”
These MaxAmps LiPo batteries are 5450mAh (milliamps) or 5.45Ah in capacity. As with all our LiPo pouch batteries, they are assembled in the USA by our Battery Builders here at MaxAmps.
Charger.
https://www.maxamps.com/hyperion-eos0720inet3-ac-dc-balance-charger
If you want to charge a lot of batteries and do it fast.
https://www.maxamps.com/hp-eos0840i-hyperion-eos-840i-8s-dc-balance-charger-1000w
I will probably go that route as i have a few RC chargers too, and they might as well get som exercise charging round cells too beside the square RC batteries.
I think I remember far back in this thread, someone asking about thread locker for the tripod thread, hence this post. I just remembered that post and recently discovered this product for another use.
If something like loctite is used it can be undone with heat and tools no matter what grade is used. But another product is available that won’t harden and is reusable and adjustable. Those are good qualities where one needs increased friction to allow potential removal of the 1/4-20 adapter in the light but not so much friction between the 1/4-20 adapter and the tripod plate. I have a similar issue with firearms and threads that require increased friction but where I don’t want to use hardening Loctite. Vibra-tite VC-3 is such a product. It’s a polymer that requires 30 minutes to dry before the threaded part is reinstalled and once installed it can be removed and reused (3x). Once applied there is no time limit before it can be installed into the thread. I suggest just applying it to one side of the thread to see how that works and only use one application. Don’t ask me how I know this .
I would have posted sooner but just recently discovered it. It’s available in many sizes.
As I write I have the 1/4-20 adapter for the MK41 drying before reinstalling it into the light. It should work there. It definitely works in the more critical firearms I’ve used it on.
Do you have a link and name Brian?
interesting!
Hey, I think I figured out where all the weird China flashlight company names come from.
They must be using artificial intelligence — with results like these paint names:
Let’s just say this neural network won’t make you fear the robot uprising.
