Your right, you can’t use the indicator output with v1.2, but you don’t really need it. When you triple click, the main led will blink out your voltage. Plus you can use the power output pad to make the side switch light up when the tail switch is on (locator).
If you know how to flash it, then sure, you could upgrade to version 1.5 when it is ready. I don’t know how to do that.
The tactical rear switch is written in the code so it can’t be turned off. It would require a reflash to get rid of it. I have the tactical on my L6, but find its not as practical as I thought it would be. It’s so easy to click on and off with the side switch that I find myself not wanting the tactical option. This second driver I’m ordering will be programmed to do nothing when the rear switch is activated. I will know the rear switch is on because I plan to have the side switch light up on my new light as well.
2B seems like the best option to me.
Btw, in group mode what are the spacings of the different levels?
And is there a posibility to choose custom output levels for a certain group?
Edit:
Oh, and will there be a version with both LVP and Temp protection for 2S in the near future ? Is it a hardware or software limitation at the moment?
So if i get the 1.2 version driver now, and later Tom releases NarsilM, i could flash NarsilM and get the Temp protection too, is that correct?
Or some hardware modding would be required too, to get both LVP and Temp protesction with NarsilM?
To be more precise,
i was asking if i now get the 1.2 2S Narsil driver with LVP on PIN 7 and then Tom’s NarsilM comes out with LVP set on PIN7, i flash it on the driver.
Will i then have both at same time 2S LVP + Temp Protection ?
Or it still will be a choice between 2S LVP or Temp Protection?
What do you guys use to inspect them, a magnifying glass?
I’ve found that my phone camera set to 5x zoom and a small flashlight makes for a very handy video microscope kind of thing.
If I had to do a lot of drivers I would get a tiny turntable so I could rotate each driver while holding the camera and light fairly steady. It’s so much easier on my eyes. :+1:
I got mine at harbor freight many years ago, they have a different one now. It should still work but only has the extra magnifier over 1 eye instead of both like mine. They are sell them on amazon as well.
