Sanyo NCR20650A 3100mAh (Red)
Official specifications:
Rated capacity: 2900mAh at 20°C
Minimum capacity: 2950mAh at 25°C
Typical capacity: 3100mAh at 25°C
Nominal voltage: 3.6V
Standard charge current: 2065mA
Charge voltage: 4.20V
Weight (max.): 55.4g
Temperature: Charge: 10°C ~ 45°C, Discharge: –20°C ~ 60°C, Storage: –20°C ~ 50°C
This is one of the new formats for LiIon, this cell do not gain any extra capacity but can deliver a lot of current.
The discharge curves match perfectly and the capacity do not drop much at higher currents.
The cell gets hot at 30A, my log says 79°C
Conclusion
The cell is not a super cell, there ware limits to how much extra performance 2mm extra in diameter gets, but it is a very good high current cell (The next size up is 5mm longer and is better).
It is a very good cell, but do we really need this size (Check 21700)?
Notes and links
Compare to 18650 and other batteries
Compare to 26650 and other batteries
