Mitko's chemical may not leave silicone residues - not sure. For me, I don't consider it necessary or worth the risk to get every trace of silicone off. I'll try to be sure loose pieces are removed, but I won't risk removing stuck silicone around the wires.
Soā¦ I wonder if anyone in the us or? Would be willing to purchase these items and then distribute them so they could be attainable and affordable on a small scale. Iām guessing there would be a lot of problems that would keep this from happening? Donāt know about shipping chemicals let alone multiple chemicals in the same shipment and ā¦ Iām sure this is not possible or yes?
Why bother with the IPA, though? MEK evaporates with 0 residue; should be able to even just dribble some MEK over any loose bits instead of using IPA. Even 95% IPA has that nasty remainder of waterā¦
Had to look, youāre a Yooper, not overseas or anything, right?
Yesterday I stopped off at my local hole-in-the-wall hardware store to see if I can get some nice powerful solvent. Didnāt make my weekend trip where I couldāve stopped off at Lowes and pick up a gallon of MEK or xylene (the latter which can be used as an octane booster if yer so inclined), so didnāt want to wait another weekā¦
Anyway, I go looking for āsome nice powerful solvent thatād eat siliconeā¦ something like MEK, xylene, Stoddardās solvent, whatever you gotā. So, I get pointed to the little spray-bottles of āorganicā this and āgreenā that, some crap that doesnāt even list the chemicals and probably doesnāt work that well anyway. Finally, Iām eyeballing the rest of the aisle, and right opposite it are maybe pint cans of both MEK and xylene! Sold! (Well, yah, probably 5Ć the price-per-gallon as the actual gallon, butā¦)
Anyway, if I can get it pretty easily in a hw store that carries maybe a half-dozen of each item because of limited space, you should be able to get some fairly easily, too.
āBigā stores like Lowes and Home Despot should have it for sure.
Thanks for the reply. I forgot an important part of my post. :person_facepalming: so, ya, I can get MEK. actually thatās what Iāve been using with ok results but nothing like this thrower potion I am reading about
Yaā¦ da UP eh! How you know aāboot dem dare Yoopers?
Before anyone goes ordering anything, get the spellings right!! -phosphate vs -phosphite is a huge difference, and goggle doesnāt have a clue whatās ācoresilineā. And Iām assuming benzene?
Think'n for those type of chemicals, might be best to get the names right.
Really didn't think we could get MEK in NY - thought it would have been banned. NY and Cal are pretty tough on these things...
Long Island used to be known for potatoes, now it's breast cancer - good rule on LI: don't ever buy a home built on an old potato farm, and don't drink the local water. Sometimes there's good reasons for bans. So off to buy some MEK . It's at my local homedepot here.
Just thought i would add this in about dedoming the new style Cree LEDās. They will dedome completely with MEK, however be careful not to aggravate the phosphor. It becomes very soft and Iāve just ruined one by smudging it. If you slice about half the dome off before you soak it, it should only take 20-30 minutes until it swells, at the point it will pop off with the slightest nudge, unfortunately when I did one today I pushed the dome across the phosphor slightly and it ruined it. Iād recommend giving it about an hour to harden again before trying to scrape the excess of the surface.
Itāll warm up the tint a bit. If I know Iām going to dedome, Iāll start with a 1A tint or so and it usually comes out pretty neutral. But then again, Iām colorblind so I may not be the best judge
The Lowes near RFM (just off the Meadowbrook and OCR) has gallon cans of MEK, xylene, toluene, acetone, whatever your chemical-craving heart desires. Lots of contractors use that stuff as solvents and for cleaning, and for good reason, because they work.
The problem is irresponsible companies and illegal dumping, that made half of LI one big Superfund site. All that stuff leached into the top-level aquifers, to the point where theyāre polluted coming out of the ground. You gotta drill past those into the deeper aquifers to get any kind of potable water.
Iām in Queens, but haunt Nassau and Suffolk fairly regularly.
I used to work at a plating, anodizing, and testing/inspection factory in Farmingdale, which later became a super fund site . Those old leaking vats were nasty... Was fun in my young days, glowing green under the black lights at the disco bars (I worked with spraying Zyglo for testing for cracks in aircraft parts, struts, etc. - black lights used to find where it bleeds out from the cracks).
Thom2022 - I'll have to try the MEK then on the new LED's - thanks for the tips though! Does anyone have #'s for the fully dedomed XP-G3's compared to the XP-G2's? If I can get one dedomed, would love to try it in my BOSS1.
Interesting about how the phosphor softens up. That was my impression from saabluster's picture - phosphor looked softer than normal.
Nope. Thatās usually a bad thing, but I guess itās good for flashlights - if I happen to get a green tint Iāll probably never know (and therefore, care).
This is just an observation and I have de-domed a few emitterās. I like to do the hard ones, the XHP35-50-70ās. I run them up on the heat sink cycle them, getting them HOT, then chemically de-dome them, the phosphorus seems to harden up, I can usually (gently) back scrape with the edge of a razor blade,pick off silicone and eveb rub with a soaked in thinner/pure alcohol Q-tip (again gently) and not disturb the phosphorus. I also hit it pretty close with a couple blast of canned air. All ways being aware of the bond wires.
edit: I also cycle the emitter on the heat sink after de-doming, to burn off any residual chemical or even silicone on the big emitters, saves you from smoking up a reflector!
Wouldnāt they just cool off once they hit the dedoming solution? Or do you prewarm the solution as well?
Iāve thought of running the emitter while in the solution but then I wised up. I donāt really know if a live emitter could ignite an mek solution but it sure seems like a bad ideaā¦
I think with a new emitter, the phosphorus is wet/mushy āFRESHā if you will and once they are heated up the phosphorus gets hard. Only seen this on the big quad die emitters, normally the single die emitter except for a few XPLās I never had to remove left over silicone, a blast of canned air takes care of it.
If Iām not going to use any of the emitters I do de-dome immediately I store them in a (plastic) film can, with the fluid I use, till I need them. The phosphorus remains harden, the fluid does nothing to soften it back up. Again just an observation from my personal experience.
