All true but it’l cost you a lot more on cells in the long run. As they probably have the same amount of usable charge/discharge cycles but only 800 to 1100mAh vs 2600 to 3400mAh. Price for an 18650 is about the same (maybe even cheaper) then any smaller sized cell.
But yeah, I’m starting to like my Klarus Mi7 now with a 14500cell. I’ll see how long the 14500 ’s last me.
Sorry HKJ that I added my little undertaking to your thread.
I got two requests by PM as well, that makes more than half asked for. But let’s see if they will be shipped at all and are not snatched by customs (makes them more than a dollar more expensive).
Perhaps the last few requests via PM so that this thread is not polluted any further?
Although those 18350 cells with 1100+mAh offer 20-25% more capacity then others, they are still a long way from what we could expect considering 18650 current capacities.
For instance: Sony VTC6 3120mAh / 650 * 350 = 1680mAh.
That’s not quite right as there is some fixed overhead at both ends of the cells which does not contribute to capacity. I have not taken any cells apart but looking at the top, I’d say it’s at least 5mm of waste. So 300/600 would be a more realistic ratio.
Also, as this provides 15A (barely) in half the capacity, it should probably be compared to a 18650 which provides 30A. Perhaps a VCT5 would be a better basis.
So while there is likely still some room for improvement, it’s probably not that much.
Maybe I’m wrong here, but I would think there will be some volume in any cell that is lost to overhead mechanisms not used for energy storage, so that a 18350 will never achieve the theoretical maximum capacity with relation to its size compared to what’s possible in a 18650 (haven’t had my morning coffee so I hope I’m making sense).
By the same token, if there’s a 18950 format, then it would hold much more energy to make 18650 look unimpressive, due to the same volume of overhead across all cell formats.
The company that manufactures these batteries is YDL.
The same company also manufactures the Aspire 18650 batteries of 1800-2500mAh, as well as the 26650 of 4300mAh.
YDL is the company that deals most with Lipo batteries.
Many daily use devices have batteries of this company.
Most EGO devices used by vapers have batteries from this company.
Have shown good behavior, but of course there are those who did not see good performance ……
But most are happy with the performance of these batteries.
I managed to use the 2500mAh and unfortunately as a performance I did not see anything superior to the well-known 18650 of the big manufacturers.
At the 22A operating mode, the battery showed poor performance and increased temperature.
It was not a measurement to be able to have a clear performance picture, but compared to the Samsung SDIEM INR18650 25R5 2500mAh 20A, it was inferior.
The 18350, however, seems to be a good construction and is probably the most efficient battery of this size today.
But comparing an 18650 to an 18350, is totally invalid.
The 18350 is manufactured for smaller devices, so we will have less performance.
If it is worth buying or not, it is proportionate to each one’s needs.
I can get the cell with better price, but I can’t send to members directly, it is hard to send cells.
I can send all the cells to one,if someone can help
