Just to satisfy my curiosity I put the 70.2 P2-1A JAX X6 (18-20amps) using a L6 OP reflector against a L6 70 P2-1C (12-13amps) OP reflector and on the meter and visually (side by side) the 70.2 P2-1A “Out Performed” (stunningly) the old XHP70 P2-1C, as apples to apples as I can get!
Hmm, hard to say what the source of discrepancy is. One thing is that Kawiboy and Tom measured the current with a clamp meter. Depending on the resistance of the tailswitch, the current when the light is in normal operation could easily be 1.5-2A less than with the clamp meter. So if they did the lumen and lux measurements with tailcap in place that could bring the measurements a little closer.
I’m not too concerned about lumen differences, ordinary calibration differences could explain that already, what is the real worry is that Tom and Kawi found a very significant increase in output between 15 and 20 amps, and I see a clear drop.
Across 4 measurements by KB, post #108 here, it certainly does show consistent rise in output from 15A to 20A. I should get some more data points in this range as well. I only tested at 11A and 18A here at post #94.
I will just give up for the moment, a proper re-test would require a new $16 dollar led that takes weeks to arrive, soldering a fresh ledboard onto a 30mm copper disc and mount that on my test-rig.
In the meantime I guess that over many people combined enough knowledge is gathered on this led that a test has little to add anymore.
KB mentioned his lux measurements were with bypassed tailcap, so the amp values associated with those lux measurements could be 1-4A lower, depending on the tailswitch resistance (ranging from 0.01-0.035mOhms). So the lux measurements could possibly be over 12-16A, not 15-20A. This could potentially explain a big part of the discrepancy with djozz’s measurements.
I get higher lumens measurements with the tailcap on consistently over the bypass wire, 3 times out of 3 with 3 different sets of cells. Not by much but between 100 and 200 lumens. I use a 14 AWG bypass wire, 8" long between the batt- and the end edge of the tube.
Good switches are pretty efficient and you have a stronger ground contact in the assembled, threaded tailcap, plus a 20 AWG bypass for the spring.
Interesting, thanks for the measurements. But they could be interpreted in different ways. It could be that you are actually getting higher current with the tailcap. Or it could be that you are getting less current with the tailcap, and the output is higher because you are in the downward slope portion of the output curve.
I just did a quick measurement of contact resistance of a 12 gauge wire pressed on the edge of a 1.5mm thick copper disk, and with just a bit of pressure it was below 1mOhm. So unless your 14 AWG wire end is unclean the contact resistance is very low. The 8” 14 AWG wire has about 1.7mOhm by itself.
I have measured bypassed-spring tailcap and switch assemblies and they have ranged from 10mOhms to 35 mOhms.
I have solder blobs at each end of the 14 AWG wire. Dunno, could be some degradation, I've had it happen before on jumper wires - resolder, and get higher readings. This one has been used a lot.
I hear the theory but in practice, I've seen over dozens and dozens, maybe 100's of measurements where the tailcap assembly does better, pretty much every time. Granted many don't have a switch (e-switch lights with no tail switch). So maybe my wire ends are beat up. I got plenty of wire around, so maybe I'll make up a clean new 12 AWG jumper and compare.
I'm surprised the surface contact area makes no difference in the formula? With the tailcap you get the full circumference of the tube making contact even with an anodized threaded tail, while the wire has a tiny fraction of that for contact.
Update: I just cut a 10 AWG stranded coated wire (all I use is stranded), 6", soldered the ends, cleaned up the ends with isop. alcohol - same result: jumper wire has lower lumens readings every time compared to the L6 switch assembly - repeatable, went back and forth a few times. Not much of a difference but I'd say about 60 lumens.
The way I measured the tail cap resistance was by passing a known current from the (bypassed) spring to the point where it would make contact with the battery tube. Then I measured the voltage at these two points to find the resistance. So any contact resistance between the tail cap and battery tube would be in addition to that resistance, but I think the contact resistance would be very small.
With your updated measurements I would say there is almost certainly more current flowing when you bypass with the AWG10 wire. There is just no way there is more resistance (contact resistance included) than in the tailcap. If that is true then that means you are at or near the maximum in the output curve.
Could you try the same measurements (with tailswitch and with AWG10 bypass) with a single XPL light? In this case we would be on the upward side of the output curve, and you should see more output with the bypass. (If my understanding is correct)
Ok, tested the 10 AWG wire across 3 different FET based lights, and again with the L6 at lower amps, about 12A. On the L6 the wire makes little difference. Have you seen an L6 switch? It's huge! Believe it's on of those 6A rated switches.
On the other lights:
U21 w/dedomed XPL, no tail switch: wire does slightly better (~7 lumens out of 1,600)
Warsun X60 w/XPL2, tail switch: wire does much better (~190 lumens out of ~2,000)
Lumintop SD26 w/XPL2, no tail switch: wire does slightly better (~30 lumens out of ~2,100)
L6 using EVVA cells, about 12A @tail: it's about a draw over 3 trial tests, all within 1% one way or the other (~7,300 lumens)
So for a bad switch, like the X60, can be a big difference. The L6 has one of the best switches we have available to us though.
All the more reason to get rid of the tail switch . If I get around to upgrading the X60, I'll look at eliminating the tail switch - don't need it with NarsilM.
I modded a couple X60's for BLFers, but not sure what I did - probably swapped out the switch - that's what I usually do when I see a significant drop from it. My own stuff though always gets lowest priority - I never seem to get back to my own to improve it.
I don’t think a tail switch would matter though, current is the same everywhere in a circuit, if he measures 20A at the switch then he would measure 20A at the LED too.
It is the voltage that changes between components in series.
