I’d say it’s between the two of those closer to your 4500k. Your 4500k looks warmer to me and closer to 4000k. It doesn’t look quite as warm as your 4500k example. The S41 with 219b looks like sunlight to me and the 219c warmer. I have an Eagletac MX30L4 with 12x 219b and I believe I figured that out to be 4700k using my camera and an 18% gray card. The E14ii with 219c is warmer than my Eagletac and S41 with 219b is much cooler probably closer to 5500k if I was guess. I’m a photographer and often shoot at night and use flashlights to aid in focusing. I try and match the color temperature of the flash or diffusion material I’m using in case the flashlight ends up effecting the photo. I guess to post photos on here I need to use an image host? I haven’t used an image host in awhile and would probably have to make a new account. Any suggestions on what host to use? I could take some beam shots. Would white wall or outdoors be preferred? I could use a gray card and get accurate color temp readings. I believe that would give me accurate readings someone could correct me if I’m wrong.
Thank you for response. We would love to see photos. You can use “http://pi.gy”. This host does not need account and it does not compress images or alters colors.
Given your specifications, you have a chance to become a very valuable person for this community Just use that site to upload and do not hesitate opening new threads.
I have 4000K 219Cs in other lights. They definitely don’t have the rosy tint of 219Bs. I’d describe them as “bright tan”, if that makes any sense, or as similar to sunlight at the start of the golden hour
If you want really detailed information about tint, look for reviews by maukka. He has a pretty nice tint measurement setup, showing exactly where each light falls in the ANSI color spectrum and what CRI to expect.
Ok took some shots to compare tints. All pics with Sony A7rii, daylight white balance, aperture priority, F2, ISO-100, and center weighted metering. I noted shutter speeds to give an idea of output, however due to the different beam patterns and the center weighted metering its more comparison of lux than lumens. Matrix metering would have given a better comparison of lumens but might effect tint.
Control shot external flash (1/200, F22, ISO-100. Flash at 1/128)
4Sevens QT2L-X, CREE XML, Cool White, 1/250
Nitecore HC30, CREE XML, Neutral White, 1/320
Astrolux S41, Nichia 219b, 1/250
Manker E41 II, Nichia 219c, 1/500
Eagletac MX30L4, Nichia 219b, 1/800
I thought I’d do something a little more colorful to show the color reproduction. This is a painting by Inga Rausch and done as fan art of my cat (I have a famous internet cat). She was nice enough to send it to me from Germany all the way to Pennsylvania.
Control shot external flash (1/200, F22, ISO-50. Flash at 1/128)
4Sevens QT2L-X, CREE XML, Cool White, 1/125
Nitecore HC30, CREE XML, Neutral White, 1/125
Astrolux S41, Nichia 219b, 1/200
Manker E41 II, Nichia 219c, 1/200 (looks like my camera over exposed this by a stop. 1/400 would be a better comparison in output)
Eagletac MX30L4, Nichia 219b, 1/640
To me the Astrolux S41 is just a beautiful tint and color reproduction, its like sunlight in your pocket. But I like the higher output and UI of the Manker E14 II better. I haven’t spent enough time with either light to chose what one will be my EDC or my walk around the woods light. For photography the S41 wins for sure, I was watching a turtle lay eggs today and had the E14 II with me. I used the it to shine under its body to get a better shot of the eggs but the mismatch in tint between the 219c and sunlight just ruined the photo. Any ideas on what would happen if I swapped emitters between S41 and E14 II?
Thanks we’ll see I’ve been into flashlights, lasers, and other things light related since the days when it was cool to have a Surefire hotwire light. I often ended up building my own stuff. I can remember I was part of the group buy to get the first batch of Nichia HCRI emitters when they where released. Nowadays I get an itch about once a year to get back into it and caught up on the new technology and buy a light or three… or build one.
The output on turbo is amazing. The tint is a nice pure white without noticeable green.
On turbo on a fresh 18650 cell the head becomes too hot to touch in seconds. This is the disadvantage of having a big chunk of direct copper in this kind of light. Heat transfer is just a little too good. The LED can withstand much greater temperature than your hand. Sometimes it’s better to have less effective heat transfer that lets the LED get hot, but then takes longer to radiate it off the light resulting in a cooler exterior body housing.;
It looks like there is no further stepdown from High @ ~850 lumens. Are there heat issues with sustaining that brightness with this light? Comfort-wise or otherwise?
Just tried letting it tailstand at 850 lumens high for several minutes with a fresh 30Q inside.
Even at just 850 lumens the head of the light was too hot to comfortably touch, though not burning hot. You wouldn’t want to rest your hand there, but you won’t hurt your thumb operating the control. If you were using it to go for a walk at night at that setting you’d either need to use a glove or hold the light by the body tube.
For comparison, I also tried tailstanding my modded Jaxman E2L 3xXPL HI 5A2 with H17F driver with temp sensor and an 18500 IMR cell. After running about the same period of time on 100% FET power with the temp sensor activated, the E2L was producing substantially more lumens than the E14II, while remaining much cooler than the E14II. This result is not too surprising given the E2L’s aluminum construction, dark-colored anodizing (better emissivity than polished copper), and much larger surface area from the more numerous and deeper heatsink fins.
Definitely not by the head. It gets burning hot in much less than 40 seconds. Can probably still hold it by the body though.
Incidentally, the threads on the head match those of the Convoy S2. A convoy S2 battery tube will screw right into the E14II’s head. It isn’t long enough so won’t make battery contact and won’t work out of the box, but it does actually screw in.
This does open up the way for modders who want to use the E14II as a mod host. You could add a tailcap mechanical clicky. Or maybe use the E2L’s 18500 body.
My turbo goes for a minute and while I can press the button to turn it off I can’t really have my other finger on the opposite side of the button touching the copper. So 4 fingers on the tube and one presses the button. It really is to hot to hold the head in a few seconds. I bet the head gets too hot to hold faster than my soldering iron.
