Q8, PMS SEND TO THOSE WITH ISSUES BLF soda can light
heheh TK, no I dont think those silk additions are possible, would be funny though :wink:
EDIT: List updated
Of course, silly. Boobs always win.
I rest my case……. :+1: … :wink:
< Am I seeing things or is TK wearing glasses?
Button tops are typically spot welded (I believe), and the metal - not sure how good the conductivity, so totally up to the mysterious 3rd party that installs the button tops. Solder, though supposed not great conductivity, is solid to the battery top. I would think/guess solder boobs will always do better, and my testing seems to prove that out compared to the button tops I have, and tested.
For durability, reliability, button tops win out every time - solder is soft, subject to going flat over time (not drooping), plus the metal could be rubbing off on the brass contact ring over time - bad if it fragments, but not sure bout that. I think I've seen this occurring though - probably best if the brass ring is polished smooth.
To fix this, could solder brass buttons to the top of the batteries. I've done this several times as well. I haven't had one fail yet, but never used them in an SRK style light (contact ring). I'd be concerned about the quality of the solder bond, if the brass button is at risk of falling off over time. Probably dependent on how well the solder job is done - clean surfaced, good amt of flux, etc. If you do use brass buttons, I'd say the contact surface should be sanded down on the edges so there's smooth contact - most of these buttons come with sharp edges. Brass will hold up better than solder for sure, but brass is relatively soft compared to steel for example, but it would be brass to brass contact so maybe that's good.
I dunno if all these concerns are warranted - I got limited long term experience with these usages.
I refer you to kramer5150’s avatar from July 2015:
So… you’re saying the softness of boobs might make them lose their zing after menOhmpause?
Let’s not even start on the puns related to electrical conductivity being measured in siemens.
In practical terms though, solder blobs are relatively easy to rejuvenate when necessary. Just re-melt it, maybe add a little solder, or file down the tip a bit (ouch), and it should be good as new. I’ve had to do this occasionally on blobbed drivers when the contact surface gets dirty. It may also be a good idea to clean the contact ring on a SRK-style light once in a while.
This kind of thing isn’t limited to just solder though. I also have to clean the battery (steel? zinc? nickel?) and contact post (aluminum) on L3 L10 lights periodically, since it gets thoroughly blackened during use.
I’m glad the Q8 has a thick contact ring, since it’s going to get worn over time regardless of what the battery tops are made of. With a thin ring like a regular PCB copper pour, wear is visible after just one use… but this thick brass ring will likely last pretty much forever.
I would not know, i rarely get to know one from the other sex good enough for me to ask for permission to examine her features that close.
And i am not the kind that jump at every little chance he get, that actually make me suspicious and work like a bucket of ice-water on me.
On a more serious note, would it be possible to make a contact ring with raised areas in the right places so flat tops would work in it too ?
Or am i overthinking again.
I think, flats tops will work with it now as is… sparkyDK. :slight_smile:
EDIT: If they are of proper length. :+1:
FINAL EDIT: … Sanyo GA flat tops will work because they are raised flattops.
Q 30 flat tops or any cell with flat tops like them… WILL NOT work.
My apologies for the initial incorrect informatio I gave. :person_facepalming:
I’ve been watching this on and off since the beginning and it looks like it’s finally coming together into a really impressive light, well done and thanks to everyone involved in the design. Please put me down for one.
Do we have any rough timeframe on shipping the final version yet? Once approved are they ready to start manufacturing?
Sheriously, typical flat tops won't work, and not much you could do to the ring, because as you tighten the battery tube, the cell tops are looping round on the ring, and where they stop, nobody knows.
SANYO GA's are flat top, but unusual because the tops protrude higher than the wrapping - so they work, as long as the springs can handle the shorter length.
Or, if you simply use protected cells with the button already attached. As I recollect, somewhere above, it was determined that protected GAs with a good protection circuit did not seem to impact the light output vs an unprotected QA. Unless you are trying to squeeze every last lumen out of the light. But if this a concern, there are other batteries with higher amp capabilities you can blob and people can mod the light to try to make the whole power train act like a room temperature superconductor.
yeah i figured it would take some figuring out where the drum stop to make sure the batteries land on a “hill” on the contact ring.
But with design ( not the Q8 ) then i am sure they could figure it out and so the resulting flashlight could use any battery.
I am fully aware this are a done deal for the Q8 and that’s just fine i will just do something to the flat tops i have gotten for it.
But in future flashlights ( not least multi cell like the Q8 ) it would be nice if they would work with any type of the particular cells its build for.
But i have been wondering even if the “hills” was smooth for the battery’s to climb easy, the design of flattops and their wrapping might suffer damage over time as the batteries would have to go up and over those “hills” several times before they land in the final resting place.
Also i have been thinking if you should lathe those hills in the contact ring, or you could make do with just punching dents into the ring.
Now i am thinking ( i know i should be sleeping now but my brain will just not allow for that it seem )
How about if the 4 batteries in a light like the Q8 was staggered in a drum around a central pillar onto which you then screw on the end cap ?
This way the batteries should be stationary when the flashlight are put together, a bonus might be you can use bigger O-rings where the battery “drum” seal onto the LED end and the tail cap end, making for a bigger chance of a waterproof light and using larger more forgiving O-rings.
Off course this design will mean that the battery drum will just be held on the LED end with the friction of the O-ring when the end cap are unscrewed for battery change.
Holy sh, ee now i better stop cuz now i have tail cap contact ideas too, i better go for a drive and get me some sugar water to get the creative juices going again.
sparkyDK, this is an already-solved issue which came up just a few pages ago. It simply requires a different design:
The Q8 will not use this method though; it uses a SRK style ring instead. So… make sure the positive terminal is higher than the cell wrapper.
The Q8 list (from post #1) sorted alphabetically .
(As of post #8341)
2 DOGS 186
264 641
2Ace 165 1119
5ar 697
7pot 982
a12luke 932
a_idiot 740
Aardvark Spleen 253 402 403
Abe87 876
Abqjohnny 51 1169
abril 50
adirondackdestroyer 545
adrianlights 255
AEDe 923
Ag76 1345
aggillator 458
aginthelaw 278
Agiri 110
aim120 430
AirBreaker 155
akhyar 387
akoposilester 56 1111 1112
akovia 937
albertopnp 365
Alcius 105
alejandrov 523
alex64 1159
AlexGT 495
Alkpwn77 204
allthumbs 218
alphazeta 335
alternety 564 565
Alux 702
amplificus 904 983 984
Andmiller 1064 1065
andrewmac 407
Andybibbville 147
Andyman? 13
Angel Martínez 128
ant0 1195
Antenne 801
Anthon 568
antiparanoico 32
AppA 1208
aprendiz 1160 1261
apt323 47 544
archi 1157
archimedes 67
aremihc 910
ARMS.AARON 1089
ARsee 1228 1229
Arufonsi 921
aslpg 398
asnidi2 1327
asot 690
Astromanic 424
AsylumSweep 863
atbglenn 567
Atom00 358 359
Autoclave 1099
Awdtsi 1221
Awkward Stretch 619
AwkwardPause 464
b1i1l1l1y1 1052
B42 685 686 1019 1020
BackpackNY 571 1084
bakalakos 202
balazs1956 1341
baldo21 260 261
Bam35 1039
bamawthu 599
banker 1013
basslovin808 446
Bastarrdo 117
Batch1 293 344
battletross 809
bawilson2 500 501
Bc412 5
bd52 399
BDM 1018
BDWrabbit 1244
BeardedRaleigh 662
bella-headlight 49 411 877
Bernard 232
Bevo 1086
bhuge00 1049
bigpix 84
bigrick 754
bikedave99 1174
bikenber73 14
Bill 63 752 1296
Bill_tong 896
Billcheese5 949
bionictony 1338
bkling 1067
BlackList 1350
bladesmith3 607
BLFD80 933
BlindingL5s 312
blinker 1306 1353
blinky 1209
blueb8llz 70 553 1120 1121 1122 1123
Bluzie 785
bmaddison 248
Boaz 391
BobbyMK 462
bobdotorg 1271 1272
bobofire 1313
Bogdan 370 371
bogdanr 466
Bohemian 775
bonfire 412
Bong lick 763 1075
Bonham 262
borealis 1098
BorisBar 575 1238
Boro 360 361
bossf350 803
Box 671
Brettg4215 864
Brian Metcalfe 318 319 374
BrianK 447 560 1356
BrianTheJay 950
brightlights 243
brjones 504
brno602 913
brted 249
Bruno28 513
BT100 1087 1138
Bungle88 610
Buzzy243 1179
bwl123 870
cabfrank 443 988
Caleb 203 547
Caleb-v 444
Calmaja 35
Cano 661 1151
Captainvideo 1302
caramba 748
carmantl 345 346
casi29061965 467 490
cavorite 1028
Cawi 1276
cbrake10 749
cclight 897
cdjaney 825
Chadvone 63 693
Charga 124
charles lin 1124
CheapThrills 469
cheesecheeks 816
ChibiM 1310 1321
Chicken Drumstick 131
chinooker 1260
chooma 210 351
chrisc 741 742
churchilllafemme 1230
CircaM 894
Cjlee89 951
cjoe7 146
CJW 367
clagged 991
clange50 479 480
clinicdoc 1226
Cliwilnew 795
cloggy 404
cmflippen 83
cnrffl1 577 1113
cocoschnauzer 363
contigo 1351
Coolerness 664
coolriku 517
Corzy 308
Couchmaster 245 551 552
cpd800t 406
CrashOne 372 377
Crazyeddie 98 137 487
Creepo 909
cristhemuso 388
crx88ia 683
cujo255 1191
cwb 134
cypher1024 973
cypherz 250
Cythras 956
D10ten 608
Dadpool 1161
dafarui 1339
daninho 468
DarkerInSol 615 616 617 618
darkpenguin 718 719 735 736 737 738 739 860 861 862
darol 798
darrenm 1054 1055
darrylo 507
DarthTader 830
datiLED 761
dave101 1041
DavidEF? 7
davidkappelt 1026
davidvns 1128
davos 1062
DB Custom 713 722 997
dbesselt 1156
DBSAR 136 169 1281
DBSS 516 779
deathless 518
Deep skull 977
DeJaVu 669
dekozn 800
Dennis 934
dentillozie 488
Dep668 687 688
derfyled 1237
derpilgerer 630
Desmo 805
devdvr 486
dezoe 1186
dhsvcs 265 1336 1337
dicksog 559
digitaltc 1323
Dimking 425
Dirt 815
Dirty_Pierre 1045
DiscoJoe 1254
djburkes 188 878
Djozz 3 1115 1286
dmbaty 1294
Dobtruckers 1058
DOCFAR 595
Docp723 347 433 434
Doctawho 440
dodo 88 274
dogany 813
Dogsrule 508
donpachi 1252
dotBLF 968
doubleone44 887
downlinx 74 316
doxerino 1304
Dr Forinor 873
Dradge 1248
Dralf 1015
Dregs 172
DrHook59 883
driveX 659
DrJones 75
DT101 152
dudunphy 389
Duke 381
dumptruck 971
Dusty 327 328
Dutcheee 68 322
duvallite 889
dw911 478
Dwantink 135
e10sno 405 1318 1319
Easyrr 6
eb1888 837 838 839
ebosh 777
ediaz 906
eebowler 774
Eggun 1104 1312
egrep 594
Eivwer 171
electricjelly 237 256
ElginAgain 1204
emarkd 109
embee 511
Enelooper 417
engber 947
ERDOS 1150
Erethryn 1259
erikk365 648
Esskay 995
Etex 829
euphxenos 408
everydaysurvivalgear 103
Evilc 65
EyeballFryer 189
Fadetoblack 1295
fantomR 636
Far Thrower 148 197
Farmboy24 1234
Farns 277
Fatlight 663
fatsteve0 1361
FBsLights 790
fcrespi 1262
fed893 307
fedcas 902
feralcomprehension 1194 1311
finges 561
fireblade893 209
firedome 324 711
Firelight2 397
fishlite5 1046
fixed it 78 1097
fixvid 1264
Flash Voyager 652
flashination 87
FlashMax 1225
Flashy Mike 239 410 448 449
Flifish48 806 1096
Flintrock 629
fluffman86 958
FmC 1182
fonfan 234 1023 1024
fonLED 725
Ford Prefect 1068
Foston Pete 453 454 644
foton 1030
Fozzy-SP 317
Frank A. 1172
Frankie Baby 342
Franz 788
Freddy61069 282
Fredylee 223 1329
FreeMagenta 1050
freeme 514
Fritz t. Cat 484
Funzel67 990
fuzun 1074
fyesilova 535
g60 290
g_sintornillos 126
gamezawy 38 336
gangstead 53 922
garrybunk 254
gboss 832
gds95 1199
gedasd 1309
geepaw 1038
gehrmo 289
geo1952 455 457
ger-slash 416
Gerrh 531 1163 1164 1285
Gerrit 106
getbully 609 1263
Gilatabar 638
giorgoskok 306 493 1092
GIR 804 818
gisewhcs 384
Gj 580 581
gleamer 432
GlinnDamar 1342
gnatx 588 824
goatfarmer 770
GoldenBatt 383 589 590
gorb507 811 812
goshdogit 11 12 40 120 121 543 556 928
gpapa693 79
gravelmonkey 1027
green_comet 601
GreenShrike 190
gregor 215
GTsuperheros 179
Gtt980 936
guerrilla154 1316
Guggga 538
GulfCoast 880
gungoat 44
Gunnerboy 252 967
Guns712 1300 1301
h2o 181 476
Hairy_Steve 340
hank 258
Hardware 1071 1200
Hauwexis 845 846 847 848
haxquiz 226 927
headburger 592
heatwaves 994 1265
hein11ag 183
Herb Tarlek 931
Hestbech 994 995
hexcode 503 672
Hezekiah 286 759
hideehoo 859
HighCaliber 177 178
hmihaylov 502
Hobo 220
hunter1 116 720 721
hurleyy 993
I_like_lamb 915
Ian2381 150
igeigeige 890
IH8MYX 546
ii_pennies 481
ikaruz_500 989
Illumenated 426
illusioned 954
Ilmatic 1253 1332
ilovejesuschrist 294 295
ImA4Wheelr 19
ISO 705 734 929 930
iwandutchy 1047
J-Dub74 461
J_R_J 675
jack-bkk 356
jacktheclipper 1108
Jailbrake 1034 1090
JakeDjanitor 46
Jalben 187
jama 635
Jambo 912
james y 1043 1044
javipiloto 1154
jaynick 1048
JayT 62
Jayzed 1214
jb1 224
jdunlap27284 164
jealous57 81
Jensa41 731 732
Jerommel 637
jerrod 512
jescereal 228
Jesjes 153 154
jfalk1 918
jhalb 297
jhullin 159 751
jingleberry 1022
Jinx 93
jkbam 550
jmoots 268
jmpaul320 95 299
jmwhite151 482 851 852 853
Joat 184
JockRobbins 717
Joe Darkness 620
joe1512 534
joeangi 756
joechina 633
Joey Adams 1021 1132
John-Galt 463
Johnhywash1 966
johnnydoe 1227
JohnnyMac 496
johnpc 955
johny723 1082
Jonandreadolan 1072
JonnyC 576
JordanZHP 1078 1196
josephqool 1061
jpcuba 684
JPLight 23 646
JPM3 263 264
JS721 216
jsmn4vu 793
Jtm94 1035
Juanesdan 118
juaquin 219
Juggeli 745
jurasik1 1231
justanotherguy 541 712 1080
Jvrthp321 691
jycheang 1009
k-wong 542 1005
Kafar 9
kahvitahra 796
Kalchev 400
kali stupa 1217
Kalihi 836
KawiBoy1428 230
kaybi 1033
Kazik 1315
kbro 168
keengeorge 309 310
KeepingItLight 992
Keepitsharp 175
Keisari 1211 1212
keithd 753
KenE 355
Kenjii 385
Kentuckywindage 797 872
Kepling 333
KFulton 1331
khas 628
Khuan 1148
KIKY 1340
Killforfood 272 379
Kindle 698
KingSmono 578
kiriba-ru 525
Kiukas 640
KiwiKane 174
Kkelleher 99 100 101 102
Kloepper Knife Works 194 195 196
knightstalker 1219
kntx 1073 1116 1189
knudsengj 1106
Koaksijalac 104
Kodachrome40 170 1282
KoekieMonster 161
kommessy 108
korpzgrinda 1029 1133
kotobuki 799 1143 1144
koyotee 276
Kozy 58 129
krutone 1298
Kulumatic 914
Kurt_Norway 593
Kusie 8 17
KutKhemist 123
Kysumi 925
LAB 259
lachesis 673
lalomt 1167
Lamont56 808
lamper 727 1171
lanceb1b 884
laststance 972
lawallac 393 394
Lazy-R-us 25 900 1249 1250
Le_Zouave 71
leaftye 694 1103 1183 1184
LEDtec 823
legan710 1088
Legolas Jr. 130
leroycp 236 266 450 451
Lexel 696 1287
Lfatman 707
Liber8 537
lichtpfadfinder 1292
Light of Earendil 700
lightbulb 281
lightknot 471 492 598
lightlight22 772 920 1040 1328
lightmog 72
lightx 757
Lilien 978
Lion42 246
lionheart_2281 33
litcrit 871
Litefighter 1320 1334 1335
LloydV 767
Loneman 510 903
longmire 1256
Lopan 1069
lovetheguitar 981
Lowtech 1042 1193
ludolf 348
luisgcan 1162
Lumenmaster17 1145 1146 1147
Lumens Industry 634
lumiere 231
Lund1660 64 439
luxlad 831
lyse99 1012
Lyubo Yanev 427 428 429 536
M4D M4X 350
M78 157 337 1007
MACS0647 313
MAD TM26 656 657
Magbrite 584
magnet 302
MagPap 794
Maiden666 92
maildroid 331
Majoroverkill 919
malamask 113
mandala 952 953
manithree 1255
Manulous 1270
ManWithoutShadow 1100 1299
Mapache 4
markalike 602
Marothar 1236
marsalla 475
Martini 82 726
martook 48
martytown 976
Masejoer 842
Matchoo 905
matkovicha 1185
Matomoto 1324
mattlward 16 34 214
MauiSon 42 979
maukka 225 627
Maxxsounds 681
MBuitendorp 1210
mcfarlie6996 964 965
MCT 162
Mecallie 1051
MechEngVictor 275
Medvegy 660
Melven 167
meti 470
metz3006 843
Meyer 138
MG 353
mhanlen 77
mi bill 127
Micael 858
Miguel_79 1114 1129
Miguelintegral 1175
mikeyx 622
Mindaugass 769 1081
Minimoke 30 975
miswas 760
Mitko 26 27
mitrhandir 1303
mizjif 714
Mkduffer 600
mlodyulek 1283
moemin 375
MontyPyfon 66
moridin 907
Morpheus 613
MorpheusT1 762
MortyDuck 764
MountainKing 438 445
MountainMan 786 787
mozart.f 314
Mr.Poppy 192 267 1247 1308
Mr.Scott 251 1077
mrheosuper 1110
mrkelvin 606
MRsDNF 325 326
mrstealyourgains 1014
msg1285 173
Mstevens113 114
Mt.B 392
MtnDon 158 498
mud_muncher 624
mudguts 680 716
Muto 20 242 689
mutts13 1343 1348
muzzleblast? 89
mxlu 396
MyDangus 1181
myowin 213 1235
myst999 198 728 1266 1267
nanojack 1036
narin000 524
Nathan42 946 987 1365
Navin_R_Johnson 817
neckbear 935
needmorlts 911
Neilyboy 1307
netprince 176 378
nexrace1 579
nfetterly 362 366
Nguyen 1277 1293
nickdude 591
Nickke 604
Nicolaas 857
Nicolicous 270
Night Light 1093
NightLight 369
Nightshade 574
niktak11 782
Nil 959 960
Nite Shadow 1001
Nitetime 163
nitrader0 1203
nnmnu1 1349
No Agenda 431
nofear87 382
Noki 573
noob 828 833 1025
Nord 1170
Nortson 810
novice1 338
nqcken 119 241
nskn71 1136
NuggetMcNugget 166 332
ObiWan-Kenobi 422 423
octav 666
OdorlessCurves 529 530
ohnonothimagain 1357
olivedrab 658
OrangePeel 1275 1288
orinjuse 835
Orionz23 1168
osb40000 193
OscarM 1290
Oswald3211 724
oto 888
Ozythemandias 625
Pablogy 441
PabloVerde 1037
pacbough 149
papaslightsaber 583 1125 1126
patchythepirate 704 1364
patmet 1347
patmurris 55
patmurris 1355
Paul321 139
pawwright 151
PBWilson 557 558
peabody 207
Peetz 311
Pegaso 122
Peho 112
pepe2017 1305
pepinfaxera 1158
perche 1155
peterlcole 924
peteybaby 549
petr9999 1137
Petroleum Lantern Guy 891
Phoenix_FIN 395
Pidro 465
pieman7 670
pirate joe 22 678 679 783 784
piyoman 840
plntigrado 1153
pommie 54
pook 330
pooptoast 519
powerfultorches 569
praveendk 437
presterjohn 586 715
Presumptuous 653 654 655
Primal 364
prisma 401
Prometheus 1149
ProtaBLF 419
pscal 376
puccio1969 76
Pukachi 205
pukoid 868
Pulsar13 288
qandeel 631 632
R.D. 974
radb 856
rag 283 298
Ragsy 499 1117
raiko 570
rajun50 651
Randolph 212
RapidLux 1346 1360
Rat_Racer 999
RaVeN 160
raynman 706
rdoc613 879
red72vw 521
redrider706 1359
regaia 1008
reliant_turbo 710 850
ReManG 320
reno 1118
retiro675 352 826
rexdog 442 515
rfd673 747
ricardon 300
Ricflair 323
Rick 199
rjorge 708
rmkline 436
Rob_K 244
robbobus 233
Roberrt777 185
RobertB 140
RocketTomato 766
RockHugger 1173
Romey310 969 970
RonMuller 111
Roter 649
RotorHead64 1284
Rpdos 1180
Rska 650
Rsqweezy 814
rufrydr 765
Rufusbduck 60
Rxich 866
ryukin2000 1220
sac02 645 908 1215 1216
saf99 755
Saigon 247
SamHaLeKe 485
samis 509
samnavy 73
san san 926 1130 1131
sandanbob 532
Sarge930 86
Savydude 1222
SawMaster 45
saypat 141
sb56637 191
scarnific 566
scdaf 271 296
Schkü 614
schlockproof 612
Sciencetists 257
SciFiFreak 31
Scooby 582
Scooter000 315
scootypuffjr 844
Scorpia 596
scotlarock 329 1085
Scottland 334
Scotty 746
scs 80
sebastiang 611
SebaZ74 1239 1240
SeenTheLight 301 819
SFB 1109
Sgtpev 206
Shadowcactus 916
Shadowfax 341
Sharpie 354
shimano3000 409
shimey 211
shirnask 61 733
Shoe 957
shogan 227
Shur 284
SIGShooter 368
Silent_Star 1190
Silentcropduster 667
Simplelight 961 962
slackwolf 885 886
slackwolf 3rd 1000
Sledge 980 985 986 1326
Sledgestone 677 841
slickpenguin 643 854
slimkango 52 1207
slow2go 221 222 692 1139 1140 1141 1278 1279 1280
smed1275 494
Smittymojo 768 1142
SmokinH 855
Snoballz 1031
SoCalTiger 1344
sochi111 1032
Sofa 834
sol 291 292
SolarLumen 776
solRNY 1291
somnambulism 562
Sonpham 621
southland 142 143 144 145
sp5it 94 1201
spade413 1178
sparkyDK 1188
specialk 865
Speed4goal 413
Speedsix 1083
spkzzz 474 526
Sprinkles 279 778 901
srs2000 1187
stanley-beamish 107
starcrazed 1330
stareye 540
staticx57 238
steel_1024 709
Steenbhg 701 1205 1206 1268
steepdrop 435 497
Stephen Elliott 1322
stephenk 269
steve42 1016
Stevejj 1218
SteveMidwest 1289
stevez32 822
Stittville Ed 85 998
Stoneface 758 1127
strango 96
strayz 505
Streamer 1246
strmix 676
Subterrestrial 1003
Sukoi 642 1010
Sullysat 418
Suncoaster 682
Swennie 895
Syncmasterklop 867
syracuse 349
T-boon 304
T18 390 1257
t3rminal 1213
tapir 489
tarver 132 229
Tarvos 15
tas69 380
tatasal 506
teacher 321 1134
tebeve 893
techieman33 456
Tecmo 57
tekwyzrd 37
tenohfive 802
Tete 217
Texas_Ace 472 473
The Burgh 235
The Grand Pooh-Bah 1056 1057
The Imp 1242
The Jinx 522 699
The Last Katun 90
The Miller 1 2
The_Driver 1352
thebaum 585 807
thecrc 1177
TheDude 415
TheHebrewHammer 820 821
TheJo 1053
TheMadcap 97
themaindude 343 1094 1095
Theodore41 520
theoldbill 59
TheOnlyDocc 1135
thijsco19 24
tigris99 603
timcodes 1004 1017
tindrum42 1059 1060
tinowrx 572
Tixx 371
Tjhosan 273
Tjohn 940 941 942 943 944
Tmik 287
tmxod 771
Toccata 1241
tocirahl 1362
Tom E 28 29 874 875 1223 1224
Tom_182 695 780
tomtaylor 201
tonylim 43
torchjunkie 483 597
toxiccoccyx 1107
ToyKeeper 339
tracerfire 1317
Trashman531 285
Trasnodel 729
trevglas 200
trevize 1165
treysoucie 789
tristanxoxo 240 1070
troisanh 91
tronx 674
TRoPHeuS 1152
tru3s1lv3r 39
Tunerman 1002
tungkon 1011
TurboLion 917
turbopscl 892
turpulator 1066 1363
tzmxxhh 21
Ulric 1198
unit311 849
unknown00101 548
uqs1000 357
Vagany 647
VaKo 208
Valdorg 1202
Van 491
Vanq86 1176
vas 133
vasa_visost 668
Vattern 18
velocraig 781
vex_zg 730
Viamede 948
vinte77 414
Volks1973 743
vulpes 539
vwpieces 881
Wackyvegan 156
walty 280
WarHawk-AVG 420 421
warzi1975 528
wattstar 791
websterjody 996 1105
weklund 460
Werner 10
WestBam 1333
westcoastwonders 639
whitecitadel 1354
Wieselflinkpro 125 750 1079
Wildcat 827 945
wildmermaid 1091
Wildthing 533
willmo 605 882
WillyD 303
wilwok 1076 1258
Wineslurper 554 555
wisefire 869
wishiwereaskibum 587
wkhchin81 477
Wojto 1325
WolfA 69
Wrathbringer27 41
wunderhe 115
Wyre 1269
Xandre 527
xCentrino 1314 1358
xed888 305
xelario 773
xjsnake 36
xray291 1192
xtrosity 723
XXX-Man 1197
xzel87 665
yasenf 1006 1232 1233 1273 1274
yclongthrow 898 899
YoFlash 744
Yokiamy 1245
Yourrid 1101 1102
zachary6227 1297
zak.wilson 182
Zanders 792
zara 180
zelee 22
Zeratull 703
zeroair 452
zifzif 1243
zipelgas 386
zoysiamo 1251
ZozzV6 626
×73rmin8r 1063
1008 names
1360 lights
  1. 2 DOGS, 264, 2Ace, 5ar, 7pot, a12luke, a_idiot, Aardvark Spleen, Abe87, Abqjohnny
  2. abril, adirondackdestroyer, adrianlights, AEDe, Ag76, aggillator, aginthelaw, Agiri, aim120, AirBreaker
  3. akhyar, akoposilester, akovia, albertopnp, Alcius, alejandrov, alex64, AlexGT, Alkpwn77, allthumbs
  4. alphazeta, alternety, Alux, amplificus, Andmiller, andrewmac, Andybibbville, Andyman?, Angel Martínez, ant0
  5. Antenne, Anthon, antiparanoico, AppA, aprendiz, apt323, archi, archimedes, aremihc, ARMS.AARON
  6. ARsee, Arufonsi, aslpg, asnidi2, asot, Astromanic, AsylumSweep, atbglenn, Atom00, Autoclave
  7. Awdtsi, Awkward Stretch, AwkwardPause, b1i1l1l1y1, B42, BackpackNY, bakalakos, balazs1956, baldo21, Bam35
  8. bamawthu, banker, basslovin808, Bastarrdo, Batch1, battletross, bawilson2, Bc412, bd52, BDM
  9. BDWrabbit, BeardedRaleigh, bella-headlight, Bernard, Bevo, bhuge00, bigpix, bigrick, bikedave99, bikenber73
  10. Bill 63, Bill_tong, Billcheese5, bionictony, bkling, BlackList, bladesmith3, BLFD80, BlindingL5s, blinker
  11. blinky, blueb8llz, Bluzie, bmaddison, Boaz, BobbyMK, bobdotorg, bobofire, Bogdan, bogdanr
  12. Bohemian, bonfire, Bong lick, Bonham, borealis, BorisBar, Boro, bossf350, Box, Brettg4215
  13. Brian Metcalfe, BrianK, BrianTheJay, brightlights, brjones, brno602, brted, Bruno28, BT100, Bungle88
  14. Buzzy243, bwl123, cabfrank, Caleb, Caleb-v, Calmaja, Cano, Captainvideo, caramba, carmantl
  15. casi29061965, cavorite, Cawi, cbrake10, cclight, cdjaney, Chadvone, Charga, charles lin, CheapThrills
  16. cheesecheeks, ChibiM, Chicken Drumstick, chinooker, chooma, chrisc, churchilllafemme, CircaM, Cjlee89, cjoe7
  17. CJW, clagged, clange50, clinicdoc, Cliwilnew, cloggy, cmflippen, cnrffl1, cocoschnauzer, contigo
  18. Coolerness, coolriku, Corzy, Couchmaster, cpd800t, CrashOne, Crazyeddie, Creepo, cristhemuso, crx88ia
  19. cujo255, cwb, cypher1024, cypherz, Cythras, D10ten, Dadpool, dafarui, daninho, DarkerInSol
  20. darkpenguin, darol, darrenm, darrylo, DarthTader, datiLED, dave101, DavidEF?, davidkappelt, davidvns
  21. davos, DB Custom, dbesselt, DBSAR, DBSS, deathless, Deep skull, DeJaVu, dekozn, Dennis
  22. dentillozie, Dep668, derfyled, derpilgerer, Desmo, devdvr, dezoe, dhsvcs, dicksog, digitaltc
  23. Dimking, Dirt, Dirty_Pierre, DiscoJoe, djburkes, Djozz, dmbaty, Dobtruckers, DOCFAR, Docp723
  24. Doctawho, dodo, dogany, Dogsrule, donpachi, dotBLF, doubleone44, downlinx, doxerino, Dr Forinor
  25. Dradge, Dralf, Dregs, DrHook59, driveX, DrJones, DT101, dudunphy, Duke, dumptruck
  26. Dusty, Dutcheee, duvallite, dw911, Dwantink, e10sno, Easyrr, eb1888, ebosh, ediaz
  27. eebowler, Eggun, egrep, Eivwer, electricjelly, ElginAgain, emarkd, embee, Enelooper, engber
  28. ERDOS, Erethryn, erikk365, Esskay, Etex, euphxenos, everydaysurvivalgear, Evilc, EyeballFryer, Fadetoblack
  29. fantomR, Far Thrower, Farmboy24, Farns, Fatlight, fatsteve0, FBsLights, fcrespi, fed893, fedcas
  30. feralcomprehension, finges, fireblade893, firedome, Firelight2, fishlite5, fixed it, fixvid, Flash Voyager, flashination
  31. FlashMax, Flashy Mike, Flifish48, Flintrock, fluffman86, FmC, fonfan, fonLED, Ford Prefect, Foston Pete
  32. foton, Fozzy-SP, Frank A., Frankie Baby, Franz, Freddy61069, Fredylee, FreeMagenta, freeme, Fritz t. Cat
  33. Funzel67, fuzun, fyesilova, g60, g_sintornillos, gamezawy, gangstead, garrybunk, gboss, gds95
  34. gedasd, geepaw, gehrmo, geo1952, ger-slash, Gerrh, Gerrit, getbully, Gilatabar, giorgoskok
  35. GIR, gisewhcs, Gj, gleamer, GlinnDamar, gnatx, goatfarmer, GoldenBatt, gorb507, goshdogit
  36. gpapa693, gravelmonkey, green_comet, GreenShrike, gregor, GTsuperheros, Gtt980, guerrilla154, Guggga, GulfCoast
  37. gungoat, Gunnerboy, Guns712, h2o, Hairy_Steve, hank, Hardware, Hauwexis, haxquiz, headburger
  38. heatwaves, hein11ag, Herb Tarlek, Hestbech, hexcode, Hezekiah, hideehoo, HighCaliber, hmihaylov, Hobo
  39. hunter1, hurleyy, I_like_lamb, Ian2381, igeigeige, IH8MYX, ii_pennies, ikaruz_500, Illumenated, illusioned
  40. Ilmatic, ilovejesuschrist, ImA4Wheelr, ISO, iwandutchy, J-Dub74, J_R_J, jack-bkk, jacktheclipper, Jailbrake
  41. JakeDjanitor, Jalben, jama, Jambo, james y, javipiloto, jaynick, JayT, Jayzed, jb1
  42. jdunlap27284, jealous57, Jensa41, Jerommel, jerrod, jescereal, Jesjes, jfalk1, jhalb, jhullin
  43. jingleberry, Jinx, jkbam, jmoots, jmpaul320, jmwhite151, Joat, JockRobbins, Joe Darkness, joe1512
  44. joeangi, joechina, Joey Adams, John-Galt, Johnhywash1, johnnydoe, JohnnyMac, johnpc, johny723, Jonandreadolan
  45. JonnyC, JordanZHP, josephqool, jpcuba, JPLight, JPM3, JS721, jsmn4vu, Jtm94, Juanesdan
  46. juaquin, Juggeli, jurasik1, justanotherguy, Jvrthp321, jycheang, k-wong, Kafar, kahvitahra, Kalchev
  47. kali stupa, Kalihi, KawiBoy1428, kaybi, Kazik, kbro, keengeorge, KeepingItLight, Keepitsharp, Keisari
  48. keithd, KenE, Kenjii, Kentuckywindage, Kepling, KFulton, khas, Khuan, KIKY, Killforfood
  49. Kindle, KingSmono, kiriba-ru, Kiukas, KiwiKane, Kkelleher, Kloepper Knife Works, knightstalker, kntx, knudsengj
  50. Koaksijalac, Kodachrome40, KoekieMonster, kommessy, korpzgrinda, kotobuki, koyotee, Kozy, krutone, Kulumatic
  51. Kurt_Norway, Kusie, KutKhemist, Kysumi, LAB, lachesis, lalomt, Lamont56, lamper, lanceb1b
  52. laststance, lawallac, Lazy-R-us, Le_Zouave, leaftye, LEDtec, legan710, Legolas Jr., leroycp, Lexel
  53. Lfatman, Liber8, lichtpfadfinder, Light of Earendil, lightbulb, lightknot, lightlight22, lightmog, lightx, Lilien
  54. Lion42, lionheart_2281, litcrit, Litefighter, LloydV, Loneman, longmire, Lopan, lovetheguitar, Lowtech
  55. ludolf, luisgcan, Lumenmaster17, Lumens Industry, lumiere, Lund1660, luxlad, lyse99, Lyubo Yanev, M4D M4X
  56. M78, MACS0647, MAD TM26, Magbrite, magnet, MagPap, Maiden666, maildroid, Majoroverkill, malamask
  57. mandala, manithree, Manulous, ManWithoutShadow, Mapache, markalike, Marothar, marsalla, Martini, martook
  58. martytown, Masejoer, Matchoo, matkovicha, Matomoto, mattlward, MauiSon, maukka, Maxxsounds, MBuitendorp
  59. mcfarlie6996, MCT, Mecallie, MechEngVictor, Medvegy, Melven, meti, metz3006, Meyer, MG
  60. mhanlen, mi bill, Micael, Miguel_79, Miguelintegral, mikeyx, Mindaugass, Minimoke, miswas, Mitko
  61. mitrhandir, mizjif, Mkduffer, mlodyulek, moemin, MontyPyfon, moridin, Morpheus, MorpheusT1, MortyDuck
  62. MountainKing, MountainMan, mozart.f, Mr.Poppy, Mr.Scott, mrheosuper, mrkelvin, MRsDNF, mrstealyourgains, msg1285
  63. Mstevens113, Mt.B, MtnDon, mud_muncher, mudguts, Muto, mutts13, muzzleblast?, mxlu, MyDangus
  64. myowin, myst999, nanojack, narin000, Nathan42, Navin_R_Johnson, neckbear, needmorlts, Neilyboy, netprince
  65. nexrace1, nfetterly, Nguyen, nickdude, Nickke, Nicolaas, Nicolicous, Night Light, NightLight, Nightshade
  66. niktak11, Nil, Nite Shadow, Nitetime, nitrader0, nnmnu1, No Agenda, nofear87, Noki, noob
  67. Nord, Nortson, novice1, nqcken, nskn71, NuggetMcNugget, ObiWan-Kenobi, octav, OdorlessCurves, ohnonothimagain
  68. olivedrab, OrangePeel, orinjuse, Orionz23, osb40000, OscarM, Oswald3211, oto, Ozythemandias, Pablogy
  69. PabloVerde, pacbough, papaslightsaber, patchythepirate, patmet, patmurris, patmurris , Paul321, pawwright, PBWilson
  70. peabody, Peetz, Pegaso, Peho, pepe2017, pepinfaxera, perche, peterlcole, peteybaby, petr9999
  71. Petroleum Lantern Guy, Phoenix_FIN, Pidro, pieman7, pirate joe 22, piyoman, plntigrado, pommie, pook, pooptoast
  72. powerfultorches, praveendk, presterjohn, Presumptuous, Primal, prisma, Prometheus, ProtaBLF, pscal, puccio1969
  73. Pukachi, pukoid, Pulsar13, qandeel, R.D., radb, rag, Ragsy, raiko, rajun50
  74. Randolph, RapidLux, Rat_Racer, RaVeN, raynman, rdoc613, red72vw, redrider706, regaia, reliant_turbo
  75. ReManG, reno, retiro675, rexdog, rfd673, ricardon, Ricflair, Rick, rjorge, rmkline
  76. Rob_K, robbobus, Roberrt777, RobertB, RocketTomato, RockHugger, Romey310, RonMuller, Roter, RotorHead64
  77. Rpdos, Rska, Rsqweezy, rufrydr, Rufusbduck, Rxich, ryukin2000, sac02, saf99, Saigon
  78. SamHaLeKe, samis, samnavy, san san, sandanbob, Sarge930, Savydude, SawMaster, saypat, sb56637
  79. scarnific, scdaf, Schkü, schlockproof, Sciencetists, SciFiFreak, Scooby, Scooter000, scootypuffjr, Scorpia
  80. scotlarock, Scottland, Scotty, scs, sebastiang, SebaZ74, SeenTheLight, SFB, Sgtpev, Shadowcactus
  81. Shadowfax, Sharpie, shimano3000, shimey, shirnask, Shoe, shogan, Shur, SIGShooter, Silent_Star
  82. Silentcropduster, Simplelight, slackwolf, slackwolf 3rd, Sledge, Sledgestone, slickpenguin, slimkango, slow2go, smed1275
  83. Smittymojo, SmokinH, Snoballz, SoCalTiger, sochi111, Sofa, sol, SolarLumen, solRNY, somnambulism
  84. Sonpham, southland, sp5it, spade413, sparkyDK, specialk, Speed4goal, Speedsix, spkzzz, Sprinkles
  85. srs2000, stanley-beamish, starcrazed, stareye, staticx57, steel_1024, Steenbhg, steepdrop, Stephen Elliott, stephenk
  86. steve42, Stevejj, SteveMidwest, stevez32, Stittville Ed, Stoneface, strango, strayz, Streamer, strmix
  87. Subterrestrial, Sukoi, Sullysat, Suncoaster, Swennie, Syncmasterklop, syracuse, T-boon, T18, t3rminal
  88. tapir, tarver, Tarvos, tas69, tatasal, teacher, tebeve, techieman33, Tecmo, tekwyzrd
  89. tenohfive, Tete, Texas_Ace, The Burgh, The Grand Pooh-Bah, The Imp, The Jinx, The Last Katun, The Miller, The_Driver
  90. thebaum, thecrc, TheDude, TheHebrewHammer, TheJo, TheMadcap, themaindude, Theodore41, theoldbill, TheOnlyDocc
  91. thijsco19, tigris99, timcodes, tindrum42, tinowrx, Tixx, Tjhosan, Tjohn, Tmik, tmxod
  92. Toccata, tocirahl, Tom E, Tom_182, tomtaylor, tonylim, torchjunkie, toxiccoccyx, ToyKeeper, tracerfire
  93. Trashman531, Trasnodel, trevglas, trevize, treysoucie, tristanxoxo, troisanh, tronx, TRoPHeuS, tru3s1lv3r
  94. Tunerman, tungkon, TurboLion, turbopscl, turpulator, tzmxxhh, Ulric, unit311, unknown00101, uqs1000
  95. Vagany, VaKo, Valdorg, Van, Vanq86, vas, vasa_visost, Vattern, velocraig, vex_zg
  96. Viamede, vinte77, Volks1973, vulpes, vwpieces, Wackyvegan, walty, WarHawk-AVG, warzi1975, wattstar
  97. websterjody, weklund, Werner, WestBam, westcoastwonders, whitecitadel, Wieselflinkpro, Wildcat, wildmermaid, Wildthing
  98. willmo, WillyD, wilwok, Wineslurper, wisefire, wishiwereaskibum, wkhchin81, Wojto, WolfA, Wrathbringer27
  99. wunderhe, Wyre, Xandre, xCentrino, xed888, xelario, xjsnake, xray291, xtrosity, XXX-Man
  100. xzel87, yasenf, yclongthrow, YoFlash, Yokiamy, Yourrid, zachary6227, zak.wilson, Zanders, zara
  101. zelee, Zeratull, zeroair, zifzif, zipelgas, zoysiamo, ZozzV6, ×73rmin8r,
:+1: …. My apologies sparky. I was thinking only of the GA’s and totally left out the test of the important facts about most all other flat tops. :person_facepalming:
Again… my apologies. I shall now put on the Dunce Hat & sit myself in the corner the remainder of the night for the incorrect info I gave… that in all likelyhood could create confusion…… :person_facepalming: … :cry:
Thank goodness Tom caught it quickly & posted the correct info. :slight_smile:
I’ll edit my post also…
Thats okay and not the cells i got for the Q8, i have a set of Sony’s VTC6 and a Set of the brown LG’s ( HG2 ), both flat top style i will have to do something about.
I am not quite sure if the GAs will be good without something done to them, as they have no button the spring should squease them less tight, so maybe a thud on the end cap would make connection go.
Then again as i understand the Q8 that shouldent matter if one or two cells momentarily get disconnected.
Man i cant wait to get my hands on this thing, just ordered a new sleeping bag tonight, so aside for a pice of tarp i am ready to go play survivalist in the forests of Denmark.
Forrest’s that will not be so dark when i am around, with or without the Q8 :wink:
